Trajectory Planner using Ruckig Lib
2 years 11 months ago #285764 by dm17ry
i suppose we do... i'm probably stating the obvious, but...
when passing any trajectory kink without a complete stop on it - x, y velocities will have a discontinuity.
when passing a transition from a line to an arc - accelerations will have a discontinuity.
some type of blending is required for all transitions: line-line, line-arc, arc-arc.
i guess opencn guys solved that with some matlab witchcraft...
2 years 11 months ago #285765 by Joco
I like things being spelt out. Assumption is the mother of all F ups.
I have been quietly mapping out calls from control.c which is part of EMCMOT down through to the scurve planner. Building up a relationship graph. When I have that a little more fleshed out will publish.
On blending, want to look into that more as to where and how. Grotius has mentioned (I believe) this would be covered by path rules. At the moment they are pretty basic. Focus has been elsewhere.
2 years 11 months ago #285770 by Becksvill
Love your work guys
Joco seems to be doing such a job job testing that I'm standing back a bit.
Once this is almost ready to run I can test it on my 6 ton machine.
The following user(s) said Thank You: tommylight, Joco, Grotius
2 years 11 months ago - 2 years 11 months ago #285791 by Joco
Replied by Joco on topic Trajectory Planner using Ruckig Lib
Ran a test of the t800 scurve TP on the plasma. Started out with no ve enabled. Was running like before. Enabled ve with a value of 1. All ok. Set value to 10. Soon after got follow error on a joint and things core-dumped. Will find the time to do a closer/more considered look and try and try and capture screens so we zero in on the point of following error.
I also have max_jerk set at 3000. Might dial that back a bit as well. NB: max acceleration is set at 3000mm/s/s.
Video of the full test file:
Edit:  Second run with joint 0 follow error being tracked. Think this needs more investigation as things core dump before any follow error gets graphed.:
This gcode file seems to generate a crash on both the sim and the plasma table.  Note that the "crash" in the sim seems to silent.  Things just stop at the same point but nothing relevant is trapped in logs.
File Name: gcode_test...1-17.ngc
File Size:35 KB
Cheers - J.
Last edit: 2 years 11 months ago by Joco.
2 years 11 months ago #285816 by Grotius
Replied by Grotius on topic Trajectory Planner using Ruckig Lib
Hi Joco,
Thanks for testing and showing us the following error.
It's clear we can not use velocity end values if path's are non colineair.
Do you think you can get rid of the pause delay between full stops?
I think it has to do with input values of acc or jerk. If you add hal pin for jerk,
you can set the jerk in the planner during runtime to test different values.
In the future we could code online blending for the planner.
Today i go to invest some time in a out of the box lcnc startup method.
I found a interesting video, at 23:24, can someone explain to me how to solve this matrix?
This looks like the ruckig algo.
Ok, have a nice day so far.
The following user(s) said Thank You: tivoi
2 years 11 months ago #285820 by Grotius
@Joco,
Your gcode file runs ok here.
The following user(s) said Thank You: akb1212, tivoi, Beef
Time to create page: 3.060 seconds
