Set the home pos.
09 Dec 2020 18:39 - 09 Dec 2020 18:39 #191514 by Aciera
Replied by Aciera on topic Set the home pos.
So there is tre lines i have to remove and let the last ones work again is that i have to do.
Don't remove any lines. You need to change the three last lines in your hal from this:
# net both-home-x  => joint.0.pos-lim-sw-in joint.0.neg-lim-sw-in joint.0.home-sw-in
# net both-home-y  => joint.1.pos-lim-sw-in joint.1.neg-lim-sw-in joint.1.home-sw-in
# net both-home-z  => joint.2.pos-lim-sw-in joint.2.neg-lim-sw-in joint.2.home-sw-in
To this:
by removing the # at the beginning of the lines.
Last edit: 09 Dec 2020 18:39 by Aciera.
09 Dec 2020 19:01 #191519 by Rørbæk
Replied by Rørbæk on topic Set the home pos.
Yes but then i get a fail message.
I have tryed to moved to a usb stick so you could see it but whit no luck
09 Dec 2020 19:09 #191520 by Aciera
Try taking a screen shot. Lots of options in Linux:
PrtSc – Save a screenshot of the entire screen to the “Pictures” directory.
Shift + PrtSc – Save a screenshot of a specific region to Pictures.
Alt + PrtSc  – Save a screenshot of the current window to Pictures.
Ctrl + PrtSc – Copy the screenshot of the entire screen to the clipboard.
Shift + Ctrl + PrtSc – Copy the screenshot of a specific region to the clipboard.
Ctrl + Alt + PrtSc – Copy the screenshot of the current window to the clipboard.
09 Dec 2020 20:24 #191528 by Rørbæk
OK that will first thing in the morning it late evening now here where i am see in the morning.
10 Dec 2020 11:26 #191576 by Rørbæk
Morning.
I have removed the "Garden fence " on the tre lines.
Trying to take print scren no reaktion from the CPU.
When starting the mashine ( not the program ) i get joint 0 on limit switch error on joint 0, 1, 2..
I am att. the current files.
10 Dec 2020 13:08 #191578 by Aciera
Ok, let's try and invert the signal from the microswitches.
In your HAL file, near the end, change this:
net both-home-x  <= parport.0.pin-13-in
net both-home-y  <= parport.0.pin-12-in
net both-home-z  <= parport.0.pin-15-in
To this:
net both-home-x  <= parport.0.pin-13-in-not
net both-home-y  <= parport.0.pin-12-in-not
net both-home-z  <= parport.0.pin-15-in-not
10 Dec 2020 17:21 #191589 by Rørbæk
Thanks that solved that problem.
I started the cnc mashine that worked.
I started the homing proces and the Y axis stated moving, then i tryed to stop it with the mocroswitch, it didnt stopped but i got a red dot with a white X in it
and the message "end of move in home state 7"
Henrik
10 Dec 2020 17:23 #191590 by Rørbæk
I will be away for an our dinnertime
10 Dec 2020 17:34 #191591 by Aciera
Your Z axis should be the first to home.
10 Dec 2020 17:39 #191592 by Rørbæk
Can that be fixed by just switching wires.
The first time a week a go before microswitches homing started with the Z axis.
Time to create page: 0.313 seconds
