THC problem
- acourtjester
- Thank you received: 29
30 May 2024 16:53 - 30 May 2024 16:54 #301893
by acourtjester
THC problem was created by acourtjester
Last edit: 30 May 2024 16:54 by acourtjester.
- jimmyrig
- Thank you received: 42
30 May 2024 17:11 - 30 May 2024 17:32 #301894
by jimmyrig
Replied by jimmyrig on topic THC problem
I assume you mean qtplasmac?
Go to parameters and increase your (can't remember exact term) void anti dive. This should help but if not try decreasing (or increasing) your p term in your pid.
My guess is it's a pid issue (or you are cutting too slow)
Takes a bit to get it tuned perfect but when it is.....it's sweet. I can cut for hours on a 8x4ft sheet and never touch the torch to the table
Last edit: 30 May 2024 17:32 by jimmyrig.
The following user(s) said Thank You: acourtjester
- Thank you received: 7506
30 May 2024 18:43 #301899
Replied by tommylight on topic THC problem
Are those cuts supposed to end like that?
I do not think so, so :
-check the THCAD division jumper is seated properly and does not move
-try to catch the screen when that happens, does the voltage rise a lot?
-tighten the screw terminals on both sides of THCAD cable, just in case
-check the high voltage cables from plasma to THCAD
And, do you get latency warnings when running LinuxCNC?
- acourtjester
31 May 2024 14:49 - 31 May 2024 14:53 #301992
by acourtjester
Replied by acourtjester on topic THC problem
Here is what I have done, changed the speed PID from 10 to 5, PID-I form 0 to 3 and PID-D from 0 to 3. No real change it cuts some part and fails on others. Jumper on the board is on 32 and unipolar.
Tried to use a Cut Rule in SheetCam to drop the THC about 0.250" before end but QTPlasmaC did not like the G-code see attached. I do get a latency error but not when doing any operations, I get it when editing the G-code in QTPlasmaC randomly. Attached a screenshot of running the Latency check test. the voltage does not seem to bounce around that much, the Z axis seems to move maybe0.030" up and down until it crashes.
Last edit: 31 May 2024 14:53 by acourtjester. Reason: added info
- Thank you received: 5337
31 May 2024 15:08 #301998
Replied by PCW on topic THC problem
A dive towards the work would indicate that the voltage was read as high
It it possible that you have lost the arc and it is not signaled to LinuxCNC?
A halscope plot of the voltage, arc-ok, and velocity when you have the issue would help a lot
- acourtjester
31 May 2024 15:15 #302000
by acourtjester
I will see what I can do. Not a real expert on LinuxCNC
- phillc54
- Thank you received: 2100
31 May 2024 19:24 #302022
by phillc54
This is telling you that in line 37 of the G-code (or nearby) there is a M998 command but LinuxCNC will only accept M codes up to M199.
Replied by phillc54 on topic THC problem
- acourtjester
31 May 2024 20:52 #302025
by acourtjester
I sent an email to Les at SheetCam about that. He has modified the PlasmaC post processor so I could use a delay (M01 code snippet) in it. So I hope he will modify it again for the Cut Rule that LinuxCNC will work with. Not sure if that will help with the problem I am having, but it was suggested by a member at Plasma Spider.
- phillc54
31 May 2024 21:00 #302028
by phillc54
linuxcnc.org/docs/devel/html/gcode/m-code.html#mcode:m0-m1
M01 would be a pause.I sent an email to Les at SheetCam about that. He has modified the PlasmaC post processor so I could use a delay (M01 code snippet) in it.
- acourtjester
31 May 2024 21:07 - 31 May 2024 21:09 #302029
by acourtjester
Yes I know that I was using it between a center punch routine and normal cutting so I could change the amps on the plasma unit. I have since found it is not needed as with the tool I use in SheetCam it fires the torch so short it just makes a dimple in the surface. It is much easier to locate the drill hole in the DXF file then measuring after the part is cut.
Last edit: 31 May 2024 21:09 by acourtjester.
Time to create page: 0.267 seconds
