AASD chinese ac servo's step/dir Oscilations
  • bevins
  • bevins's Avatar Topic Author
  • Platinum Member
  • Platinum Member
20 Sep 2020 14:30 - 20 Sep 2020 14:30 #182910 by bevins
I am trying to get these servos operating properly. I am using 7i92/7i76 and the drives are in step/dir.
When I move them with keyboard jogging they oscillate like crazy as shown in video.
When I jog them with drive control panel they don't. and they move great.
I know it seems like they need tuning but I think it may be linuxcnc and how it is setup.
I am using step+- and dir +- and tried 0,1,2 step type to no avail.
HAL File
Warning: Spoiler!
INI file
Warning: Spoiler!
Last edit: 20 Sep 2020 14:30 by bevins.
20 Sep 2020 17:04 #182932 by tommylight
Replied by tommylight on topic AASD chinese ac servo's step/dir Oscilations
Omit the
....maxerror.. =0.01
lines and see if that helps.
The following user(s) said Thank You: bevins
20 Sep 2020 19:07 - 20 Sep 2020 19:14 #182944 by PCW
Looks like a drive issue (oscillations > max_ferror)
You can check this by monitoring the following error
Note step-type should be 0 for step/dir drives
1 is CW/CCW, 2 is Quadrature
Last edit: 20 Sep 2020 19:14 by PCW.
  • bevins
  • Platinum Member
  • Platinum Member
20 Sep 2020 20:46 #182957 by bevins
Omit the
Yeah, did that in the hal and it does the same thing.
  • bevins
  • Platinum Member
  • Platinum Member
20 Sep 2020 20:52 #182958 by bevins
I changed them back to step type 0. no change
I have worked on this for half the week and all weekend and cannot get these drives to be stable. I actually havent been able to change the way they act at all. These drives are fubar or I am not changing what needs to be change3d.
Here is the manual: AASD manuals
Use the AASD one. better translation.
20 Sep 2020 21:26 #182968 by tommylight
Wiring according to page 20?
Any alarms going off ?
Looks like Pn002 has to be set to 2
Pn096 on page 61 has to be set to 0 for step/dir but on the wiring page it says it has to be 1 for step/dir ????
  • bevins
  • Platinum Member
  • Platinum Member
20 Sep 2020 22:31 #182974 by bevins
Pn002 is set to 2
I am using differential input mode. step +/Step- dir+/dir-
No alarms.....
I tried all three.... on Pn096
It says with differential max 500khz. Where is this changed?
I cant find any parameters that change the internal pid. I change the gain I think is P but doesn't do anything.
20 Sep 2020 22:45 - 20 Sep 2020 22:46 #182976 by PCW
Did you determine that its an internal vs external (LinuxCNC setup) issue?
You can do this by seeing if the following error shows the oscillations
If it does, this is a LinuxCNC setup issue, if not, its a drive tuning issue
Last edit: 20 Sep 2020 22:46 by PCW.
  • bevins
  • Platinum Member
  • Platinum Member
20 Sep 2020 22:55 #182979 by bevins
I thought I had it nailed down to being linuxcnc setup because in jogging mode on the drive when I jog, it acts perfectly.
I will check hal scope for following error.
  • bevins
  • Platinum Member
  • Platinum Member
20 Sep 2020 23:01 #182982 by bevins
Jogging from Drive panel works fine.
Time to create page: 0.181 seconds
