mesa 7i96 connection refused
5 years 6 months ago - 5 years 6 months ago #206451 by bevins
Replied by bevins on topic mesa 7i96 connection refused
Aaron3309 wrote: After doing
sudo ifdown -a
sudo ifup -a
ip a
i get
2: enp3s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether f0:4d:a2:fe:86:3e brd ff:ff:ff:ff:ff:ff
inet 10.10.10.100/24 brd 10.10.10.255 scope global enp3s0
valid_lft forever preferred_lft forever
inet6 fe80::f24d:a2ff:fefe:863e/64 scope link
now my error when opening the machine changes to resource temporarily unavailable and then ip a returns the old ip
I don't know what else to do i've been working on this for close to 20 straight hours, i am self employed and this machine is the heart of my business.
So if you run now while it is not working:
sudo ifdown -a
sudo ifup -a
does ip -a show the correct ip?
Last edit: 5 years 6 months ago by bevins.
5 years 6 months ago #206453 by bevins
Does your /etc/network/interfaces still have the edits you did?
5 years 6 months ago #206455 by Aaron3309
yes it still has the edits, the only way they will show in the ip a is when i do
sudo ifdown -a
sudo ifup -a
immediately before.
in order to try and connect to the mesa card i have to click the Wicd network manager in the top right corner, click wired network, add and enter the ip address of the card. it gives me no options to set the host ip that i can find.
i was able to restart the computer and the ip stayed until i clicked connect to the wired network
5 years 6 months ago - 5 years 6 months ago #206456 by PCW
Replied by PCW on topic mesa 7i96 connection refused
As I mentioned, please delete the WICD connection
You should not have to click anything (and if WICD has the
IP address set to 10.10.10.10 you are simple breaking the configuration
every time you click)
Last edit: 5 years 6 months ago by PCW.
5 years 6 months ago #206459 by Aaron3309
should i just restart with a new install of linuc cnc?
on the downloads page of linucx cnc i see:
LinuxCNC 2.8.0 Debian 10 Buster PREEMPT-RT ISO
LinuxCNC 2.8.0 Debian 7 Wheezy RTAI
LinuxCNC 2.8.0 Debian 10 Buster RTAI
is there one of these that would be best/ least problems. i dont need experimental features or anything just something stable that will run my plasma
5 years 6 months ago #206460 by Aaron3309
i deleted it, made sure the ip address was correct in ip a and it will not connect, it shows no wired connections in Wicd
Time to create page: 0.614 seconds
