Latency, error finishing read, and IRQ affinity
2 years 6 months ago #297764 by PCW
The IP address in the script should match the real IP address of the host device connected to the Mesa card
2 years 6 months ago #298207 by zmrdko
Hi, awsome script! Definitely fixes latency issues.
However, I am trying to utilize this with EtherCAT master and I am getting error
irqbalance is running AND there are more than 2 cpus - setting up policy script sed: can't read /etc/rc.local: No such file or directory
I would guess it has to do something with NIC IP address not being 10.10.10.1
2 years 6 months ago - 2 years 6 months ago #298208 by tommylight
Nope, some new Linux Distros do not use rc.local, so do a search for the distro you are suing and how to add it, then run the script again.
Edit,
Left hand seems faster that right one, USING, should be using, not suing above! :)
Last edit: 2 years 6 months ago by tommylight. Reason: Typo
The following user(s) said Thank You: zmrdko
2 years 6 months ago #298658 by jg00163206
i am stuck on the irqblance part in the instructions of that link. i created the files but i am not certain what to do from there. when i run: sudo ./rt_setup.sh, command not found. i created both files and make them exicutable and restarted and when i run: sudo ./rt_setup.sh. what to do after that. i am missing something something.
2 years 6 months ago #298694 by jg00163206
i think i have it. maybe if i took the time to read the entire thread, i might find the information i am looking for. thanks
2 years 6 months ago #298696 by jg00163206
i guess i dont have this figured out. i keep getting command not found when i run sudo ./rt_setup.sh. i know i have to do something to the file but i can't figure out what to do to make it not give me the error on exit error. please help me out
Time to create page: 0.362 seconds
