Trajectory Planner using Ruckig Lib
2 years 5 months ago #301390
Apple make a special point of having G2(?) continuity on their products. The corners of an iPhone are not arcs, and people generally think this looks better, even if they don't notice it. Similarly on vehicles, they aim for better continuity so that you don't get straight lines in the reflections.
I found this YouTube video absolutely fascinating on the subject, and I did wonder if the matrix equation shown could be expanded to 3 or 9 axes to solve for the required continuity for CNC use. I think that would be a case of choosing the right boundary conditions and possibly solving iteratively.
(Don't be worried that the video is so long, if you are anything like me you will get to the end thinking it's been 15 minutes)
Replied by andypugh on topic Trajectory Planner using Ruckig Lib
This can be true, i believe you. But what is accepted by the community? A arc blend or a clothoid blend.
If a product has corner with a arc blend, it looks quite nice. If its a non arc shape, i think they are not happy.
The following user(s) said Thank You: akb1212, Clive S, Lcvette, Grotius
2 years 5 months ago #301391
This was introduced for spark-eroder applications.
The existing LinuxCNC TP already does this, if you set the feed override negative, it runs backwards.Reverse motion might open up the door to replicating the "Traking" feature on Prototrak CNC lathes. It lets you use one of the MPG wheels to move forward or reverse through the program motions.
The following user(s) said Thank You: akb1212, Lcvette, Grotius
- Thank you received: 2177
2 years 5 months ago - 2 years 5 months ago #301394
Replied by Aciera on topic Trajectory Planner using Ruckig Lib
Regarding toolpath smothing using clothoids in CNC application. I've posted this before in another thread but the link there seems broken so here it is again:
www.researchgate.net/publication/3318941...cf4408a7c0c/download
Last edit: 2 years 5 months ago by Aciera.
- RDA
- Thank you received: 43
2 years 5 months ago #301404
by RDA
Replied by RDA on topic Trajectory Planner using Ruckig Lib
I just want to say, great work everyone! Just let me know where to send beer.
The following user(s) said Thank You: Lcvette, Grotius
- Lcvette
- Thank you received: 784
2 years 5 months ago #301433
by Lcvette
Replied by Lcvette on topic Trajectory Planner using Ruckig Lib
First of all this is super awesome watching the progress on this project! a huge thank you to those putting the time in.
I wanted to throw this out as this is where my issues arise from with machine shake, it occurs during adaptive cutting tool paths on repositioning moves where a series of short line segments are posted. I have tried using smoothing settings and tolerance settings in fusion but it continues to spit out these short segments. i use G64 with the P value tied to fusion 360's "smoothing" setting, and it helps slightly but the shake at these repositioning moves is terrible, the doors on the machine rattle and shake something fierce and im sure its awesome for the motion mechanicals. I am posting the file and was wondering if perhaps you might be inclined to run it in your test TP and show a comparison of the current stock tp and the new scurve. i have a video here showing the machine shake its pretty ugly.. it was cutting this part, if you have volume you can hear the shudder and if not watch the frames of the doors for the shake.. /o\
Thanks guys!
Chris
repositioning shake video
Thanks guys!
Chris
The following user(s) said Thank You: akb1212, Grotius
- Grotius
- Thank you received: 2349
2 years 5 months ago #301439
by Grotius
Replied by Grotius on topic Trajectory Planner using Ruckig Lib
Hi Chris,
I will test the ngc file i the planner coming day's.
Hi All,
Found a nice lib, github.com/ebertolazzi/G1fitting .
This is from university.G1 fitting with clothoidsby Enrico Bertolazzi and Marco FregoWe are now a few commits ahead of the master.
I walk up to the morning sky first. With all my favorite colors. Right on. My sisters and my brothers.
Ok we made a function test in c++ to verify if we can use the bi-clothoid's into the linuxcnc toolpath planner.
The function peaks to : 0.094579000 milliseconds
Hi All,
The following user(s) said Thank You: akb1212, rodw, Lcvette, Aciera
Time to create page: 1.229 seconds
