Latency, error finishing read, and IRQ affinity
2 years 5 months ago #300464 by Swag
If I rerun rt_setup.sh, it is not updating the two files in /etc/linuxcnc and manually editing the lcnc_setirqaffinities.sh to have the correct IP does not result in the IRQ being pinned to the correct CPU (2 instead of 8, still). So looks like I still have some investigations to do, but at least I now know what needs to be accomplished.
The following user(s) said Thank You: DHeineck
2 years 5 months ago #301800 by BryceJ
Thanks for the script! Had been fighting this issue for a few days with errors talking to a mesa board on a N100 that I was setting up. Worked great on once I fixed the same issue Swag had.  My static IP had been 10.10.10.11.  Changed it to 10.10.10.1 and the ping to 10.10.10.10 was good, previously I was getting random 3ms spikes.
ping 10.10.10.10 -i .02
325 packets transmitted, 325 received, 0% packet loss, time 8151ms
rtt min/avg/max/mdev = 0.080/0.101/0.127/0.007 ms
2 years 2 months ago - 2 years 2 months ago #307179 by CNC_Tinkerer
Hi!
I am working with a custom ethernet interface and think I really need this IRQ management. Unfortunately I have not been able to get what's described here to work after quite a few hours beating my head on the desk and rereading ALL these posts several times. I've tried a number of things but I don't know much about scripting. I'm probably missing something obvious.
If someone has debugging suggestions or can tell me what other information to post here I would really appreciate it.
Architecture: x86_64 CPU(s): 8 On-line CPU(s) list: 0-7 Thread(s) per core: 2 Core(s) per socket: 4 Socket(s): 1 NUMA node(s): 1 Vendor ID: AuthenticAMD CPU family: 23 Model: 17 Model name: AMD Ryzen 5 PRO 2400G with Radeon Vega Graphics
The obvious things:
I did install irqbalance via Synaptic. I did change IP to 10.0.0.1 two places in rt_setup.sh--that's the address in interfaces file.
What happens:
If I run rt_setup.sh it says it is creating the affinity file, and it ends up in /etc/linuxcnc as expected with permissions correct. But after restart I seem to end up with ethernet interrupts always on cpu5 where I would expect cpu7.
user1@debian2:~/linuxcnc/irq-mgmt$ sudo ./rt_setup.sh [sudo] password for user1: Linux debian2 4.19.0-16-rt-amd64 #1 SMP PREEMPT RT Debian 4.19.181-1 (2021-03-19) x86_64 GNU/Linux irqbalance is running AND there are more than 2 cpus - setting up policy script
The script comes up with isolcpus 6,7 in grub, which is what I determined months ago and added manually and seems like it should be correct.
    linux    /boot/vmlinuz-4.19.0-16-rt-amd64 root=UUID=5b220cf2-b101-424f-9abb-ee2246a65503 ro initrd=/install/gtk/initrd.gz quiet isolcpus=6,7 intel_idle.max_cstate=1 i915.enable_rc6=0
my /etc/network/interfaces (after removing commented out lines and loopback):
# This file describes the network interfaces available on your system # and how to activate them. For more information, see interfaces(5). source /etc/network/interfaces.d/* # NEW - Lenovo Ryzen desktop PC allow-hotplug enp8s0f0 iface enp8s0f0 inet static address 10.0.0.1
Significant things I tried:
Running test script "pinirq_2024-05-12.txt" with parameter enp8s0f0 displays expected results. But watching interrupts stills shows the nic IRQs on cpu5.
user1@debian2:~/linuxcnc/irq-mgmt$ sudo ./pinirq enp8s0f0 Cores: 8 Old CPU Mask: 0020 Set device enp8s0f0 IRQ 61 CPU mask to 0128
I tried using NIC=`enp8s0f0` in place of both awks in rt_setup.sh but that does not work either (note the quotes I used!).
I did have loopback lines and old (commented out) iface and address lines in interfaces file. I removed them and reran everything as I'm not sure how picky that grep is.
user1@debian2:~/linuxcnc/irq-mgmt$ sudo /etc/init.d/irqbalance status -l ● irqbalance.service - irqbalance daemon    Loaded: loaded (/lib/systemd/system/irqbalance.service; enabled; vendor preset: enabled)    Active: active (running) since Wed 2024-08-07 08:31:44 EDT; 1h 8min ago      Docs: man:irqbalance(1)            https://github.com/Irqbalance/irqbalance  Main PID: 577 (irqbalance)     Tasks: 2 (limit: 4915)    Memory: 6.3M    CGroup: /system.slice/irqbalance.service            └─577 /usr/sbin/irqbalance --foreground --policyscript=/etc/linuxcnc/lcnc_irqbalancepolicy.sh Aug 07 08:31:44 debian2 systemd[1]: Started irqbalance daemon.
section from /proc/interrupts:
60: 0 0 0 0 0 0 0 0 IR-PCI-MSI 4726791-edge xhci_hcd 61: 0 0 0 0 0 71062 0 0 IR-PCI-MSI 4194304-edge enp8s0f0 62: 0 0 0 697991 0 0 0 0 IR-PCI-MSI 4718592-edge amdgpu
Last edit: 2 years 2 months ago by CNC_Tinkerer. Reason: code formatting still butchered
2 years 2 months ago #307182 by CNC_Tinkerer
Is it possible /etc/default/irqbalance is not being used and thus not reaching our lcnc_irqbalancepolicy.sh file? I don't understand how that process is supposed to work...
2 years 1 month ago #310881 by rajsekhar
I downloaded lcnc_irqpolicy.sh.txt.
My NIC is "enp4s0" and Mesa ip=10.10.10.10.
I made the modification in the above file and modified file attached. Please check whether any further correction required or it is ok.
NIC=`awk 'BEGIN{nic="enp4s0 "} {if ($1=="iface") {tmpnic = $2} if ($1=="address") {if ($2 == 10.10.10.10 ) {nic = tmpnic}}} END{print(nic)}' /etc/network/interfaces`
1 year 11 months ago #314597 by dbtayl
In the interest of contributing something and not solely sucking time asking questions about problems that may well not actually be LinuxCNC's problem...
I've got a Celeron J6412 fanless PC with integrated graphics running my mill. Arch Linux, kernel 6.10.2-rt14-arch1-2-rt from the official Arch repo. Jitter is ~32000 ns- plenty good for Mesa usage, longer than I'd like. That's the result of following this thread's guidance and the usual disabling of power management in the BIOS.
My actual contribution is around video drivers. Re jitter, fbdev works great (albeit slow), the legacy Intel and KMS/modesetting drivers were terrible- latency well over 100000 ns. I'm guessing that's why you see the "nomodeset" kernel option listed. In my case, I found that disabling glamor in xorg.conf lets you use modesetting with seemingly (placebo effect?) better performance, but without any hit to jitter:
Section "Device"     Identifier "Intel Graphics"     Driver "modesetting"     #"glamor" is the other/default option     Option "AccelMethod" "none" EndSection
Time to create page: 0.196 seconds
