What do I need to switch to LinuxCNC
- Himarc3D
- Thank you received: 49
15 Sep 2020 21:19 #182278
by Himarc3D
Replied by Himarc3D on topic What do I need to switch to LinuxCNC
Here i used Rufus and was okay.What boot media did you use ?
DVD or USB ?
If USB what utility did you use ?
Win32diskimager is the most reliable. Which ISO did you use ?
Etcher and Rufus can cause issues for some reason.
Are you booting with a UEFI system or a legacy BIOS system or using a legacy module on a UEFI system ?
- rogerfries
15 Sep 2020 21:28 #182280
by rogerfries
Replied by rogerfries on topic What do I need to switch to LinuxCNC
Yes, I'm a bit out of date. I work in a super large company and do mostly enterprise application stuff these days. I don't often get the chance to play in the weeds.
The secure boot thing helped and I've moved on errors copying the files on the install from the USB, retrying from the DVD
- BeagleBrainz
- Visitor
15 Sep 2020 21:36 #182282
by BeagleBrainz
Replied by BeagleBrainz on topic What do I need to switch to LinuxCNC
Hmmmm any idea of the error messages ?
The more info supplied the better help can be.
- rogerfries
15 Sep 2020 21:41 #182283
by rogerfries
Sorry, wasn't asking for help yet on that issue I'm retrying with the DVD and it seems to be working now.
I still haven't ordered my Mesa card. I'm not quite ready to commit, but I haven't given Mach any more money either. I really want to give this a try.
- BeagleBrainz
- Visitor
15 Sep 2020 21:43 #182284
by BeagleBrainz
Okay, if grub fails at the end of installation let me know.
- rogerfries
15 Sep 2020 21:56 #182286
by rogerfries
BeagleBrainz, You must be Psychic
Grub failed in /dev/sda
Not sure where my last post went. Is there a delay because I'm a new user or something?
- BeagleBrainz
- Visitor
15 Sep 2020 22:08 #182288
by BeagleBrainz
Nah that's purely my fault. Was a while between creating ISOs.
When you get the menu press e to edit
change the text fromto
Then boot.
quiet splashquiet splash efi=runtimeThen boot.
- rogerfries
15 Sep 2020 22:41 #182293
by rogerfries
OK got it installed! Thanks again! I'm looking at the gmoccapy screens now.
- BeagleBrainz
- Visitor
15 Sep 2020 22:44 #182294
by BeagleBrainz
Sorry that it wasn't as smooth as it should be.
I'll get a fix up shortly.
- Thank you received: 4144
16 Sep 2020 07:14 #182396
Replied by rodw on topic What do I need to switch to LinuxCNC
Ah, a Google Drive man after my own heart!
So now you have the distro up and running, you will be able to install Chromium which is the open source version of Chrome from the command line but I always use Google's version. In the default browser (is it Firefox?), go to www.google.com/chrome/ and download the package. you should be able to just click on it and gdebi or similar will install it for you.
Then its just a matter of logging into Chrome and all your shortcuts should replicate and you can log into Gmail and then you are sweet to get to Drive or any other Google app. The experience is identical to Windows (or the Chromebook I am typing this on)
Time to create page: 0.438 seconds
