mesa 7i96 connection refused
5 years 6 months ago #206477 by Aaron3309
i have tried it with both the 192.168.1.121 and the 10.10.10.10. I am the only person who has ever used this so i dont know how it could have been changed. it worked fine on my previous computer. i turned off ivp 6 i think but the freaking ip address still changes, after running ifup -a ifdown-a it sows the correct number but if i do anything at all even just ping any ip or try to open my machine it reverts to this
2: enp3s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether f0:4d:a2:fe:86:3e brd ff:ff:ff:ff:ff:ff
5 years 6 months ago #206478 by PCW
Replied by PCW on topic mesa 7i96 connection refused
What happens if you setup a static IP address of 10.10.10.100 in wicd?
I still get the impression the wicd is messing with things
Replacing wicd with netmanager might also help (since netmanager
respects interfaces file settings)
5 years 6 months ago #206479 by Aaron3309
When i do that it shows in the ip a command as 10.10.10.100/8 but when i try to open my machine it says network unreachable
5 years 6 months ago #206480 by PCW
If you get "network unreachable" and" ip a" shows that the static
address is right and the link is "UP" this means is still a network configuration error on the host. Not sure what.
At this point I would probably remove wicd and install netmanager
5 years 6 months ago #206494 by Aaron3309
So i tried removing wcid and using netmanager and similar results. I managed to find the flash drive with the EXACT same linux debian wheezy iso that worked on my previous computer, i put it on the new pc, i used a backup of my machine configuration that is EXACTLY the same that worked on my previous computer and i get and error that resource is not available. with this new installation i no longer have the ip address issues but i cannot ping the card in the 192.168.1.121 setting or the 10.10.10.10 it says no response . is it possible that the ethernet on my mesa 7i96 is not working if its that i will gladly buy another card and be done with all this.
  • BeagleBrainz
  • New Member
  • New Member
5 years 6 months ago #206520 by BeagleBrainz
Replied by BeagleBrainz on topic mesa 7i96 connection refused
Have you checked your cable ?
Time to create page: 0.538 seconds
