Latency, error finishing read, and IRQ affinity
2 years 8 months ago #293008 by mozmck
It seems like in the past I had tested on dual core and had it working, but it could be that irqbalance or maybe the service that starts it has been changed in newer versions/distributions. The problem I had recently was due to the fact that it did 'exit 1' which worked fine in the past, but now it had to be 'exit 0'
2 years 8 months ago #293011 by Mecanix
Nice one! Unfortunately the great Ice-Age, Medieval, Antiquated infamous Intel Core Duo's not happy with it. I can only get the service to start and the script executed with GRUB_CMDLINE_LINUX_DEFAULT="quiet". a.k.a. No isolcpus but then that defeats the purpose. Fails to start the service with isolcpus so I think you were initially right. Or perhaps I'm not doing it right, let's see if someone else with a similar coreduo set-up can.
cnc@debian-duo:~$ sudo /etc/init.d/irqbalance status ● irqbalance.service - irqbalance daemon      Loaded: loaded (/lib/systemd/system/irqbalance.service; enabled; preset: enabled)      Active: active (running) since Sat 2024-02-10 11:56:07 EST; 2min 23s ago        Docs: man:irqbalance(1)              https://github.com/Irqbalance/irqbalance    Main PID: 370 (irqbalance)       Tasks: 2 (limit: 6868)      Memory: 1.7M         CPU: 222ms      CGroup: /system.slice/irqbalance.service              └─370 /usr/sbin/irqbalance --foreground --policyscript=/etc/irqbalance.d/lcnc_irqpolicy.sh Feb 10 11:56:07 debian-duo systemd[1]: Started irqbalance.service - irqbalance daemon.
2 years 8 months ago #293012 by tommylight
Made this sticky, thank you.
2 years 8 months ago #293018 by mozmck
Mecanix, the second script is for use without irqbalance running. It should be run from /etc/rc.local and not as a policyscript for irqbalance. I haven't tested it myself yet, but I know I have a dual-core or two around here that I can try it on. Probably be next week or so before I can find time to do that.
2 years 8 months ago #293024 by Mecanix
Ah. You actually did mentioned, missed it, sry.
$ sudo nano /etc/default/grub     #GRUB_CMDLINE_LINUX_DEFAULT="quiet"     GRUB_CMDLINE_LINUX_DEFAULT="quiet isolcpus=1" $ sudo update-grub $ sudo nano /etc/rc.local -----------------------------------------------------     #!/bin/sh -e     #     # IRQ Affinity by mozmck     sh '/etc/irqbalance.d/lcnc_irqpolicy.sh'     exit 0 ----------------------------------------------------- $ sudo chmod +x /etc/rc.local $ sudo systemctl daemon-reload $ sudo systemctl status rc-local
What's the required voodoo to verify/debug besides $ watch -n1 -d cat /proc/interrupts ?
2 years 8 months ago #293025 by rodw
If this is stickied now, is this the right section? It might be better in Installing linuxcnc
Time to create page: 0.106 seconds
