- Thank you received: 37
I don't think there is any requirement to use halcompile to build the TP module. There are plenty of components written without it so you should be ablr to use Cmake to build you module.@rodw
Yes, I mostly agree - however if we would like to be able to package the trajectory planner with LinuxCNC at some point its much easier to build it with CMake. I discovered this myself while attempting to get the trajectory planner to compile alongside the rest of the project, I spent more time trying to get it to properly compile/link and fighting the preprocessor macros than actually making progress on the code itself. However, it can be done as a separate project using HALCompile as you said.
