Orientation position problem after run Gcode
3 years 4 weeks ago #282234 by Aciera
1. Have you installed the component?
$ sudo halcompile --install spindle_index_enable.comp
(don't use 'sudo' if you are on a rip installation ie if you have compiled linuxcnc on your computer)
2. There also is another error 'duplicate component name iocontrol' not sure where that comes from.
The following user(s) said Thank You: abdulasis12
3 years 4 weeks ago #282246 by abdulasis12
Thank you MR.Aciera
Now I install   sudo halcompile --install spindle_index_enable.comp   Done (must sudo can work).
Now wait MR.  0x2102    for advice about  signal 'spindle-syn not found '
3 years 4 weeks ago - 3 years 4 weeks ago #282256 by Aciera
Also, don't forget to 'loadrt ... ' and 'addf ...' the new component in your hal file.
Last edit: 3 years 4 weeks ago by Aciera.
3 years 4 weeks ago #282297 by abdulasis12
Ahh I don't know this step , Thank you ^^" .
loadrt spindle_index_enable
addf spindle_index_enable          servo-thread
Right ?
Asis,
3 years 4 weeks ago #282299 by Aciera
I think you would need (note the '.0' in the addf line):
addf spindle_index_enable.0 servo-thread
3 years 4 weeks ago #282304 by abdulasis12
Thank you MR. Aciera     , Will try tomorow
Time to create page: 0.202 seconds
