whb not showing up?
  • Catch22
  • Catch22's Avatar Topic Author
  • Elite Member
  • Elite Member
19 Oct 2020 16:35 - 19 Oct 2020 20:33 #186591 by Catch22
whb not showing up? was created by Catch22
So when I open up Linuxcnc and go to
Show Hal Configuration, then click on pins, there is no whb there. When I open up the Sim it is in there. Am I missing something. This is to get my Xhc-whb04b-4 working.
It works in the Linuxcnc simulator.
Last edit: 19 Oct 2020 20:33 by Catch22.
20 Oct 2020 20:50 #186746 by Todd Zuercher
Replied by Todd Zuercher on topic whb not showing up?
Did you add the lines to your hal file to load the driver, and add it to the real time thread(s)?
  • Catch22
  • Elite Member
  • Elite Member
20 Oct 2020 21:12 #186753 by Catch22
Replied by Catch22 on topic whb not showing up?
I'm pretty sure I did, I followed talla83 video and the simulator worked, but when I tried doing it on the machine it didn't.
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
20 Oct 2020 21:59 #186757 by BeagleBrainz
Replied by BeagleBrainz on topic whb not showing up?
Do we really need to ask for you to post the hal & ini files ? :S
Have a look here.
forum.linuxcnc.org/51-ot-posts/40089-a-r...ose-that-have-issues
  • Catch22
  • Elite Member
  • Elite Member
20 Oct 2020 22:58 #186765 by Catch22
Sorry about that, here are my files. And Thank you....
report file
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.0~pre1
Machine configuration directory is '/home/mike/linuxcnc/configs/my_LinuxCNC_machine'
Machine configuration file is 'my_LinuxCNC_machine.ini'
INIFILE=/home/mike/linuxcnc/configs/my_LinuxCNC_machine/my_LinuxCNC_machine.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=XYZ
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./my_LinuxCNC_machine.hal
Found file(REL): ./custom.hal
CANNOT FIND FILE FOR:xhc-whb04b-6.hal
Running HAL shutdown script
hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
hm2_pci: discovered 5i25 at 0000:04:00.0
hm2/hm2_5i25.0: Smart Serial Firmware Version 43
Board hm2_5i25.0.7i77.0.0 Hardware Mode 0 = standard
Board hm2_5i25.0.7i77.0.0 Software Mode 0 = input_output
Board hm2_5i25.0.7i77.0.0 Software Mode 1 = io_analog
Board hm2_5i25.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage
Board hm2_5i25.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage
Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
hm2/hm2_5i25.0: 34 I/O Pins used:
hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData0 (Output)
hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData0 (Input)
hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
hm2/hm2_5i25.0: registered
hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
hm2/hm2_5i25.0: unregistered
hm2_pci: driver unloaded
hm2: unloading
Debug file information:
Note: Using POSIX realtime
2708
Stopping realtime threads
Unloading hal components
RTAPI_PCI: Unmapped 65536 bytes at 0x7f5e5c44f000
Info report created by linuxcnc_info:
The file: /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
pastebin.com
in order to provide information about the linuxcnc
system and configuration.
Date: Tue Oct 20 18:52:26 EDT 2020
UTC Date: Tue Oct 20 22:52:26 UTC 2020
this program: /usr/bin/linuxcnc_info
uptime: 18:52:26 up 5 min, 1 user, load average: 0.40, 0.94, 0.49
lsb_release -sa: LinuxMint Linuxcnc Uspace Powered by Linux Mint 19.2 Tina 19.2 tina
which linuxcnc: /usr/bin/linuxcnc
pwd: /home/mike/linuxcnc/configs/my_LinuxCNC_machine
USER: mike
LOGNAME: mike
HOME: /home/mike
EDITOR:
VISUAL:
LANGUAGE: en_CA:en
TERM: dumb
COLORTERM:
DISPLAY: :0
DESKTOP: mate
display size: 1920x1080 pixels (508x285 millimeters)
PATH: /usr/bin:/home/mike/linuxcnc/configs/my_LinuxCNC_machine/bin:/usr/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games
uname items:
nodename -n: cnc
kernel-name -s: Linux
kernel-vers -v: #1 SMP PREEMPT RT Thu Mar 5 00:02:34 AEDT 2020
machine -m: x86_64
processor -p: x86_64
platform -i: x86_64
oper system -o: GNU/Linux
/proc items:
cmdline: BOOT_IMAGE=/boot/vmlinuz-4.19.106-rt44-lcnc root=UUID=dc295af9-e1cf-45c8-a78c-4ecf9396287e ro quiet splash vt.handoff=1
model name: Intel(R) Core(TM)2 CPU 6400 @ 2.13GHz
cores: 2
cpu MHz: 2041.545
parport: 0000-0000 : parport0 0000-0000 : parport0 0000-0000 : parport0
serial: 0000-0000 : serial
Versions:
gcc: gcc (Ubuntu 7.5.0-3ubuntu1~18.04) 7.5.0
python: Python 2.7.17
git: git version 2.17.1
git commit: NA
tcl: 8.6
tk: 8.6
glade: not_in_PATH
glade-gtk2: not_in_PATH
linuxcnc_var all:
LINUXCNCVERSION: 2.8.0~pre1
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
REALTIME: /etc/init.d/realtime
RTS: uspace
HALLIB_DIR: /usr/share/linuxcnc/hallib
dpkg -l '*linuxcnc*':
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
un linuxcnc <none> <none> (no description available)
un linuxcnc-dev <none> <none> (no description available)
un linuxcnc-doc <none> <none> (no description available)
ii linuxcnc-doc-en 1:2.8.0~pre1.5904.gf7b17e195 all motion controller for CNC machines and robots (English documentation)
un linuxcnc-sim <none> <none> (no description available)
un linuxcnc-sim-dev <none> <none> (no description available)
ii linuxcnc-uspace 1:2.8.0~pre1.5904.gf7b17e195 amd64 motion controller for CNC machines and robots
ii linuxcnc-uspace-dev 1:2.8.0~pre1.5904.gf7b17e195 amd64 PC based motion controller for real-time Linux
hal file
# Generated by PNCconf at Sun Jan 28 11:04:57 2018
# Using LinuxCNC version: UNAVAILABLE
# overwritten when you run PNCconf again
loadrt [KINS]KINEMATICS
loadrt hostmot2
loadrt hm2_pci config=" num_encoders=6 num_pwmgens=0 num_stepgens=0 sserial_port_0=000xxx"
setp hm2_5i25.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.y,pid.z,pid.s
loadrt scale names=scale.gear
loadrt mux16 names=ratio_select
addf hm2_5i25.0.read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.y.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf ratio_select servo-thread
addf scale.gear servo-thread
addf hm2_5i25.0.write servo-thread
# external output signals
# external input signals
# --- ESTOP-EXT ---
net estop-ext <= hm2_5i25.0.7i77.0.0.input-00
# --- BOTH-HOME-X ---
net both-home-x <= hm2_5i25.0.7i77.0.0.input-11-not
# --- BOTH-HOME-Y ---
net both-home-y <= hm2_5i25.0.7i77.0.0.input-12-not
# --- BOTH-HOME-Z ---
net both-home-z <= hm2_5i25.0.7i77.0.0.input-13-not
# AXIS X JOINT 0
setp pid.x.Pgain [JOINT_0]P
setp pid.x.Igain [JOINT_0]I
setp pid.x.Dgain [JOINT_0]D
setp pid.x.bias [JOINT_0]BIAS
setp pid.x.FF0 [JOINT_0]FF0
setp pid.x.FF1 [JOINT_0]FF1
setp pid.x.FF2 [JOINT_0]FF2
setp pid.x.deadband [JOINT_0]DEADBAND
setp pid.x.maxoutput [JOINT_0]MAX_OUTPUT
setp pid.x.error-previous-target true
net x-index-enable <=> pid.x.index-enable
net x-enable => pid.x.enable
net x-pos-cmd => pid.x.command
net x-pos-fb => pid.x.feedback
net x-output <= pid.x.output
# ---PWM Generator signals/setup---
setp hm2_5i25.0.7i77.0.1.analogout0-scalemax [JOINT_0]OUTPUT_SCALE
setp hm2_5i25.0.7i77.0.1.analogout0-minlim [JOINT_0]OUTPUT_MIN_LIMIT
setp hm2_5i25.0.7i77.0.1.analogout0-maxlim [JOINT_0]OUTPUT_MAX_LIMIT
net x-output => hm2_5i25.0.7i77.0.1.analogout0
net x-pos-cmd <= joint.0.motor-pos-cmd
net x-enable <= joint.0.amp-enable-out
# enable _all_ sserial pwmgens
net x-enable => hm2_5i25.0.7i77.0.1.analogena
setp hm2_5i25.0.encoder.00.counter-mode 0
setp hm2_5i25.0.encoder.00.filter 1
setp hm2_5i25.0.encoder.00.index-invert 0
setp hm2_5i25.0.encoder.00.index-mask 0
setp hm2_5i25.0.encoder.00.index-mask-invert 0
setp hm2_5i25.0.encoder.00.scale [JOINT_0]ENCODER_SCALE
net x-pos-fb <= hm2_5i25.0.encoder.00.position
net x-vel-fb <= hm2_5i25.0.encoder.00.velocity
net x-pos-fb => joint.0.motor-pos-fb
net x-index-enable joint.0.index-enable <=> hm2_5i25.0.encoder.00.index-enable
net x-pos-rawcounts <= hm2_5i25.0.encoder.00.rawcounts
# ---setup home / limit switch signals---
net both-home-x => joint.0.home-sw-in
net both-home-x => joint.0.neg-lim-sw-in
net both-home-x => joint.0.pos-lim-sw-in
# AXIS Y JOINT 1
setp pid.y.Pgain [JOINT_1]P
setp pid.y.Igain [JOINT_1]I
setp pid.y.Dgain [JOINT_1]D
setp pid.y.bias [JOINT_1]BIAS
setp pid.y.FF0 [JOINT_1]FF0
setp pid.y.FF1 [JOINT_1]FF1
setp pid.y.FF2 [JOINT_1]FF2
setp pid.y.deadband [JOINT_1]DEADBAND
setp pid.y.maxoutput [JOINT_1]MAX_OUTPUT
setp pid.y.error-previous-target true
net y-index-enable <=> pid.y.index-enable
net y-enable => pid.y.enable
net y-pos-cmd => pid.y.command
net y-pos-fb => pid.y.feedback
net y-output <= pid.y.output
setp hm2_5i25.0.7i77.0.1.analogout1-scalemax [JOINT_1]OUTPUT_SCALE
setp hm2_5i25.0.7i77.0.1.analogout1-minlim [JOINT_1]OUTPUT_MIN_LIMIT
setp hm2_5i25.0.7i77.0.1.analogout1-maxlim [JOINT_1]OUTPUT_MAX_LIMIT
net y-output => hm2_5i25.0.7i77.0.1.analogout1
net y-pos-cmd <= joint.1.motor-pos-cmd
net y-enable <= joint.1.amp-enable-out
setp hm2_5i25.0.encoder.01.counter-mode 0
setp hm2_5i25.0.encoder.01.filter 1
setp hm2_5i25.0.encoder.01.index-invert 0
setp hm2_5i25.0.encoder.01.index-mask 0
setp hm2_5i25.0.encoder.01.index-mask-invert 0
setp hm2_5i25.0.encoder.01.scale [JOINT_1]ENCODER_SCALE
net y-pos-fb <= hm2_5i25.0.encoder.01.position
net y-vel-fb <= hm2_5i25.0.encoder.01.velocity
net y-pos-fb => joint.1.motor-pos-fb
net y-index-enable joint.1.index-enable <=> hm2_5i25.0.encoder.01.index-enable
net y-pos-rawcounts <= hm2_5i25.0.encoder.01.rawcounts
net both-home-y => joint.1.home-sw-in
net both-home-y => joint.1.neg-lim-sw-in
net both-home-y => joint.1.pos-lim-sw-in
# AXIS Z JOINT 2
setp pid.z.Pgain [JOINT_2]P
setp pid.z.Igain [JOINT_2]I
setp pid.z.Dgain [JOINT_2]D
setp pid.z.bias [JOINT_2]BIAS
setp pid.z.FF0 [JOINT_2]FF0
setp pid.z.FF1 [JOINT_2]FF1
setp pid.z.FF2 [JOINT_2]FF2
setp pid.z.deadband [JOINT_2]DEADBAND
setp pid.z.maxoutput [JOINT_2]MAX_OUTPUT
setp pid.z.error-previous-target true
net z-index-enable <=> pid.z.index-enable
net z-enable => pid.z.enable
net z-pos-cmd => pid.z.command
net z-pos-fb => pid.z.feedback
net z-output <= pid.z.output
setp hm2_5i25.0.7i77.0.1.analogout2-scalemax [JOINT_2]OUTPUT_SCALE
setp hm2_5i25.0.7i77.0.1.analogout2-minlim [JOINT_2]OUTPUT_MIN_LIMIT
setp hm2_5i25.0.7i77.0.1.analogout2-maxlim [JOINT_2]OUTPUT_MAX_LIMIT
net z-output => hm2_5i25.0.7i77.0.1.analogout2
net z-pos-cmd <= joint.2.motor-pos-cmd
net z-enable <= joint.2.amp-enable-out
setp hm2_5i25.0.encoder.02.counter-mode 0
setp hm2_5i25.0.encoder.02.filter 1
setp hm2_5i25.0.encoder.02.index-invert 0
setp hm2_5i25.0.encoder.02.index-mask 0
setp hm2_5i25.0.encoder.02.index-mask-invert 0
setp hm2_5i25.0.encoder.02.scale [JOINT_2]ENCODER_SCALE
net z-pos-fb <= hm2_5i25.0.encoder.02.position
net z-vel-fb <= hm2_5i25.0.encoder.02.velocity
net z-pos-fb => joint.2.motor-pos-fb
net z-index-enable joint.2.index-enable <=> hm2_5i25.0.encoder.02.index-enable
net z-pos-rawcounts <= hm2_5i25.0.encoder.02.rawcounts
net both-home-z => joint.2.home-sw-in
net both-home-z => joint.2.neg-lim-sw-in
net both-home-z => joint.2.pos-lim-sw-in
# SPINDLE
setp pid.s.Pgain [SPINDLE_0]P
setp pid.s.Igain [SPINDLE_0]I
setp pid.s.Dgain [SPINDLE_0]D
setp pid.s.bias [SPINDLE_0]BIAS
setp pid.s.FF0 [SPINDLE_0]FF0
setp pid.s.FF1 [SPINDLE_0]FF1
setp pid.s.FF2 [SPINDLE_0]FF2
setp pid.s.deadband [SPINDLE_0]DEADBAND
net ratio_select.out pid.s.maxoutput
setp pid.s.error-previous-target true
net spindle-index-enable <=> pid.s.index-enable
net spindle-enable => pid.s.enable
net spindle-vel-cmd-rpm-abs => pid.s.command
net spindle-vel-fb-rpm-abs => pid.s.feedback
net spindle-pid-out pid.s.output => scale.gear.in
net gear-ratio ratio_select.out-f => scale.gear.gain
setp ratio_select.in00 0.000222
setp ratio_select.in01 0.000222
net gear-select-a => ratio_select.sel0
net spindle-output <= scale.gear.out
setp hm2_5i25.0.7i77.0.1.analogout5-scalemax [SPINDLE_0]OUTPUT_SCALE
setp hm2_5i25.0.7i77.0.1.analogout5-minlim [SPINDLE_0]OUTPUT_MIN_LIMIT
setp hm2_5i25.0.7i77.0.1.analogout5-maxlim [SPINDLE_0]OUTPUT_MAX_LIMIT
net spindle-output => hm2_5i25.0.7i77.0.1.analogout5
net spindle-enable => hm2_5i25.0.7i77.0.1.spinena
net spindle-vel-cmd-rps <= spindle.0.speed-out-rps
net spindle-vel-cmd-rps-abs <= spindle.0.speed-out-rps-abs
net spindle-vel-cmd-rpm <= spindle.0.speed-out
net spindle-vel-cmd-rpm-abs <= spindle.0.speed-out-abs
net spindle-enable <= spindle.0.on
net spindle-cw <= spindle.0.forward
net spindle-ccw <= spindle.0.reverse
net spindle-brake <= spindle.0.brake
net spindle-revs => spindle.0.revs
net spindle-vel-fb-rps => spindle.0.speed-in
net spindle-index-enable <=> spindle.0.index-enable
sets spindle-at-speed true
# connect miscellaneous signals
# ---HALUI signals---
net axis-select-x halui.axis.x.select
net jog-x-pos halui.axis.x.plus
net jog-x-neg halui.axis.x.minus
net jog-x-analog halui.axis.x.analog
net x-is-homed halui.joint.0.is-homed
net axis-select-y halui.axis.y.select
net jog-y-pos halui.axis.y.plus
net jog-y-neg halui.axis.y.minus
net jog-y-analog halui.axis.y.analog
net y-is-homed halui.joint.1.is-homed
net axis-select-z halui.axis.z.select
net jog-z-pos halui.axis.z.plus
net jog-z-neg halui.axis.z.minus
net jog-z-analog halui.axis.z.analog
net z-is-homed halui.joint.2.is-homed
net jog-selected-pos halui.axis.selected.plus
net jog-selected-neg halui.axis.selected.minus
net spindle-manual-cw halui.spindle.0.forward
net spindle-manual-ccw halui.spindle.0.reverse
net spindle-manual-stop halui.spindle.0.stop
net machine-is-on halui.machine.is-on
net jog-speed halui.axis.jog-speed
net MDI-mode halui.mode.is-mdi
# ---coolant signals---
net coolant-mist <= iocontrol.0.coolant-mist
net coolant-flood <= iocontrol.0.coolant-flood
# ---probe signal---
net probe-in => motion.probe-input
# ---motion control signals---
net in-position <= motion.in-position
net machine-is-enabled <= motion.motion-enabled
# ---digital in / out signals---
# ---estop signals---
net estop-ext => iocontrol.0.emc-enable-in
# ---manual tool change signals---
net tool-change-request iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-change-confirmed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
ini file
[EMC]
MACHINE = my_LinuxCNC_machine
DEBUG = 0
VERSION = 1.1
[DISPLAY]
DISPLAY = axis
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
MAX_SPINDLE_OVERRIDE = 1.200000
MIN_SPINDLE_OVERRIDE = 0.500000
INTRO_TIME = 5
PROGRAM_PREFIX = /home/mike/linuxcnc/nc_files
INCREMENTS = .1in .05in .01in .005in .001in .0005in .0001in
DEFAULT_LINEAR_VELOCITY = 0.500000
MAX_LINEAR_VELOCITY = 1.000000
MIN_LINEAR_VELOCITY = 0.016670
DEFAULT_ANGULAR_VELOCITY = 12.000000
MAX_ANGULAR_VELOCITY = 180.000000
MIN_ANGULAR_VELOCITY = 1.666667
EDITOR = gedit
GEOMETRY = xyz
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
SERVO_PERIOD = 1000000
[HMOT]
# **** This is for info only ****
CARD0=hm2_5i25.0
COMPONENT_ARGUMENTS = -a
[HAL]
HALUI = halui
HALFILE = my_LinuxCNC_machine.hal
HALFILE = custom.hal
HALFILE = xhc-whb04b-6.hal
POSTGUI_HALFILE = postgui_call_list.hal
SHUTDOWN = shutdown.hal
[HALUI]
[KINS]
JOINTS = 3
KINEMATICS = trivkins coordinates=XYZ
[TRAJ]
COORDINATES = XYZ
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
DEFAULT_LINEAR_VELOCITY = 0.10
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_X]
MAX_VELOCITY = 1.0
MAX_ACCELERATION = 30.0
MIN_LIMIT = -31.0
MAX_LIMIT = 0.001
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.5
MIN_FERROR = 0.05
MAX_VELOCITY = 1.0
P = 50.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 0.001
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
ENCODER_SCALE = 2540.005
OUTPUT_SCALE = -10.0
OUTPUT_MIN_LIMIT = -10.0
OUTPUT_MAX_LIMIT = 10.0
MIN_LIMIT = -31.0
MAX_LIMIT = 0.001
HOME_OFFSET = 0.000000
HOME_SEARCH_VEL = 0.116667
HOME_LATCH_VEL = -0.016667
HOME_FINAL_VEL = 0.016667
HOME_USE_INDEX = NO
HOME_IGNORE_LIMITS = YES
HOME_SEQUENCE = 1
[AXIS_Y]
MAX_VELOCITY = 1.0
MIN_LIMIT = -13.5
MAX_LIMIT = 0.001
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.5
MIN_FERROR = 0.05
MAX_VELOCITY = 1.0
P = 50.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 0.001
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
ENCODER_SCALE = -2540.005
MIN_LIMIT = -13.5
MAX_LIMIT = 0.001
HOME_USE_INDEX = NO
HOME_SEQUENCE = 2
[AXIS_Z]
MAX_VELOCITY = 1.0
MIN_LIMIT = -4.65
MAX_LIMIT = 0.001
[JOINT_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.5
MIN_FERROR = 0.05
MAX_VELOCITY = 1.0
P = 50.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 0.001
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
BACKLASH = 0.002
MIN_LIMIT = -4.65
MAX_LIMIT = 0.001
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
[SPINDLE_0]
P = 0.0
I = 0.0
D = 0.0
FF0 = 1.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 4500.0
OUTPUT_SCALE = 1
OUTPUT_MIN_LIMIT = 0
  • BeagleBrainz
  • Visitor
  • Visitor
20 Oct 2020 23:53 #186767 by BeagleBrainz
Do you have this file xhc-whb04b-6.hal ?
  • Catch22
  • Elite Member
  • Elite Member
21 Oct 2020 00:11 #186769 by Catch22
Yes I do.
loadusr -W xhc-whb04b-6 -HsfB
# pendant signal configuration
# On/Off signals
net machine.is-on halui.machine.is-on whb.halui.machine.is-on
net pdnt.machine.on whb.halui.machine.on halui.machine.on
net pdnt.machine.off whb.halui.machine.off halui.machine.off
# program related signals
net pdnt.program.is-idle whb.halui.program.is-idle halui.program.is-idle
net pdnt.program.is-paused whb.halui.program.is-paused halui.program.is-paused
net pdnt.program-is-running whb.halui.program.is-running halui.program.is-running
net pdnt.program.resume whb.halui.program.resume halui.program.resume
net pdnt.program.pause whb.halui.program.pause halui.program.pause
net pdnt.program.run whb.halui.program.run halui.program.run
net pdnt.program.stop whb.halui.program.stop halui.program.stop
# machine mode related signals
net pdnt.mode.auto whb.halui.mode.auto halui.mode.auto
net pdnt.mode.manual whb.halui.mode.manual halui.mode.manual
net pdnt.mode.mdi whb.halui.mode.mdi halui.mode.mdi
net pdnt.mode.joint whb.halui.mode.joint halui.mode.joint
net pdnt.mode.teleop whb.halui.mode.teleop halui.mode.teleop
net pdnt.mode.is-auto halui.mode.is-auto whb.halui.mode.is-auto
net pdnt.mode.is-manual halui.mode.is-manual whb.halui.mode.is-manual whb.halui.mode.is-teleop
net pdnt.mode.is-mdi halui.mode.is-mdi whb.halui.mode.is-mdi
net pdnt.mode.is-joint halui.mode.is-joint whb.halui.mode.is-joint
net pdnt.mode.is-teleop halui.mode.is-teleop # whb.halui.mode.is-teleop
# "selected axis" signals
net pdnt.axis.X.select whb.halui.axis.x.select halui.axis.x.select
net pdnt.axis.y.select whb.halui.axis.y.select halui.axis.y.select
net pdnt.axis.Z.select whb.halui.axis.z.select halui.axis.z.select
net pdnt.axis.x.jog-scale whb.axis.x.jog-scale axis.x.jog-scale
net pdnt.axis.y.jog-scale whb.axis.y.jog-scale axis.y.jog-scale
net pdnt.axis.z.jog-scale whb.axis.z.jog-scale axis.z.jog-scale
net pdnt.axis.x.jog-counts whb.axis.x.jog-counts axis.x.jog-counts
net pdnt.axis.y.jog-counts whb.axis.y.jog-counts axis.y.jog-counts
net pdnt.axis.z.jog-counts whb.axis.z.jog-counts axis.z.jog-counts
net pdnt.axis.x.jog-enable whb.axis.x.jog-enable axis.x.jog-enable
net pdnt.axis.y.jog-enable whb.axis.y.jog-enable axis.y.jog-enable
net pdnt.axis.z.jog-enable whb.axis.z.jog-enable axis.z.jog-enable
net pdnt.axis.x.jog-vel-mode whb.axis.x.jog-vel-mode axis.x.jog-vel-mode
net pdnt.axis.y.jog-vel-mode whb.axis.y.jog-vel-mode axis.y.jog-vel-mode
net pdnt.axis.z.jog-vel-mode whb.axis.z.jog-vel-mode axis.z.jog-vel-mode
# macro buttons to MDI commands
net pdnt.macro-1 whb.button.macro-1 halui.mdi-command-01 # use MDI command from main.ini
net pdnt.macro-2 whb.button.macro-2 halui.mdi-command-02 # use MDI command from main.ini or used for Hardcoded lube on/off
net pdnt.reserved.for.spindle+ whb.button.macro-3 # Hardcoded for spindle+ whb.halui.spindle.increase
net pdnt.reserved.for.spindle- whb.button.macro-4 # Hardcoded for spindle- whb.halui.spindle.decrease
net pdnt.macro-5 whb.button.macro-5 halui.mdi-command-05 # use MDI command from main.ini
net pdnt.macro-6 whb.button.macro-6 halui.mdi-command-06 # use MDI command from main.ini
net pdnt.macro-7 whb.button.macro-7 halui.mdi-command-07 # use MDI command from main.ini
net pdnt.reserved.for.spindle.dir whb.button.macro-8 # Hardcoded for spindle direction inside pendant
net pdnt.macro-9 whb.button.macro-9 halui.mdi-command-09 # use MDI command from main.ini
net pdnt.reserved.for.ABS-REL whb.button.macro-10 # Hardcoded for swap Dro Relative/Absolue
net pdnt.macro-14 whb.button.macro-14 halui.mdi-command-14 # use MDI command from main.ini
net pdnt.reserved.for.flood whb.button.macro-15 # Hardcoded for halui.flood on/off
net pdnt.reserved.for.mist whb.button.macro-16 # Hardcoded for halui.mist on/off
net pdnt.macro.11 whb.button.macro-11 halui.mdi-command-11 # use MDI command from main.ini
net pdnt.macro.12 whb.button.macro-12 halui.mdi-command-12 # use MDI command from main.ini
net pdnt.macro.13 whb.button.macro-13 halui.mdi-command-13 # use MDI command from main.ini
# flood and mist toggle signals
net pdnt.flood.is-on whb.halui.flood.is-on halui.flood.is-on #return signal is on or off
net pdnt.flood.off whb.halui.flood.off halui.flood.off #reserved whb.button.macro-15
net pdnt.flood.on whb.halui.flood.on halui.flood.on #reserved whb.button.macro-15
net pdnt.mist.is-on whb.halui.mist.is-on halui.mist.is-on #return signal is on or off
net pdnt.mist.off whb.halui.mist.off halui.mist.off #reserved whb.button.macro-16
net pdnt.mist.on whb.halui.mist.on halui.mist.on #reserved whb.button.macro-16
#net pdnt.lube.is-on whb.halui.lube.is-on halui.lube.is-on #return signal is on or off
#net pdnt.lube.off whb.halui.lube.off halui.lube.off #reserved whb.button.macro-2
#net pdnt.lube.on whb.halui.lube.on halui.lube.on #reserved whb.button.macro-2
# default function button signals
net pdnt.button.m-home whb.button.m-home halui.home-all # Homing use built-in halui home all
net pdnt.button.safe-z whb.button.safe-z halui.mdi-command-03 # Safe-z use MDI command from main.ini
net pdnt.button.w-home whb.button.w-home halui.mdi-command-04 # Unpark use MDI command from main.ini
net pdnt.button.probe-z whb.button.probe-z halui.mdi-command-08 # Probe-Z use MDI command from main.ini
# unused, just exposes pendant internal status or as basic button
#net pdnt.mode-lead whb.halui.feed.selected-lead
#net pdnt.mode-mpg-feed whb.halui.feed.selected-mpg-feed
#net pdnt.mode-continuous whb.halui.feed.selected-continuous
#net pdnt.mode-step whb.halui.feed.selected-step
#net pdnt.button.mode-mpg whb.button.mode-continuous
#net pdnt.button.mode-step whb.button.mode-step
#net pdnt.button.fn whb.button.fn
#net pdnt.button.reset whb.button.reset
#net pdnt.button.stop whb.button.stop
#net pdnt.button.start-pause whb.button.start-pause
#net pdnt.button.s-on-off whb.button.s-on-off
#net pdnt.button.spindle-plus whb.button.spindle-plus
#net pdnt.button.spindle-minus whb.button.spindle-minus
#net pdnt.button.feed-plus whb.button.feed-plus
#net pdnt.button.feed-minus whb.button.feed-minus
# spindle related signals
net pdnt.spindle.is-on whb.halui.spindle.is-on spindle.0.on
net pdnt.spindle.start whb.halui.spindle.start halui.spindle.0.start
net pdnt.spindle.stop whb.halui.spindle.stop halui.spindle.0.stop
net pdnt.spindle.forward whb.halui.spindle.forward halui.spindle.0.forward
net pdnt.spindle.reverse whb.halui.spindle.reverse halui.spindle.0.reverse
net pdnt.spindle.increase whb.halui.spindle.increase halui.spindle.0.increase # reserved whb.button.macro-3
net pdnt.spindle.decrease whb.halui.spindle.decrease halui.spindle.0.decrease # reserved whb.button.macro-4
net pdnt.spindle-speed-abs whb.halui.spindle-speed-cmd spindle.0.speed-out-abs # speed cmd from motion in rpm absolue
# spindle speed override signals
net pdnt.spindle-override.scale whb.halui.spindle-override.scale halui.spindle.0.override.scale # needed for both spindle+/- and spindleoverride+/- button
net pdnt.spindle.override.value halui.spindle.0.override.value whb.halui.spindle-override.value # GUI feed rate related signals
net pdnt.spindle.override.increase whb.halui.spindle-override.increase halui.spindle.0.override.increase
net pdnt.spindle.override.decrease whb.halui.spindle-override.decrease halui.spindle.0.override.decrease
# GUI feed rate related signals can be used when program is running moving GUI slider
net pdnt.feed-override.scale whb.halui.feed-override.scale halui.feed-override.scale # needed for both FeedOverride+/- and rotary knob button
net pdnt.max-velocity.value whb.halui.max-velocity.value halui.max-velocity.value # needed for Mpg mode : button feed position% * max-velocity = Mpg feedrate
# take feed override min/max values from/to the GUI
net pdnt.feed-override.value halui.feed-override.value whb.halui.feed-override.value # GUI feed rate related signals
net pdnt.feed-override.increase whb.halui.feed-override.increase halui.feed-override.increase
net pdnt.feed-override.decrease whb.halui.feed-override.decrease halui.feed-override.decrease
# axis position related signals feedback
net pdnt.axis.x.pos-feedback halui.axis.x.pos-feedback whb.halui.axis.x.pos-feedback
net pdnt.axis.y.pos-feedback halui.axis.y.pos-feedback whb.halui.axis.y.pos-feedback
net pdnt.axis.z.pos-feedback halui.axis.z.pos-feedback whb.halui.axis.z.pos-feedback
# axis position related signals relative
net pdnt.axis.x.pos-relative halui.axis.x.pos-relative whb.halui.axis.x.pos-relative
net pdnt.axis.y.pos-relative halui.axis.y.pos-relative whb.halui.axis.y.pos-relative
net pdnt.axis.z.pos-relative halui.axis.z.pos-relative whb.halui.axis.z.pos-relative
  • BeagleBrainz
  • Visitor
  • Visitor
21 Oct 2020 00:27 - 21 Oct 2020 00:34 #186771 by BeagleBrainz
Looking through the error log this seems to be the culprit:
Is this file in the same folder as your machine config ?
Last edit: 21 Oct 2020 00:34 by BeagleBrainz.
  • Catch22
  • Elite Member
  • Elite Member
21 Oct 2020 00:57 #186775 by Catch22
Yes that folder is in with the ini and Hal and custom Hal and a few other files.
And it's named xhc-whb04b-6
  • BeagleBrainz
  • Visitor
  • Visitor
21 Oct 2020 01:45 - 21 Oct 2020 01:46 #186778 by BeagleBrainz
The HAL file for the whb has to match the file name in for ini file.
In your ini file.
[HAL]
HALUI = halui
If the file is named in your config directory xhc-whb04b-6.hal you will not get the can not find file error.
If the file is named in your config directoryxhc-whb04b-6 you will get the can not find file error.
Also the name should be a match regarding case as well.
Last edit: 21 Oct 2020 01:46 by BeagleBrainz.
