THC problem
2 years 4 months ago - 2 years 4 months ago #302568 by acourtjester
Replied by acourtjester on topic THC problem
I'm still not getting it sorry  Do I need to be in another directory in the terminal??
Last edit: 2 years 4 months ago by acourtjester. Reason: added info
2 years 4 months ago - 2 years 4 months ago #302569 by PCW
Replied by PCW on topic THC problem
CHMOD is not the same as chmod,
That is, there is no CHMOD command
but there is a chmod command.
first command:
chmod +x checkmask.txt
second command
./checkmask.txt eth0
You should be able to copy, paste these into a
terminal window (in the Downloads directory
since that's where downloaded files go)
Last edit: 2 years 4 months ago by PCW.
The following user(s) said Thank You: acourtjester
2 years 4 months ago - 2 years 4 months ago #302575 by acourtjester
no difference it now looks like there is no file checkmask.txt.  I tried different spacing too.
2 years 4 months ago - 2 years 4 months ago #302576 by PCW
1. You have to know where you downloaded the file
Note, at least with Firefox, you can specify "Save link as"
so you know both the name of the saved file and where
its been saved.
2. chmod+x is not valid, chmod +x is (note the space between chmod and +x )
2 years 4 months ago #302587 by tommylight
Replied by tommylight on topic THC problem
cd
press enter
cd Downloads
press enter
>>>>copy the line bellow by left clicking 3 times fast on the line and right click select "copy"<<<
right click in terminal and choose "paste"
press enter
press enter
2 years 4 months ago #302595 by acourtjester
Ok where do I download checkmask.txt from???????
Time to create page: 0.079 seconds
