Debian 11 Bullseye segfaults QTPlasmac
- bevins
- Thank you received: 338
13 Nov 2021 23:50 #226393
by bevins
Debian 11 Bullseye segfaults QTPlasmac was created by bevins
When shutting down sim QTPlasmac, I am getting segfaults. Found them in dmesg. And the console says Linuxcnc shutting down with errors.
2021-11-13 18:46:22,725 - QTvcp - INFO - Logging to "/home/fab1/qtvcp.log"
2021-11-13 18:46:22,764 - QTvcp.QTVCP.QT_ISTAT - WARNING - INI Parsing Error, No PROGRAM_PREFIX Entry in DISPLAY, Using: ~/linuxcnc/nc_files
2021-11-13 18:46:22,766 - QTvcp.QTVCP.QT_ISTAT - WARNING - INI Parsing Error, No MIN_LINEAR_VELOCITY Entry in DISPLAY, Using: 1
2021-11-13 18:46:23,171 - QTvcp.QTVCP.QT_PSTAT - INFO - Using DEFAULT handler file path: /usr/share/qtvcp/panels/qtplasmac_sim/qtplasmac_sim_handler.py
2021-11-13 18:46:23,171 - QTvcp.QTVCP.QT_PSTAT - INFO - Using DEFAULT ui file from /usr/share/qtvcp/panels/qtplasmac_sim/qtplasmac_sim.ui
2021-11-13 18:46:23,171 - QTvcp.QTVCP.QT_PSTAT - INFO - Using LOCAL qss file from /home/fab1/linuxcnc/configs/by_machine.qtplasmac/qtplasmac_sim.qss
2021-11-13 18:46:23,171 - QTvcp.QTVCP.QT_PSTAT - INFO - No qrc file found
2021-11-13 18:46:23,171 - QTvcp.QTVCP.QT_PSTAT - INFO - No resources.py file found, No QRC file to compile one from.
2021-11-13 18:46:23,172 - QTvcp.QTVCP.QT_PSTAT - INFO - Using no translations. Default system locale is: en
2021-11-13 18:46:23,172 - QTvcp - INFO - Building A VCP Panel with Python 3
2021-11-13 18:46:23,172 - QTvcp - INFO - No handler file specified - using /usr/share/qtvcp/panels/qtplasmac_sim/qtplasmac_sim_handler.py
2021-11-13 18:46:23,173 - QTvcp - INFO - No HAL component base name specified - using: qtplasmac_sim
2021-11-13 18:46:23,173 - QTvcp.QTVCP.QT_MAKEGUI - INFO - Qsettings file path: /home/fab1/.config/QtVcp/qtplasmac_sim.conf
2021-11-13 18:46:23,179 - QTvcp.QTVCP.QT_MAKEGUI - INFO - No resource file to load: None
2021-11-13 18:46:23,260 - QTvcp - INFO - Preference path: /home/fab1/linuxcnc/configs/by_machine.qtplasmac/qtplasmac.prefs
2021-11-13 18:46:23,262 - QTvcp.QTVCP.QT_MAKEPINS - INFO - No preference file - can not set preference geometry.
2021-11-13 18:46:23,276 - QTvcp - INFO - Preference path: NonePlease Log in or Create an account to join the conversation.
- bevins
13 Nov 2021 23:53 - 13 Nov 2021 23:54 #226394
by bevins
Replied by bevins on topic Debian 11 Bullseye segfaults QTPlasmac
Definately a qtvcp and/or QTPlasmaC issue when running the sim. I havent tested with mesa cards yet. There is a 5i25 in the box and will connect a 7i76 to it next and check not running the sim.
dmesg shows the segfaults.
/EDIT axis runs fine with no errors.
Last edit: 13 Nov 2021 23:54 by bevins.
- phillc54
- Thank you received: 2100
14 Nov 2021 02:49 #226404
by phillc54
Replied by phillc54 on topic Debian 11 Bullseye segfaults QTPlasmac
Possibly a pyqt5 error in python3.9, it works fine with python3.7
forum.linuxcnc.org/plasmac/43880-qtplasm...ntation-fault#226178
- bevins
14 Nov 2021 02:58 #226405
by bevins
yeah well, can't really put this on a customers machine. seg faulting everytime shutdown linuxcnc
- phillc54
14 Nov 2021 03:00 #226406
by phillc54
Try the LinuxCNC Buster ISO or MX-Linux-19.4
- bevins
14 Nov 2021 03:09 #226407
by bevins
Can I get the QTPlasmac updates with these?Try the LinuxCNC Buster ISO or MX-Linux-19.4
- phillc54
14 Nov 2021 03:14 #226408
by phillc54
Yep, we build QtPlasmaC on MX19.4 which is a Debian Buster spinoff.
I update my table from the Buildbot.
- bevins
14 Nov 2021 03:26 #226409
by bevins
ok cool.... I'm on it. Is the buildbot page updated with the correct key fingerprint?Yep, we build QtPlasmaC on MX19.4 which is a Debian Buster spinoff.
- phillc54
14 Nov 2021 03:30 #226410
by phillc54
Not as far as I know, just use the keyserver named keyserver.ubuntu.com instead of the one on the Buildbot page.
- bevins
14 Nov 2021 03:42 #226411
by bevins
Buster is linuxcnc 2.8. Got to go to master to get your updates?Not as far as I know, just use the keyserver named keyserver.ubuntu.com instead of the one on the Buildbot page.
Time to create page: 0.107 seconds
