whb not showing up?
- BeagleBrainz
- Visitor
21 Oct 2020 22:28 #186851
by BeagleBrainz
Replied by BeagleBrainz on topic whb not showing up?
can you try this
And report the output
halcmd -f
loadusr -W xhc-whb04b-6 -HsfB
show pin
unload xhc-whb04b-6
quitAnd report the output
- Catch22
- Thank you received: 17
21 Oct 2020 22:49 #186852
by Catch22
Replied by Catch22 on topic whb not showing up?
mike@cnc:~$ halcmd -f
halcmd: loadusr -w xhc-whb04b-6 -HsfB
HAL: ERROR: duplicate component name 'xhc-whb04b-6'
failed to initialize HAL component xhc-whb04b-6
<stdin>:1: program 'xhc-whb04b-6' failed, returned 1
mike@cnc:~$
mike@cnc:~$
- Catch22
21 Oct 2020 22:51 #186853
by Catch22
halcmd: show pin
Component Pins:
Owner Type Dir Value Name
4 s32 OUT 0 whb.axis.a.jog-counts
4 bit OUT FALSE whb.axis.a.jog-enable
4 float OUT 0 whb.axis.a.jog-scale
4 bit OUT FALSE whb.axis.a.jog-vel-mode
4 s32 OUT 0 whb.axis.b.jog-counts
4 bit OUT FALSE whb.axis.b.jog-enable
4 float OUT 0 whb.axis.b.jog-scale
4 bit OUT FALSE whb.axis.b.jog-vel-mode
4 s32 OUT 0 whb.axis.c.jog-counts
4 bit OUT FALSE whb.axis.c.jog-enable
4 float OUT 0 whb.axis.c.jog-scale
4 bit OUT FALSE whb.axis.c.jog-vel-mode
4 s32 OUT 0 whb.axis.x.jog-counts
4 bit OUT FALSE whb.axis.x.jog-enable
4 float OUT 0 whb.axis.x.jog-scale
4 bit OUT FALSE whb.axis.x.jog-vel-mode
4 s32 OUT 0 whb.axis.y.jog-counts
4 bit OUT FALSE whb.axis.y.jog-enable
4 float OUT 0 whb.axis.y.jog-scale
4 bit OUT FALSE whb.axis.y.jog-vel-mode
4 s32 OUT 0 whb.axis.z.jog-counts
4 bit OUT FALSE whb.axis.z.jog-enable
4 float OUT 0 whb.axis.z.jog-scale
4 bit OUT FALSE whb.axis.z.jog-vel-mode
4 bit OUT FALSE whb.button.feed-minus
4 bit OUT FALSE whb.button.feed-plus
4 bit OUT FALSE whb.button.fn
4 bit OUT FALSE whb.button.m-home
4 bit OUT FALSE whb.button.macro-1
4 bit OUT FALSE whb.button.macro-10
4 bit OUT FALSE whb.button.macro-11
4 bit OUT FALSE whb.button.macro-12
4 bit OUT FALSE whb.button.macro-13
4 bit OUT FALSE whb.button.macro-14
4 bit OUT FALSE whb.button.macro-15
4 bit OUT FALSE whb.button.macro-16
4 bit OUT FALSE whb.button.macro-2
4 bit OUT FALSE whb.button.macro-3
4 bit OUT FALSE whb.button.macro-4
4 bit OUT FALSE whb.button.macro-5
4 bit OUT FALSE whb.button.macro-6
4 bit OUT FALSE whb.button.macro-7
4 bit OUT FALSE whb.button.macro-8
4 bit OUT FALSE whb.button.macro-9
4 bit OUT FALSE whb.button.mode-continuous
4 bit OUT FALSE whb.button.mode-step
4 bit OUT FALSE whb.button.probe-z
4 bit OUT FALSE whb.button.reset
4 bit OUT FALSE whb.button.s-on-off
4 bit OUT FALSE whb.button.safe-z
4 bit OUT FALSE whb.button.spindle-minus
4 bit OUT FALSE whb.button.spindle-plus
4 bit OUT FALSE whb.button.start-pause
4 bit OUT FALSE whb.button.stop
4 bit OUT FALSE whb.button.w-home
4 float IN 0 whb.halui.axis.a.pos-feedback
4 float IN 0 whb.halui.axis.a.pos-relative
4 bit OUT FALSE whb.halui.axis.a.select
4 float IN 0 whb.halui.axis.b.pos-feedback
4 float IN 0 whb.halui.axis.b.pos-relative
4 bit OUT FALSE whb.halui.axis.b.select
4 float IN 0 whb.halui.axis.c.pos-feedback
4 float IN 0 whb.halui.axis.c.pos-relative
4 bit OUT FALSE whb.halui.axis.c.select
4 float IN 0 whb.halui.axis.x.pos-feedback
4 float IN 0 whb.halui.axis.x.pos-relative
4 bit OUT FALSE whb.halui.axis.x.select
4 float IN 0 whb.halui.axis.y.pos-feedback
4 float IN 0 whb.halui.axis.y.pos-relative
4 bit OUT FALSE whb.halui.axis.y.select
4 float IN 0 whb.halui.axis.z.pos-feedback
4 float IN 0 whb.halui.axis.z.pos-relative
4 bit OUT FALSE whb.halui.axis.z.select
4 bit OUT FALSE whb.halui.feed-override.decrease
4 bit OUT FALSE whb.halui.feed-override.increase
4 float OUT 0 whb.halui.feed-override.scale
4 float IN 0 whb.halui.feed-override.value
4 bit OUT FALSE whb.halui.feed.selected-10
4 bit OUT FALSE whb.halui.feed.selected-100
4 bit OUT FALSE whb.halui.feed.selected-2
4 bit OUT FALSE whb.halui.feed.selected-30
4 bit OUT FALSE whb.halui.feed.selected-5
4 bit OUT FALSE whb.halui.feed.selected-60
4 bit OUT FALSE whb.halui.feed.selected-continuous
4 bit OUT FALSE whb.halui.feed.selected-lead
4 bit OUT FALSE whb.halui.feed.selected-mpg-feed
4 bit OUT FALSE whb.halui.feed.selected-step
4 bit IN FALSE whb.halui.flood.is-on
4 bit OUT FALSE whb.halui.flood.off
4 bit OUT FALSE whb.halui.flood.on
4 bit IN FALSE whb.halui.lube.is-on
4 bit OUT FALSE whb.halui.lube.off
4 bit OUT FALSE whb.halui.lube.on
4 bit IN FALSE whb.halui.machine.is-on
4 bit OUT FALSE whb.halui.machine.off
4 bit OUT FALSE whb.halui.machine.on
4 float IN 0 whb.halui.max-velocity.value
4 bit IN FALSE whb.halui.mist.is-on
4 bit OUT FALSE whb.halui.mist.off
4 bit OUT FALSE whb.halui.mist.on
4 bit OUT FALSE whb.halui.mode.auto
4 bit IN FALSE whb.halui.mode.is-auto
4 bit IN FALSE whb.halui.mode.is-joint
4 bit IN FALSE whb.halui.mode.is-manual
4 bit IN FALSE whb.halui.mode.is-mdi
4 bit IN FALSE whb.halui.mode.is-teleop
4 bit OUT FALSE whb.halui.mode.joint
4 bit OUT FALSE whb.halui.mode.manual
4 bit OUT FALSE whb.halui.mode.mdi
4 bit OUT FALSE whb.halui.mode.teleop
4 bit IN FALSE whb.halui.program.is-idle
4 bit IN FALSE whb.halui.program.is-paused
4 bit IN FALSE whb.halui.program.is-running
4 bit OUT FALSE whb.halui.program.pause
4 bit OUT FALSE whb.halui.program.resume
4 bit OUT FALSE whb.halui.program.run
4 bit OUT FALSE whb.halui.program.stop
4 bit OUT FALSE whb.halui.spindle-override.decrease
4 bit OUT FALSE whb.halui.spindle-override.increase
4 float OUT 0 whb.halui.spindle-override.scale
4 float IN 0 whb.halui.spindle-override.value
4 float IN 0 whb.halui.spindle-speed-cmd
4 bit OUT FALSE whb.halui.spindle.decrease
4 bit OUT FALSE whb.halui.spindle.forward
4 bit OUT FALSE whb.halui.spindle.increase
4 bit IN FALSE whb.halui.spindle.is-on
4 bit OUT FALSE whb.halui.spindle.reverse
4 bit OUT FALSE whb.halui.spindle.start
4 bit OUT FALSE whb.halui.spindle.stop
4 bit OUT TRUE whb.pendant.is-connected
4 bit OUT FALSE whb.pendant.is-sleeping
halcmd:
halcmd: show pin
Component Pins:
halcmd:
- Catch22
21 Oct 2020 22:53 #186854
by Catch22
halcmd: unload xhc-whb04b-6
<stdin>:1: component 'xhc-whb04b-6' is not loaded
mike@cnc:~$ quit
Command 'quit' not found, did you mean:
command 'luit' from deb x11-utils
command 'quilt' from deb quilt
command 'quiz' from deb bsdgames
command 'qgit' from deb qgit
command 'quot' from deb quota
Try: sudo apt install <deb name>
mike@cnc:~$
mike@cnc:~$ quit
mike@cnc:~$
- BeagleBrainz
- Visitor
21 Oct 2020 22:59 #186855
by BeagleBrainz
Did you have Linuxcnc running whilst trying this ?
- Catch22
21 Oct 2020 23:20 #186856
by Catch22
No I didn't, it won't run unless I delete the HALFILE xhc-whb04b-6.hal
Should I delete that and have Linuxcnc running and run those commands again?
- BeagleBrainz
- Visitor
22 Oct 2020 00:22 #186858
by BeagleBrainz
No.
Actually reboot and run those commands again.
But type them in one at a time rather than copy & paste them all at once.
- Catch22
22 Oct 2020 00:58 #186859
by Catch22
halcmd: loadusr -W xhc-whb04b-6 -HsfB
halcmd: show pin
Component Pins:
halcmd: quit
mike@cnc:~$
halcmd: show pin
Component Pins:
halcmd: quit
mike@cnc:~$
- BeagleBrainz
- Visitor
22 Oct 2020 01:23 - 22 Oct 2020 01:23 #186862
by BeagleBrainz
Ok it would appear that the user comp is loading.
Now rename xhc-whb04b-6.hal to MyPendant.hal and change the entry in your /home/mike/linuxcnc/configs/my_LinuxCNC_machine/my_LinuxCNC_machine.ini from xhc-whb04b-6.hal to MyPendant.hal
Reboot and try to start Linuxcnc.
Last edit: 22 Oct 2020 01:23 by BeagleBrainz.
- Catch22
22 Oct 2020 01:43 #186866
by Catch22
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.0~pre1
Machine configuration directory is '/home/mike/linuxcnc/configs/my_LinuxCNC_machine'
Machine configuration file is 'my_LinuxCNC_machine.ini'
INIFILE=/home/mike/linuxcnc/configs/my_LinuxCNC_machine/my_LinuxCNC_machine.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=XYZ
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./my_LinuxCNC_machine.hal
Running HAL shutdown script
hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
hm2_pci: discovered 5i25 at 0000:04:00.0
hm2/hm2_5i25.0: Smart Serial Firmware Version 43
Board hm2_5i25.0.7i77.0.0 Hardware Mode 0 = standard
Board hm2_5i25.0.7i77.0.0 Software Mode 0 = input_output
Board hm2_5i25.0.7i77.0.0 Software Mode 1 = io_analog
Board hm2_5i25.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage
Board hm2_5i25.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage
Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
hm2/hm2_5i25.0: 34 I/O Pins used:
hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData0 (Output)
hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData0 (Input)
hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
hm2/hm2_5i25.0: registered
hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
hm2/hm2_5i25.0: unregistered
hm2_pci: driver unloaded
hm2: unloading
Debug file information:
Note: Using POSIX realtime
./my_LinuxCNC_machine.hal:329: Pin 'halui.machine.is-on' was already linked to signal 'machine-is-on'
1949
Stopping realtime threads
Unloading hal components
RTAPI_PCI: Unmapped 65536 bytes at 0x7f87f0ad5000
Info report created by linuxcnc_info:
The file: /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
pastebin.com
in order to provide information about the linuxcnc
system and configuration.
Date: Wed Oct 21 21:42:23 EDT 2020
UTC Date: Thu Oct 22 01:42:23 UTC 2020
this program: /usr/bin/linuxcnc_info
uptime: 21:42:23 up 3 min, 1 user, load average: 1.95, 1.43, 0.59
lsb_release -sa: LinuxMint Linuxcnc Uspace Powered by Linux Mint 19.2 Tina 19.2 tina
which linuxcnc: /usr/bin/linuxcnc
pwd: /home/mike/linuxcnc/configs/my_LinuxCNC_machine
USER: mike
LOGNAME: mike
HOME: /home/mike
EDITOR:
VISUAL:
LANGUAGE: en_CA:en
TERM: dumb
COLORTERM:
DISPLAY: :0
DESKTOP: mate
display size: 1920x1080 pixels (508x285 millimeters)
PATH: /usr/bin:/home/mike/linuxcnc/configs/my_LinuxCNC_machine/bin:/usr/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games
uname items:
nodename -n: cnc
kernel-name -s: Linux
kernel-vers -v: #1 SMP PREEMPT RT Thu Mar 5 00:02:34 AEDT 2020
machine -m: x86_64
processor -p: x86_64
platform -i: x86_64
oper system -o: GNU/Linux
/proc items:
cmdline: BOOT_IMAGE=/boot/vmlinuz-4.19.106-rt44-lcnc root=UUID=dc295af9-e1cf-45c8-a78c-4ecf9396287e ro quiet splash vt.handoff=1
model name: Intel(R) Core(TM)2 CPU 6400 @ 2.13GHz
cores: 2
cpu MHz: 2020.036
parport: 0000-0000 : parport0 0000-0000 : parport0 0000-0000 : parport0
serial: 0000-0000 : serial
Versions:
gcc: gcc (Ubuntu 7.5.0-3ubuntu1~18.04) 7.5.0
python: Python 2.7.17
git: git version 2.17.1
git commit: NA
tcl: 8.6
tk: 8.6
glade: not_in_PATH
glade-gtk2: not_in_PATH
linuxcnc_var all:
LINUXCNCVERSION: 2.8.0~pre1
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
REALTIME: /etc/init.d/realtime
RTS: uspace
HALLIB_DIR: /usr/share/linuxcnc/hallib
dpkg -l '*linuxcnc*':
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
un linuxcnc <none> <none> (no description available)
un linuxcnc-dev <none> <none> (no description available)
un linuxcnc-doc <none> <none> (no description available)
ii linuxcnc-doc-en 1:2.8.0~pre1.5904.gf7b17e195 all motion controller for CNC machines and robots (English documentation)
un linuxcnc-sim <none> <none> (no description available)
un linuxcnc-sim-dev <none> <none> (no description available)
ii linuxcnc-uspace 1:2.8.0~pre1.5904.gf7b17e195 amd64 motion controller for CNC machines and robots
ii linuxcnc-uspace-dev 1:2.8.0~pre1.5904.gf7b17e195 amd64 PC based motion controller for real-time Linux
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
VERSION=1.1
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=XYZ
hm2: unloading
1949
pastebin.com
USER: mike
LOGNAME: mike
HOME: /home/mike
EDITOR:
VISUAL:
LANGUAGE: en_CA:en
TERM: dumb
COLORTERM:
DISPLAY: :0
DESKTOP: mate
uname items:
nodename -n: cnc
machine -m: x86_64
platform -i: x86_64
/proc items:
cores: 2
cpu MHz: 2020.036
Versions:
git commit: NA
tcl: 8.6
tk: 8.6
glade: not_in_PATH
linuxcnc_var all:
RTS: uspace
Time to create page: 0.092 seconds
