- Thank you received: 8
My spindle type encoder differential signal , I can use function "hm2_7i96s.0 encoder.05.quad-error-enable true" right ?I would set the hm2_7i96s.0 encoder.05.quad-error-enable bit,
do your gcode test and see if hm2_7i96s.encoder.05.quad-error gets set true
Is the spindle encoder differential?
If so, is the 7I77 set for differential inputs?
Hi Mr. PCWOK I would first verify the you have valid differential signals at the 7I77
You can do this by measuring the differential voltage with a voltmeter
You measure _between_ A and /A and _between_ B and /B
and verify that you have > 2V absolute in each state.
(you need to wiggle the spindle around to get each state)
One state should be >+2V and the other < -2V
(absolute value always greater than 2V)
Have any idea for orientation with 7i77 ?I'd recommend using shielded cables and proper grounding.
