THC problem
08 Jun 2024 15:55 #302652 by PCW
Replied by PCW on topic THC problem
GRUB_CMDLINE_LINUX_DEFAULT="quiet isolcpus=1 acpi_irq_nobalance idle=poll"
The following user(s) said Thank You: acourtjester
09 Jun 2024 15:27 - 09 Jun 2024 15:29 #302705 by acourtjester
Replied by acourtjester on topic THC problem
Ok after I make the change to the grub as above I then use crontab to create an operation to run the pinirq script a boot time. With a ctrl x to write it.
@reboot chmod +x pinirq,txt
sudo ./pinirq.txt eth0    should there be a @ at the beginning of this line too???
the script is already on the hard drive from the last time I used it
Last edit: 09 Jun 2024 15:29 by acourtjester. Reason: added info
09 Jun 2024 15:48 #302707 by PCW
You don't need to chmod +x more than once so
chmod +x pinirq,txt in unnecessary (and will fail
because crontab has no idea where pinirq.txt is located)
Not sure about crontab and sudo
(will it ask you for a password during startup?)
So the systemd method of launching scripts at startup
may be better
Note that sudo ./pinirq.txt eth0 will fail because again crontab
does not know where pinirq.txt is located (you need a full path
or copy pinirq.txt to a standard executable directory like /user/bin/
Also pinirq.txt should probably be renamed just pinirq or pinirq.sh
(it only has the .txt suffix because that's required to be able to post it to the forum)
@reboot is what tells crontab to do the operation only at boot time
09 Jun 2024 16:04 #302709 by acourtjester
How about @reboot (full path location) pinirq (renamed just ) pinirq
next line ./pinirq eth0
09 Jun 2024 16:11 #302710 by PCW
@reboot  sudo pinirq eth0
assuming pinirq is in /usr/bin/
09 Jun 2024 16:14 #302712 by acourtjester
done deal I can move it and remove the .txt from it
18 Sep 2024 21:30 #310421 by Diegot
Replied by Diegot on topic THC problem
wow, thank you
my ping was 0.4s to the mesa card and went to 0.4ms
Time to create page: 1.200 seconds
