AASD chinese ac servo's step/dir Oscilations
- bevins
- Thank you received: 338
20 Sep 2020 23:19 - 20 Sep 2020 23:21 #182988
by bevins
Replied by bevins on topic AASD chinese ac servo's step/dir Oscilations
Last edit: 20 Sep 2020 23:21 by bevins.
- Thank you received: 5307
21 Sep 2020 00:11 #182993
Replied by PCW on topic AASD chinese ac servo's step/dir Oscilations
Right so no oscillations there (peak error in step generation = 3 uinches or so)
- bevins
21 Sep 2020 10:42 #183116
by bevins
with the drives enabled I can move the axis by hand and then it start oscillating.
Do I need more P gain?
- bevins
21 Sep 2020 12:23 #183123
by bevins
AH!!!
Found the good manual that has the PIDS and adjustments. I should be ok now.
But for anyone with the Chinese AASD drives use this manual.
AASD manual with all parameters to tune
- bevins
22 Sep 2020 00:33 #183207
by bevins
What's your best guess why this is doping this. all motors are doing it.
I have been trying to get this tuned but keep having same issue as in the last video.
I can swap out the 7i76 for a 7i77 as a last resort. I have a 7i77, I would like to see if I can fix it though.
22 Sep 2020 01:10 #183217
Too much P or too little D in the drive would be my first guess
I would probably increase D until it gets too crunchy/buzzy
then back off about 50%.
- bevins
22 Sep 2020 11:23 #183274
by bevins
yeah, well, they dont call it D in the manual. I dont know what parameters is what.
- bevins
22 Sep 2020 19:02 #183330
by bevins
What is a safe max for P. I am up to 1200 and I can push the axis until I get following error.
What would you call max P before I consider that not the problem?
- bevins
22 Sep 2020 19:14 #183333
by bevins
I am up to 8450 for P{ and it is not changing still soft. I can push it to f-error but I feel the resistance.
I found a parameter called: speed command source in speed control mode
I selected Motion controller analog voltage command, but it doesnt change anything when I am adding P in linuxcnc.
It does bypass the internal loop of the drive.
22 Sep 2020 20:07 - 22 Sep 2020 20:07 #183339
Its not clear to me which parameters are which (and LinuxCNC doesnt need any PID changes,
this is all in the drive)
Does the drive come with any tuning software?
Last edit: 22 Sep 2020 20:07 by PCW.
Time to create page: 0.195 seconds
