Debian 11 Bullseye segfaults QTPlasmac
  • bevins
  • bevins's Avatar Topic Author
  • Platinum Member
  • Platinum Member
14 Nov 2021 04:54 #226425 by bevins
Replied by bevins on topic Debian 11 Bullseye segfaults QTPlasmac
OK, i got QTPlasmaC v1.217.121    <= this the latest?
14 Nov 2021 04:54 #226426 by rodw
Replied by rodw on topic Debian 11 Bullseye segfaults QTPlasmac
Added it to the sources.list file and it worked.
WTF do the guys that don't know this stuff do? It's really stupid the gui wont take the repositories but it worked when I added them manually to the file.
They buy a commercial controller...
Getting and keeping a config working right now (that requires master branch) I have found to be the hardest since I started using Linuxcnc and had to compile the kernel to get preempt_rt.
A soon as Linuxcnc gets out of this list ftp-master.debian.org/new.html
I'm adopting Debian 12 (testing branch)
14 Nov 2021 04:56 #226427 by phillc54
Replied by phillc54 on topic Debian 11 Bullseye segfaults QTPlasmac
Yes
14 Nov 2021 05:00 #226428 by phillc54
I find it really easy, on my table which uses a Buildbot package I just do a sudo apt update and a sudo apt upgrade, on my test machines I do a git pull, make clean and make.
  • bevins
  • Platinum Member
  • Platinum Member
14 Nov 2021 05:11 #226430 by bevins
I just found the Buster ISO easy peasy. comes with the rt kernel, no compiling and once you get master its easy. I should have did this before.
Even has my usb wifi, no need to complie and mess with kernel modules.
Like Phil said. sudo apt-get update/upgrade
  • snowgoer540
  • snowgoer540's Avatar
  • Moderator
  • Moderator
14 Nov 2021 05:19 - 14 Nov 2021 05:21 #226431 by snowgoer540
Replied by snowgoer540 on topic Debian 11 Bullseye segfaults QTPlasmac
This is also an option:
forum.linuxcnc.org/9-installing-linuxcnc...rd-new-windows-users
Pretty step by step and painless.
The OS might be a bit more user friendly for your customers than the Debian 10 iso
Last edit: 14 Nov 2021 05:21 by snowgoer540.
  • bevins
  • Platinum Member
  • Platinum Member
14 Nov 2021 05:31 #226432 by bevins
I tried MX and couldnt get wifi kernel module to work properly.
This QTPlasmaC machine is being used by the customer now and I might upgrade it to debian buster cause at least the wifi is working on buster out of the box.
  • bevins
  • Platinum Member
  • Platinum Member
14 Nov 2021 05:33 #226433 by bevins
I think it is MX 21 that is loaded.
  • bevins
  • Platinum Member
  • Platinum Member
14 Nov 2021 05:51 #226434 by bevins
nope, its 19 from your install guide.
14 Nov 2021 06:58 #226436 by rodw
I had this problem too. So I reverted to Mint 19.3 which is what I've always used then it got broken becasue all of a sudden master wanted a later version of Python which I could not resolve. I wanted to steer clear of Buster because at that time it installed python 2 & python 3. By going to Bullseye, python2 was gone. The install went super smooth, bit like Bevin's 17 minutes, but then some things changed which threw some roadblocks out. But finding a few bugs and getting them fixed for the next guy is part of the game.
Time to create page: 0.325 seconds
