THC problem
2 years 4 months ago - 2 years 4 months ago #302467 by acourtjester
Replied by acourtjester on topic THC problem
Thanks I have figured out how to make the changes in grub but not how to save it. I did see the options at the bottom, and thinking about it I was not having the complete keystrokes to do the write, Adding the ctrl key was what I was missing.  When I tried a similar route to windows it get a denied message.  I assume when I do the Ctrl^X it will then ask to replace the grub file with the changed one.
Last edit: 2 years 4 months ago by acourtjester. Reason: added info
2 years 4 months ago #302475 by PCW
Replied by PCW on topic THC problem
As Aciera suggested, you must use "sudo" when launching the
editor to edit system files:
$ sudo nano /etc/default/grub
The following user(s) said Thank You: acourtjester
2 years 4 months ago #302549 by acourtjester
Ok changed made to grub, did not help the latency error problem. I still get it randomly
2 years 4 months ago #302551 by PCW
Can you run this script to check your setup?
File Name: checkmask_...6-07.txt
File Size:621 B
Download
chmod +x checkmask.txt
./checkmask.txt ethernet_device_name
ethernet_device_name will be something like eno1 or enp0s25
You can get a list with the command
ip a
2 years 4 months ago - 2 years 4 months ago #302564 by acourtjester
Well I am dumb and a stick, I got the ip a and attached it here.
But had no luck getting the other info you want,  I am not a linux person so you will need to write exactly which the commands are needed for me to supply the info to you.
I tried to use the terminal but no luck,  I did do file searches but could not find that file (checkmask.txt).
2 years 4 months ago #302567 by PCW
Case is important in unix/linux commands
(CHMOD is not the same as chmod)
./checkmask.txt eth0
Time to create page: 0.130 seconds
