Building new Full Qt c/c++ HMI (incl. nml and EtherCAT )
23 Aug 2021 14:54 - 23 Aug 2021 15:00 #218541 by Grotius
I found the error. It has been solved by adding :
INCLUDEPATH += /usr/include/tirpc
LIBS+= -L/usr/include/tirpc -ltirpc
This is the same error Reinhard has been searching for.
I updated the .pro file for your new install :
github.com/grotius-cnc/Qt-Lcnc/blob/main/Qt_LLX_Symbols.pro
Now got your app running in full screen mode. Had to press "cntrl + F2" to switch tty.
Last edit: 23 Aug 2021 15:00 by Grotius.
23 Aug 2021 15:43 #218548 by Grotius
23 Aug 2021 20:44 #218570 by cmorley
Hi Chris,
Using Qt properties is no problem.
What kind of Qt properties are on the wishlist?
With that info we can determine it's complexity.
Thanks for responding. I looked at the python widget and made this list for discussion.
Not all are strictly need for display but the current version does these things (plus a couple more that are not that important now) I think the (mostly) made up names are descriptive enough.
I don't wish to steal this thread so could make a new topic if you wish to discuss further.
PROPERTIES
    BackgroundColor
        DROInlayBackgroundColor
SIGNALS
    GcodeProperties
    GcodeErrors
    CurrentSelectedLine
    LoadingProgress
SLOTS
    setView
    LoadProgram
    HiglightGraphicsLine
    setGraphicsView
    Clear
    zoom
    pan
    rotate
    setAlphaMode
    setShowDro
    SetDROUnits
    feedPlotColors
         RapidPlotColors
Thanks Chris
24 Aug 2021 04:41 #218602 by Grotius
Yes make a new topic.
24 Aug 2021 05:23 #218609 by udoS
Hi Grotius
had a hell of a night. Linux-Pro
The manual install 2nd row didn't work out to install. No luck wit ANY PW.
The second install 1st row AUTO installed. Didn't ask me where to and grabt the whole dis killing 3 partitions. Let's leave it at that.
I have a new install of your RTOS now running pulled my own repo and I'm OK. Qt-Lcnc starts from qtcreator just fine.
And Yes Lcnc axis must start first.
/usr/bin/ld: /opt/linuxcnc/lib/libnml.so: undefined reference to `xdr_float'
/usr/bin/ld: /opt/linuxcnc/lib/libnml.so: undefined reference to `xdr_double'
nop. haven't seen those before.
In the vid I have seen you don't get the DTG's. You took them out or  ?
24 Aug 2021 06:04 - 24 Aug 2021 06:07 #218614 by Grotius
It was worth it.
Normally you would not see that error. In the lcnc ./configure it is searching for /xdr.
Reinhard has had a hard time finding this error, and he did not tell us the solution in his topic.
But now we know it's out there.
In the vid I have seen you don't get the DTG's. You took them out or?
They are present, but not implemented to show in any label.
Last edit: 24 Aug 2021 06:07 by Grotius.
24 Aug 2021 06:07 #218615 by Grotius
On your github channel there is a request to add some code with includepath's etc.
24 Aug 2021 06:22 - 24 Aug 2021 06:24 #218616 by udoS
so what do I do?  git = ggrrrrrrrr
now my qt project is a Master ?????? How do I get rid of that ?
Last edit: 24 Aug 2021 06:24 by udoS.
24 Aug 2021 06:41 #218617 by Grotius
I think that's no problem.
If you look at "pull requests", you can try to add these.
And you can give me write permissions to the repository if you want.
24 Aug 2021 06:57 #218618 by udoS
How do I do that ?
Time to create page: 0.284 seconds
