Set the home pos.
08 Dec 2020 11:26 #191411 by Rørbæk
Replied by Rørbæk on topic Set the home pos.
No connection to the controller.
I will work on it a little later
08 Dec 2020 13:33 #191417 by Rørbæk
Here is the fail read.
  • Moderator
  • Moderator
08 Dec 2020 14:30 #191420 by tommylight
Replied by tommylight on topic Set the home pos.
Lower case L.
Never mind that, just type linuxcnc and a menu will pop up, chose your config and click OK.
08 Dec 2020 16:04 #191428 by Rørbæk
Sorry but i am not sure that i understand youre comment. I am now give you the files and the failreply i get if that can be of any help.
I tryed the hh-mill and thats the same i cant move any axis from the keybord.
  • Moderator
  • Moderator
08 Dec 2020 16:16 #191430 by tommylight
in a terminal:
linuxcnc -L <<<<lower case L, not 1
OR just
linucnc
That will open a menu where you can choose the configuration, usually the last used one is selected so just click on OK.
08 Dec 2020 16:40 #191432 by Aciera
Replied by Aciera on topic Set the home pos.
Point is you haven't been able to start linuxcnc in the terminal because you have not used the command correctly you typed linuxcnc -1 (number one) instead of linuxcnc -l (lowercase letter L) so you get an error about that. We need the text output AFTER you start Linuxcnc. So maybe try the command again with the lowercase L or as, Thommy suggested:
linuxcnc
and then choose your configuration from the menu.
09 Dec 2020 09:41 #191483 by Rørbæk
Ok now i got it, thanks
09 Dec 2020 12:24 #191491 by Rørbæk
Hurra now its running.
then i was homing it, i tryed to stop it with the microswitch but it didnt stop but i got following mess.
" end of move in home state 7 " but it continued so i stopped it with the e stop. there are also a red plus.
09 Dec 2020 13:31 - 09 Dec 2020 13:36 #191493 by Aciera
Which axis, the Z axis I presume? Was it moving upwards?
If you mean a window with a red X then we also need to know what the message is.
Generally you need to provide more information. It's better to describe to much than too little.
[edit]
Just noticed you have these lines commented out at the end of your hal:
# net both-home-x  => joint.0.pos-lim-sw-in joint.0.neg-lim-sw-in joint.0.home-sw-in
# net both-home-y  => joint.1.pos-lim-sw-in joint.1.neg-lim-sw-in joint.1.home-sw-in
# net both-home-z  => joint.2.pos-lim-sw-in joint.2.neg-lim-sw-in joint.2.home-sw-in
that is blocking the signals from the micro switches getting to LinuxCNC. So remove the # at the beginning of those three lines.
Last edit: 09 Dec 2020 13:36 by Aciera.
09 Dec 2020 16:17 #191502 by Rørbæk
I am sorry that am writting so short it takes me quith a while to writhe
The box with the red cirkel with a withe x in is saying " end of move in home state 7 "
putting # in front of the 3 last lines was because you told to me about moving 3 lines out and i cuold not find out which one to move and the tre last lines was the one which came closets
So there is tre lines i have to remove and let the last ones work again is that i have to do.
Henrik
PS i took me about half an hour to make this input.
Time to create page: 0.231 seconds
