Orientation position problem after run Gcode
3 years 1 month ago #281321 by Aciera
Ah ok, it's actually an or2 component not a mux2 so that is fine then. I haven't gone over your hal in great detail and debugging spindle orientation can be a difficult task. Doing it remotely is very difficult indeed.
So the first thing I would suggest is to thoroughly test the spindle orient functionality by running the spindle and then do an M19 R0 then run the spindle again and do another M19 R0. You want this to work at least a hundred times using different spindle speeds and directions before moving on to other things.
3 years 1 month ago #281322 by abdulasis12
So the first thing I would suggest is to thoroughly test the spindle orient functionality by running the spindle and then do an M19 R0 then run the spindle again and do another M19 R0. You want this to work at least a hundred times using different spindle speeds and directions before moving on to other things.Today
Hi MR.Aciera
Today I try to find this problem what or where to error
I try
 m3 s1000  5minuts
recheck m19 r0  it's ok
m3 s2000 5 minuts
m3 s3000 3-4 mins
m3 s4000 4mins
m3 s5000 5 mins
m3 s6000 5mins
m3 s7000 5mins
before go next m3 i will M19 r0 for check  , result = good
then I try run gcode about 1:30 - 2 mins
when gcode completed I try M19 r0  it's wrong position Orient.
Maybe I think when gcode run  servo motor XYZ and motor water pump start too, Maybe noise in to Encoder05 on 7i77 for made it's error tracking ?
Asis,
3 years 1 month ago #281326 by PCW
I would set the hm2_7i96s.0 encoder.05.quad-error-enable bit,
do your gcode test and see if hm2_7i96s.encoder.05.quad-error gets set true
Is the spindle encoder differential?
If so, is the 7I77 set for differential inputs?
The following user(s) said Thank You: abdulasis12
3 years 1 month ago #281342 by abdulasis12
Hi MR.PCW
Yes, My spindle Encoder is Differential.
---- If so, is the 7I77 set for differential inputs?
Hmmm, I not sure , How to recheck ?
3 years 1 month ago #281344 by abdulasis12
Hi MR.PCW
Ahh  I just got you meaning set jumper.
Now I use Differential Done by default Board.
Asis,
3 years 1 month ago #281361 by abdulasis12
Amp spindle Old model Sanyo Denki on brother TC-228 I not have document for check type of signal encoder.
But on board I see  26LS32  I think it's sent signal type differential.
Time to create page: 0.323 seconds
