5 axis tilted drilling
4 years 3 weeks ago #253732 by Yannis
Replied by Yannis on topic 5 axis tilted drilling
i will try that
4 years 3 weeks ago #253734 by Yannis
File Name: linuxcnc.report.txt
File Size:4.63 KB
4 years 3 weeks ago #253735 by Aciera
Replied by Aciera on topic 5 axis tilted drilling
check_config: (trivkins kinematics) ERROR:
[JOINT_3]MIN_LIMIT > [AXIS_A]MIN_LIMIT (-9999.01 > -1e99)
[JOINT_3]MAX_LIMIT < [AXIS_A]MAX_LIMIT (9999.01 < +1e99)
[JOINT_5]MIN_LIMIT > [AXIS_C]MIN_LIMIT (-10 > -9999.01)
[JOINT_5]MAX_LIMIT < [AXIS_C]MAX_LIMIT (20 < 9999.01)
You have your AXIS limits set larger than your JOINT limits. Try setting equal limits for axis and joints
4 years 3 weeks ago #253738 by Yannis
i try to set xyzabcw and xyzabc config
the error result
File Name: my_LinuxCN...08-2.ini
File Size:6.27 KB
File Name: linuxcnc.r...08-2.txt
File Size:8.44 KB
File Name: my_LinuxCN...08-2.hal
File Size:16.21 KB
4 years 3 weeks ago - 4 years 3 weeks ago #253746 by Aciera
Ok maybe try the attached files. I have fixed some stuff in your hal and omitted the a-axis there since we only want that in the ini to test things.
Last edit: 4 years 3 weeks ago by Aciera. Reason: edit ini file
The following user(s) said Thank You: Yannis
4 years 3 weeks ago #253847 by Yannis
 Hello
the resault with the latest file
File Name: linuxcnc_i...0-10.txt
File Size:3.42 KB
File Name: linuxcnc.r...0-10.txt
File Size:8.18 KB
Time to create page: 0.517 seconds
