5 axis tilted drilling
4 years 1 month ago - 4 years 1 month ago #253163 by Aciera
Replied by Aciera on topic 5 axis tilted drilling
Seems you are working with version 2.7. I'm less familiar with versions lower than 2.8 but here is a suggestion (make sure to backup your current ini file before making the changes.
The only other file needed would be the "5axiskins" file and I _think_ that is present in version 2.7. Also you seem to have the machine configured as XYZAB which seems odd as with the tilting rotational head you posted the rotation axis would be C. I will need to change your ini to the XYZBC setup because the 5axiskins used in the bridgemill simulation config uses that, so you might have to change the axis letter A to B and B to C in your .hal file.
Try changing/ adding the following lines in the sections indicated:
[DISPLAY]
GEOMETRY = XYZCBW
[TRAJ]
COORDINATES = XYZBCWY
[KINS]
JOINTS = 6
KINEMATICS = 5axiskins coordinates=xyzbcw
before the spindle section add (you will likely have to adjust the limit and velocity/accelleration values to your needs):
# Axis W
[AXIS_5]
TYPE = LINEAR
MIN_LIMIT = -10
MAX_LIMIT = 20
MAX_VELOCITY = 40
MAX_ACCELERATION = 70
HOME_SEARCH_VEL = 0
edit:
Forgot that you will likely also need to add stuff (ie pid) to your .hal file for the W axis so post that file if you are having trouble getting it running
Last edit: 4 years 1 month ago by Aciera.
The following user(s) said Thank You: Yannis
4 years 4 weeks ago #253311 by Yannis
Replied by Yannis on topic 5 axis tilted drilling
The HAL file
File Name: AGISANDROS...0-03.hal
File Size:14.08 KB
4 years 4 weeks ago - 4 years 4 weeks ago #253315 by Aciera
Here is a modified version to try. There will likely be errors on startup if you can't figure those out you will need to post the errors and your ini and hal file.
Last edit: 4 years 4 weeks ago by Aciera. Reason: file missing
4 years 4 weeks ago #253329 by Yannis
Your browser does not support embedded PDFs. Please download the file here: Download PDF.
i try to convert the A axis to C and i have this error
4 years 4 weeks ago #253336 by Aciera
Not sure, can you attach the hal and ini files you are working with?
4 years 4 weeks ago #253341 by Yannis
It is all ready attached
the only think a did was to change the A to C in ini and hal file
Time to create page: 0.062 seconds
