5 axis tilted drilling
4 years 4 weeks ago #253346 by Aciera
Replied by Aciera on topic 5 axis tilted drilling
the only think a did was to change the A to C in ini and hal file
I'm not clairvoyant.  How am I to know what specific changes you made to which version of your files. The changes should already be done in the hal file I posted, while the ini you would need to modify.
4 years 4 weeks ago - 4 years 4 weeks ago #253415 by Yannis
Replied by Yannis on topic 5 axis tilted drilling
For some reason the spindle is treated like axis
so i changed the number of axis to 6 and the error is gone
Last edit: 4 years 4 weeks ago by Yannis.
4 years 4 weeks ago #253419 by Yannis
Now i can see in the Axis Display X Y Z B C
Before the C change the axis display was X Y Z A B
But when i try to jog C axis the only think is moving is the velocity and then i have a error '' joint 5 following error''
4 years 3 weeks ago - 4 years 3 weeks ago #253503 by Yannis
File Name: my_LinuxCN...0-05.hal
File Size:16.22 KB
File Name: my_LinuxCN...0-05.ini
File Size:5.74 KB
Hello again
some update i install in a different pc a 2.9 version of linuxcnc
i have the same problem as in 2.7 version in all the configuration file i use XYZCBW
and for some reason in the axis display is XYZBCW and
the problem with the C axis not moving still there
any suggestions?
Last edit: 4 years 3 weeks ago by Yannis.
4 years 3 weeks ago #253590 by Aciera
I'm sorry I don't have much time but I would think the w axis does need some feedback hence the following error.
I'll try to have a look at it later today or tomorrow.
The following user(s) said Thank You: Yannis
4 years 3 weeks ago - 4 years 3 weeks ago #253620 by Aciera
After a bit of a ponder I think that the W axis might not even need a pid at all. So try removing/ commenting all this (if it isn't already commented out of course):
# AXIS W JOINT 5
setp pid.w.Pgain [JOINT_5]P
setp pid.w.Igain [JOINT_5]I
setp pid.w.Dgain [JOINT_5]D
setp pid.w.bias [JOINT_5]BIAS
setp pid.w.FF0 [JOINT_5]FF0
setp pid.w.FF1 [JOINT_5]FF1
setp pid.w.FF2 [JOINT_5]FF2
setp pid.w.deadband [JOINT_5]DEADBAND
setp pid.w.maxoutput [JOINT_5]MAX_OUTPUT
setp pid.w.error-previous-target true
# This setting is to limit bogus stepgen
# velocity corrections caused by position
# feedback sample time jitter.
setp pid.w.maxerror 0.012700
#net w-index-enable <=> pid.w.index-enable
#net w-enable => pid.w.enable
#net w-pos-cmd => pid.w.command
#net w-pos-fb => pid.w.feedback
#net w-output <= pid.w.output
# Step Gen signals/setup
#setp hm2_7i76e.0.stepgen.05.dirsetup [JOINT_5]DIRSETUP
#setp hm2_7i76e.0.stepgen.05.dirhold [JOINT_5]DIRHOLD
#setp hm2_7i76e.0.stepgen.05.steplen [JOINT_5]STEPLEN
#setp hm2_7i76e.0.stepgen.05.stepspace [JOINT_5]STEPSPACE
#setp hm2_7i76e.0.stepgen.05.position-scale [JOINT_5]STEP_SCALE
#setp hm2_7i76e.0.stepgen.05.step_type 0
#setp hm2_7i76e.0.stepgen.05.control-type 1
#setp hm2_7i76e.0.stepgen.05.maxaccel [JOINT_5]STEPGEN_MAXACCEL
#setp hm2_7i76e.0.stepgen.05.maxvel [JOINT_5]STEPGEN_MAXVEL
# ---closedloop stepper signals---
#net w-pos-cmd <= joint.5.motor-pos-cmd
#net w-vel-cmd <= joint.5.vel-cmd
#net w-output <= hm2_7i76e.0.stepgen.05.velocity-cmd
#net w-pos-fb <= hm2_7i76e.0.stepgen.05.position-fb
#net w-pos-fb => joint.5.motor-pos-fb
#net w-enable <= joint.5.amp-enable-out
#net w-enable => hm2_7i76e.0.stepgen.05.enable
# ---setup home / limit switch signals---
#net w-home-sw => joint.5.home-sw-in
#net w-neg-limit => joint.5.neg-lim-sw-in
#net w-pos-limit => joint.5.pos-lim-sw-in
And add this to close the loop:
net w-pos-fb     <= joint.5.motor-pos-cmd     => joint.5.motor-pos-fb
As for the rotary axis not moving I'm somewhat at a loss. As a last resort you might want to create a totally new config using the pncconf tool and modify/add the extra axis manually.
edit:
Also not that this line is not correct:
loadrt trivkins
It should be:
loadrt [KINS]KINEMATICS
Last edit: 4 years 3 weeks ago by Aciera.
Time to create page: 0.222 seconds
