Debian 11 Bullseye segfaults QTPlasmac
- bevins
- Thank you received: 338
14 Nov 2021 03:55 #226412
by bevins
Replied by bevins on topic Debian 11 Bullseye segfaults QTPlasmac
Up and running linuxcnc in 17 minutes. That's a record for me.
Usually compiling kernels, compiling linuxcnc, this that the other, usually takes hours.
- phillc54
- Thank you received: 2100
14 Nov 2021 03:55 #226413
by phillc54
Replied by phillc54 on topic Debian 11 Bullseye segfaults QTPlasmac
Set these as your repositories in Synaptic:
deb http://buildbot.linuxcnc.org/ buster master-rtpreempt
deb-src http://buildbot.linuxcnc.org/ buster master-rtpreemptPlease Log in or Create an account to join the conversation.
- phillc54
14 Nov 2021 03:57 #226414
by phillc54
Haha, it seems I was too late.
Once you get the hang of it then it i pretty quick.
- Thank you received: 4145
14 Nov 2021 04:16 #226417
Replied by rodw on topic Debian 11 Bullseye segfaults QTPlasmac
I have these issues too. I did report it. I think we should raise a bug on github.
Can you run it in a terminal window for your customer and send stderr to nul?
- phillc54
14 Nov 2021 04:25 #226418
by phillc54
Why not just use a distro with the same python version as the Buster ISO.
It seems silly to use a distro where you need to hide all terminal error messages.
14 Nov 2021 04:31 #226420
Treading water pending Debian 12
I have spent to much time on networking, Samba, FTP etc to want to redo it.
I usually load from the command line using linuxcnc -l
Because it always seems to be open with all your updates
- bevins
14 Nov 2021 04:32 #226421
by bevins
weird, its not taking the repositories.
14 Nov 2021 04:42 #226422
I raised an issue.
- phillc54
14 Nov 2021 04:43 #226423
by phillc54
I am not sure what you mean.weird, its not taking the repositories.
- bevins
14 Nov 2021 04:47 #226424
by bevins
Added it to the sources.list file and it worked.
WTF do the guys that don't know this stuff do? It's really stupid the gui wont take the repositories but it worked when I added them manually to the file.
Time to create page: 0.267 seconds
