Trajectory Planner using Ruckig Lib
2 years 11 months ago #285452 by spumco
Replied by spumco on topic Trajectory Planner using Ruckig Lib
Any suggestions for the name of this planner?
t2 judgment day
I can't think of anything that isn't amusingly vulgar, so I'll sit back during the naming process.
2 years 11 months ago #285458 by Joco
Replied by Joco on topic Trajectory Planner using Ruckig Lib
Re names and looking abck over the film characters and key referecnce points here is a list:
  • Skynet - used
  • Cyberdyne - used
  • T-800 Model 101
  • T-1000
  • T-X
  • T-600
  • T-3000
  • Rev-9
  • T-900 TOK715
You could take the pattern of the Terminator series names and extend them for each iteration.   The next option is to pick human characters from the films.
Cheers - J.
2 years 11 months ago #285462 by Joco
Proposed sample filw per request.   The big square has a mix of normal sides and ones made of a mix of different length coliner lines.
Cheers - J.
File Name: square-tests.ngc
File Size:6 KB
The following user(s) said Thank You: tivoi, Grotius
2 years 11 months ago #285473 by Grotius
Replied by Grotius on topic Trajectory Planner using Ruckig Lib
@Joco,
Any advice on how to import the exiting project into Creator?
In qt open the cmakelists.txt file, and it loads the project. You can also build it with qt, but to install you can
use one of the build scripts.
Thanks you for the names. ! We choose the next on the list : T-800 Model 101
Thanks for the ngc file.
The following user(s) said Thank You: akb1212, tivoi, Joco
2 years 11 months ago #285493 by tommylight
Replied by tommylight on topic Trajectory Planner using Ruckig Lib
Rev 9
To late?
2 years 11 months ago #285540 by Grotius
Hi Tommy,
Yes, it's tpmod_T800 & motmod_T800 now.
Next time.
Time to create page: 7.530 seconds
