linuxcnc trajectory planner
  • Grotius
  • Grotius's Avatar Topic Author
  • Platinum Member
  • Platinum Member
18 Oct 2024 11:28 #312534 by Grotius
Replied by Grotius on topic linuxcnc trajectory planner
Hi Arciera,
That's a cubicspline lib that was tested. Is now removed from source, not used, obsolete now.
Updated:
codeberg.org/skynet/linuxcnc_trajectory_planner
If you will, also install this, as i tested a 2d clothoid spline, that needs a ipop lib.
sudo apt-get install coinor-libipopt-dev
19 Oct 2024 05:50 #312592 by Aciera
Replied by Aciera on topic linuxcnc trajectory planner
First issue:
user@user-iMac:~/linuxcnc_trajectory_planner/cmake/build$ cmake ..
-- Configuring done
CMake Error in motion/CMakeLists.txt:
  Imported target "clothoids" includes non-existent path
    "/home/user/linuxcnc_trajectory_planner/cmake/motion/../Clothoids-1/build"
  in its INTERFACE_INCLUDE_DIRECTORIES.  Possible reasons include:
  * The path was deleted, renamed, or moved to another location.
  * An install or uninstall procedure did not complete successfully.
  * The installation package was faulty and references files it does not
  provide.
  provide.
-- Generating done
CMake Generate step failed.  Build files cannot be regenerated correctly.
So I tried to delete what seemed to refer to the clothoids-1 from the CMakeLists.txt upon which the error disappeared:
-- Configuring done
-- Generating done
-- Build files have been written to: /home/user/linuxcnc_trajectory_planner/cmake/build
However trying to run 'sim/axis/axis_mm.ini' fails with this:
user@user-iMac:~/linuxcnc_trajectory_planner$ linuxcnc
LINUXCNC - 2.10.0~pre0
Machine configuration directory is '/home/user/linuxcnc_trajectory_planner/configs/sim/axis'
Machine configuration file is 'axis_mm.ini'
Starting LinuxCNC...
linuxcncsvr (2133377) emcsvr: machine 'LinuxCNC-HAL-SIM-AXIS'  version '1.1'
Note: Using POSIX non-realtime
milltask (2133420) task: machine 'LinuxCNC-HAL-SIM-AXIS'  version '1.1'
halui (2133422) halui: machine 'LinuxCNC-HAL-SIM-AXIS'  version '1.1'
Found file(lib): /home/user/linuxcnc_trajectory_planner/lib/hallib/core_sim.hal
motmod: dlopen: /home/user/linuxcnc_trajectory_planner/rtlib/motmod.so: undefined symbol: vector_clear
/home/user/linuxcnc_trajectory_planner/lib/hallib/core_sim.hal:7: waitpid failed /home/user/linuxcnc_trajectory_planner/bin/rtapi_app motmod
/home/user/linuxcnc_trajectory_planner/lib/hallib/core_sim.hal:7: /home/user/linuxcnc_trajectory_planner/bin/rtapi_app exited without becoming ready
/home/user/linuxcnc_trajectory_planner/lib/hallib/core_sim.hal:7: insmod for motmod failed, returned -1
USRMOT: ERROR: command 30 timeout
emcMotionInit: emcTrajInit failed
LinuxCNC terminated with an error.  You can find more information in the log:
    /home/user/linuxcnc_debug.txt
and
    /home/user/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
  • Grotius
  • Platinum Member
  • Platinum Member
19 Oct 2024 07:29 #312599 by Grotius
Hi Arciera,
You are almost there.
About your error, this is a function used by motion.c. For some reason at my pc it run's ok.
To avoid your error, i added extra function prototypes in the place where you get the error from : motmod.so
review : added function defenitions
Repo is updated.
Ok. now focussing on the scurve code.
Good luck Arciera...
The following user(s) said Thank You: Aciera, Darium
19 Oct 2024 08:02 #312601 by Aciera
Updated the repo, rebuilt:
2004  cd linuxcnc_trajectory_planner/
 2005  git pull
 2006  ./autogen.sh
 2007  ./configure --with-realtime=uspace --disable-build-documentation-translation --enable-non-distributable=yes --disable-build-documentation
 2008  cd ..
 2009  cd cmake/build/
 2010  cmake ..
 2011  linuxcnc
but unfortunately still the same error:
linuxcncsvr (2177975) emcsvr: machine 'LinuxCNC-HAL-SIM-AXIS'  version '1.1'
milltask (2177989) task: machine 'LinuxCNC-HAL-SIM-AXIS'  version '1.1'
halui (2177991) halui: machine 'LinuxCNC-HAL-SIM-AXIS'  version '1.1'
  • Grotius
  • Platinum Member
  • Platinum Member
19 Oct 2024 09:48 #312609 by Grotius
Hi Arciera,
To verify i did a fresh clone into a dir named : ~/test.
1. Build linuxcnc as usual, and did a sudo make install to finish the installation.
2. Build the clothoid-1 lib. (had to empty the build dir, then cmake.. make -j4.  eventually do a make install for system wide.)
3. Create build dir ~/linuxcnc_trajectory_planner/cmake/build
4. cd into this build dir. then : cmake.. make -j4    and do a make install
5. Run the ./build.sh script.
6. Linuxcnc runs here.
I think you did not do a make install for installing (overwriting) the modified motmod.so component.
Ok good luck.
20 Oct 2024 06:11 - 20 Oct 2024 06:34 #312657 by Aciera
Ok so I seem to have managed to build the clothoids-1 lib:
[code]user@user-iMac:~/linuxcnc_trajectory_planner/cmake/Clothoids-1$ mkdir build
user@user-iMac:~/linuxcnc_trajectory_planner/cmake/Clothoids-1$ ls
build  cmake  CMakeLists.txt  deps  include  LICENSE  README.rst  src  src_py  src_tests_broken  VERSION
user@user-iMac:~/linuxcnc_trajectory_planner/cmake/Clothoids-1$ cd build/
user@user-iMac:~/linuxcnc_trajectory_planner/cmake/Clothoids-1/build$ cmake ..
-- The C compiler identification is GNU 11.4.0
-- The CXX compiler identification is GNU 11.4.0
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/bin/cc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Configuring done
-- Generating done
-- Build files have been written to: /home/user/linuxcnc_trajectory_planner/cmake/Clothoids-1/build
user@user-iMac:~/linuxcnc_trajectory_planner/cmake/Clothoids-1/build$ cd ..
user@user-iMac:~/linuxcnc_trajectory_planner/cmake/Clothoids-1/build$ ls
Clothoids  ClothoidsConfig.cmake  ClothoidsConfigVersion.cmake  CMakeCache.txt  CMakeFiles  cmake_install.cmake  compile_commands.json  _deps  deps  Makefile
user@user-iMac:~/linuxcnc_trajectory_planner/cmake/Clothoids-1/build$ make -j4
[  6%] Building CXX object _deps/polynomialroots-build/CMakeFiles/PolynomialRootsStatic.dir/src/PolynomialRoots-1-Quadratic.cc.o
[  6%] Building CXX object _deps/polynomialroots-build/CMakeFiles/PolynomialRootsStatic.dir/src/PolynomialRoots-3-Quartic.cc.o
[  6%] Building CXX object _deps/polynomialroots-build/CMakeFiles/PolynomialRootsStatic.dir/src/PolynomialRoots-2-Cubic.cc.o
[  8%] Building CXX object _deps/polynomialroots-build/CMakeFiles/PolynomialRootsDynamic.dir/src/PolynomialRoots-1-Quadratic.cc.o
[ 10%] Building CXX object _deps/polynomialroots-build/CMakeFiles/PolynomialRootsDynamic.dir/src/PolynomialRoots-2-Cubic.cc.o
[ 12%] Building CXX object _deps/polynomialroots-build/CMakeFiles/PolynomialRootsStatic.dir/src/PolynomialRoots-Jenkins-Traub.cc.o
[ 14%] Building CXX object _deps/polynomialroots-build/CMakeFiles/PolynomialRootsStatic.dir/src/PolynomialRoots-Utils.cc.o
[ 16%] Building CXX object _deps/polynomialroots-build/CMakeFiles/PolynomialRootsDynamic.dir/src/PolynomialRoots-3-Quartic.cc.o
[ 18%] Building CXX object _deps/polynomialroots-build/CMakeFiles/PolynomialRootsDynamic.dir/src/PolynomialRoots-Jenkins-Traub.cc.o
[ 20%] Building CXX object _deps/polynomialroots-build/CMakeFiles/PolynomialRootsDynamic.dir/src/PolynomialRoots-Utils.cc.o
[ 22%] Linking CXX static library libPolynomialRoots.a
[ 22%] Built target PolynomialRootsStatic
[ 27%] Building CXX object CMakeFiles/ClothoidsStatic.dir/src/Constants.cc.o
[ 27%] Building CXX object CMakeFiles/ClothoidsDynamic.dir/src/Constants.cc.o
[ 29%] Building CXX object CMakeFiles/ClothoidsDynamic.dir/src/AABBtree.cc.o
[ 31%] Linking CXX shared library libPolynomialRoots.so
[ 31%] Built target PolynomialRootsDynamic
[ 33%] Building CXX object CMakeFiles/ClothoidsStatic.dir/src/AABBtree.cc.o
[ 35%] Building CXX object CMakeFiles/ClothoidsDynamic.dir/src/Biarc.cc.o
[ 37%] Building CXX object CMakeFiles/ClothoidsStatic.dir/src/Biarc.cc.o
[ 39%] Building CXX object CMakeFiles/ClothoidsDynamic.dir/src/BiarcList.cc.o
[ 41%] Building CXX object CMakeFiles/ClothoidsStatic.dir/src/BiarcList.cc.o
[ 43%] Building CXX object CMakeFiles/ClothoidsDynamic.dir/src/Circle.cc.o
[ 45%] Building CXX object CMakeFiles/ClothoidsDynamic.dir/src/Clothoid.cc.o
[ 47%] Building CXX object CMakeFiles/ClothoidsDynamic.dir/src/ClothoidDistance.cc.o
[ 50%] Building CXX object CMakeFiles/ClothoidsDynamic.dir/src/ClothoidG2.cc.o
[ 52%] Building CXX object CMakeFiles/ClothoidsDynamic.dir/src/ClothoidList.cc.o
[ 54%] Building CXX object CMakeFiles/ClothoidsStatic.dir/src/Circle.cc.o
[ 56%] Building CXX object CMakeFiles/ClothoidsStatic.dir/src/Clothoid.cc.o
[ 58%] Building CXX object CMakeFiles/ClothoidsStatic.dir/src/ClothoidDistance.cc.o
[ 60%] Building CXX object CMakeFiles/ClothoidsDynamic.dir/src/Fresnel.cc.o
[ 62%] Building CXX object CMakeFiles/ClothoidsDynamic.dir/src/G2lib_intersect.cc.o
[ 64%] Building CXX object CMakeFiles/ClothoidsStatic.dir/src/ClothoidG2.cc.o
[ 66%] Building CXX object CMakeFiles/ClothoidsStatic.dir/src/ClothoidList.cc.o
[ 68%] Building CXX object CMakeFiles/ClothoidsDynamic.dir/src/G2lib.cc.o
[ 70%] Building CXX object CMakeFiles/ClothoidsDynamic.dir/src/Line.cc.o
[ 72%] Building CXX object CMakeFiles/ClothoidsDynamic.dir/src/PolyLine.cc.o
[ 75%] Building CXX object CMakeFiles/ClothoidsStatic.dir/src/Fresnel.cc.o
[ 77%] Building CXX object CMakeFiles/ClothoidsStatic.dir/src/G2lib_intersect.cc.o
[ 79%] Building CXX object CMakeFiles/ClothoidsDynamic.dir/src/Triangle2D.cc.o
[ 81%] Building CXX object CMakeFiles/ClothoidsStatic.dir/src/G2lib.cc.o
[ 83%] Building CXX object CMakeFiles/ClothoidsStatic.dir/src/Line.cc.o
[ 85%] Building CXX object CMakeFiles/ClothoidsDynamic.dir/src/ClothoidSpline-Interpolation.cc.o
[ 87%] Building CXX object CMakeFiles/ClothoidsDynamic.dir/src/ClothoidSpline-LMSolver.cc.o
[ 89%] Building CXX object CMakeFiles/ClothoidsStatic.dir/src/PolyLine.cc.o
[ 91%] Building CXX object CMakeFiles/ClothoidsStatic.dir/src/Triangle2D.cc.o
[ 93%] Building CXX object CMakeFiles/ClothoidsStatic.dir/src/ClothoidSpline-Interpolation.cc.o
[ 95%] Building CXX object CMakeFiles/ClothoidsStatic.dir/src/ClothoidSpline-LMSolver.cc.o
[ 97%] Linking CXX shared library libClothoids.so
[ 97%] Built target ClothoidsDynamic
[100%] Linking CXX static library libClothoids.a
[100%] Built target ClothoidsStatic
Then the install also seemed to work:
user@user-iMac:~/linuxcnc_trajectory_planner/cmake/Clothoids-1/build$ sudo make install
[ 12%] Built target PolynomialRootsStatic
[ 50%] Built target ClothoidsStatic
[ 87%] Built target ClothoidsDynamic
[100%] Built target PolynomialRootsDynamic
Install the project...
-- Install configuration: ""
-- Installing: /usr/local/lib/libPolynomialRoots.a
-- Installing: /usr/local/lib/libPolynomialRoots.so.2.0.0
-- Up-to-date: /usr/local/lib/libPolynomialRoots.so.2
-- Set runtime path of "/usr/local/lib/libPolynomialRoots.so.2.0.0" to "$ORIGIN"
-- Installing: /usr/local/include/PolynomialRoots/PolynomialRoots-Utils.hh
-- Installing: /usr/local/include/PolynomialRoots/PolynomialRoots.hh
-- Installing: /usr/local/lib/cmake/PolynomialRoots/PolynomialRootsTargets.cmake
-- Installing: /usr/local/lib/cmake/PolynomialRoots/PolynomialRootsTargets-noconfig.cmake
-- Installing: /usr/local/lib/cmake/PolynomialRoots/PolynomialRootsConfig.cmake
-- Installing: /usr/local/lib/cmake/PolynomialRoots/PolynomialRootsConfigVersion.cmake
-- Installing: /usr/local/lib/libClothoids.a
-- Installing: /usr/local/lib/libClothoids.so.3.0.0
-- Up-to-date: /usr/local/lib/libClothoids.so.3
-- Installing: /usr/local/include/Clothoids/AABBtree.hxx
-- Installing: /usr/local/include/Clothoids/BaseCurve_using.hxx
-- Installing: /usr/local/include/Clothoids/BaseCurve.hxx
-- Installing: /usr/local/include/Clothoids/Biarc.hxx
-- Installing: /usr/local/include/Clothoids/BiarcList.hxx
-- Installing: /usr/local/include/Clothoids/Circle.hxx
-- Installing: /usr/local/include/Clothoids/Clothoid.hxx
-- Installing: /usr/local/include/Clothoids/ClothoidList.hxx
-- Installing: /usr/local/include/Clothoids/Constants.hxx
-- Installing: /usr/local/include/Clothoids/Fresnel.hxx
-- Installing: /usr/local/include/Clothoids/G2lib.hxx
-- Installing: /usr/local/include/Clothoids/Line.hxx
-- Installing: /usr/local/include/Clothoids/PolyLine.hxx
-- Installing: /usr/local/include/Clothoids/Triangle2D.hxx
-- Installing: /usr/local/include/Clothoids/Types.hxx
-- Installing: /usr/local/include/Clothoids/ClothoidSpline-Interpolation.hxx
-- Installing: /usr/local/include/Clothoids/Clothoids.hh
-- Installing: /usr/local/lib/cmake/PolynomialRoots/ClothoidsTargets.cmake
-- Installing: /usr/local/lib/cmake/PolynomialRoots/ClothoidsTargets-noconfig.cmake
-- Installing: /usr/local/lib/cmake/PolynomialRoots/ClothoidsConfig.cmake
-- Installing: /usr/local/lib/cmake/PolynomialRoots/ClothoidsConfigVersion.cmake
[/code]
Last edit: 20 Oct 2024 06:34 by Aciera. Reason: Worked this time
20 Oct 2024 06:46 #312658 by Aciera
Looks like the next step also worked this time around:
user@user-iMac:~/linuxcnc_trajectory_planner/cmake$ cd build/
-- Configuring done
-- Generating done
user@user-iMac:~/linuxcnc_trajectory_planner/cmake/build$ make -j4
[ 12%] Building C object planner/CMakeFiles/tpmod.dir/home/user/linuxcnc_trajectory_planner/src/emc/tp/tpmod.c.o
[ 12%] Building C object motion/CMakeFiles/motmod.dir/home/user/linuxcnc_trajectory_planner/src/emc/kinematics/cubic.c.o
[ 12%] Building C object motion/CMakeFiles/motmod.dir/home/user/linuxcnc_trajectory_planner/src/emc/motion/axis.c.o
[ 12%] Building C object planner/CMakeFiles/tpmod.dir/home/user/linuxcnc_trajectory_planner/src/emc/tp/tc.c.o
[ 15%] Building C object planner/CMakeFiles/tpmod.dir/home/user/linuxcnc_trajectory_planner/src/emc/tp/tcq.c.o
[ 18%] Building C object planner/CMakeFiles/tpmod.dir/home/user/linuxcnc_trajectory_planner/src/emc/tp/tp.c.o
[ 21%] Building C object motion/CMakeFiles/motmod.dir/home/user/linuxcnc_trajectory_planner/src/emc/motion/motion.c.o
[ 25%] Building C object planner/CMakeFiles/tpmod.dir/home/user/linuxcnc_trajectory_planner/src/emc/tp/spherical_arc.c.o
[ 28%] Building C object motion/CMakeFiles/motmod.dir/home/user/linuxcnc_trajectory_planner/src/emc/motion/command.c.o
[ 31%] Building C object planner/CMakeFiles/tpmod.dir/home/user/linuxcnc_trajectory_planner/src/emc/tp/blendmath.c.o
[ 34%] Building C object motion/CMakeFiles/motmod.dir/home/user/linuxcnc_trajectory_planner/src/emc/motion/control.c.o
[ 37%] Building C object motion/CMakeFiles/motmod.dir/home/user/linuxcnc_trajectory_planner/src/emc/motion/simple_tp.c.o
[ 40%] Building C object planner/CMakeFiles/tpmod.dir/home/user/linuxcnc_trajectory_planner/src/emc/nml_intf/emcpose.c.o
[ 43%] Building C object planner/CMakeFiles/tpmod.dir/home/user/linuxcnc_trajectory_planner/src/libnml/posemath/_posemath.c.o
[ 46%] Building C object motion/CMakeFiles/motmod.dir/home/user/linuxcnc_trajectory_planner/src/emc/motion/emcmotutil.c.o
[ 50%] Building C object planner/CMakeFiles/tpmod.dir/home/user/linuxcnc_trajectory_planner/src/libnml/posemath/sincos.c.o
[ 53%] Building C object motion/CMakeFiles/motmod.dir/home/user/linuxcnc_trajectory_planner/src/emc/motion/stashf.c.o
[ 56%] Building C object motion/CMakeFiles/motmod.dir/home/user/linuxcnc_trajectory_planner/src/emc/motion/dbuf.c.o
[ 59%] Building CXX object motion/CMakeFiles/motmod.dir/home/user/linuxcnc_trajectory_planner/src/emc/motion/vector.cpp.o
[ 62%] Building CXX object motion/CMakeFiles/motmod.dir/home/user/linuxcnc_trajectory_planner/src/emc/motion/optimizer.cpp.o
[ 65%] Building C object motion/CMakeFiles/motmod.dir/home/user/linuxcnc_trajectory_planner/src/emc/tp/tc.c.o
[ 68%] Linking C shared library tpmod.so
[ 68%] Built target tpmod
[ 71%] Building C object motion/CMakeFiles/motmod.dir/home/user/linuxcnc_trajectory_planner/src/emc/tp/tcq.c.o
[ 75%] Building C object motion/CMakeFiles/motmod.dir/home/user/linuxcnc_trajectory_planner/src/emc/tp/spherical_arc.c.o
[ 78%] Building C object motion/CMakeFiles/motmod.dir/home/user/linuxcnc_trajectory_planner/src/emc/tp/blendmath.c.o
[ 81%] Building C object motion/CMakeFiles/motmod.dir/home/user/linuxcnc_trajectory_planner/src/emc/nml_intf/emcpose.c.o
[ 84%] Building C object motion/CMakeFiles/motmod.dir/home/user/linuxcnc_trajectory_planner/src/libnml/posemath/_posemath.c.o
[ 87%] Building C object motion/CMakeFiles/motmod.dir/home/user/linuxcnc_trajectory_planner/src/libnml/posemath/sincos.c.o
[ 90%] Building CXX object motion/CMakeFiles/motmod.dir/__/tinyspline/src/tinysplinecxx.cxx.o
[ 93%] Building C object motion/CMakeFiles/motmod.dir/__/tinyspline/src/tinyspline.c.o
[ 96%] Building C object motion/CMakeFiles/motmod.dir/__/tinyspline/src/parson.c.o
[100%] Linking CXX shared library motmod.so
[100%] Built target motmod
user@user-iMac:~/linuxcnc_trajectory_planner/cmake/build$ make install
Consolidate compiler generated dependencies of target motmod
[ 68%] Built target motmod
Consolidate compiler generated dependencies of target tpmod
[100%] Built target tpmod
-- Installing: /home/user/linuxcnc_trajectory_planner/cmake/motion/../../rtlib/motmod.so
-- Installing: /home/user/linuxcnc_trajectory_planner/cmake/planner/../../rtlib/tpmod.so
-- Set runtime path of "/home/user/linuxcnc_trajectory_planner/cmake/planner/../../rtlib/tpmod.so" to ""
20 Oct 2024 06:51 #312661 by Aciera
However when I run 'build.sh' I get a different error when I try to launch axis-mm:
user@user-iMac:~/linuxcnc_trajectory_planner/cmake$ ./build.sh
Reading 203/203 dependency files
Done reading dependencies
Reading 266/266 realtime dependency files
Done reading realtime dependencies
You now need to run 'sudo make setuid' in order to run in place with access to hardware.
-- Configuring done
-- Generating done
[ 31%] Built target tpmod
-- Up-to-date: /home/user/linuxcnc_trajectory_planner/cmake/motion/../../rtlib/motmod.so
-- Up-to-date: /home/user/linuxcnc_trajectory_planner/cmake/planner/../../rtlib/tpmod.so
linuxcncsvr (2248433) emcsvr: machine 'LinuxCNC-HAL-SIM-AXIS'  version '1.1'
tpmod: dlopen: liblinuxcnchal.so.0: cannot open shared object file: No such file or directory
<commandline>:0: waitpid failed /home/user/linuxcnc_trajectory_planner/bin/rtapi_app tpmod
<commandline>:0: /home/user/linuxcnc_trajectory_planner/bin/rtapi_app exited without becoming ready
<commandline>:0: insmod for tpmod failed, returned -1
milltask (2248448) task: machine 'LinuxCNC-HAL-SIM-AXIS'  version '1.1'
halui (2248450) halui: machine 'LinuxCNC-HAL-SIM-AXIS'  version '1.1'
motmod: dlopen: liblinuxcnchal.so.0: cannot open shared object file: No such file or directory
and
20 Oct 2024 07:08 #312666 by Aciera
So I just recreated whole process again in a new cloned directory and i get the same error in the end.
  • Grotius
  • Platinum Member
  • Platinum Member
20 Oct 2024 09:07 - 20 Oct 2024 09:17 #312676 by Grotius
 Hi Arciera,
It looks like compiling goes ok.
But installing goes wrong.
Is your install directory the same as mine? I see that's different. You use : user@user-iMac:
It wan't to install the motdot.so and the tpmod.so to a non-exsisting filepath.
I expect the cmake used my configuration, this can occur when the build dir was not empty.
This can happen if i am lazy to not use the ./gitignore files. Where the build dir's are not uploaded containing my build configuration
wich includes also filepaths.
To run it directly, you can try to copy (overwrite) the motmod.so manually to the linuxcnc rtlib. The modified motmod.so is here:
~/linuxcnc_trajectory_planner/cmake/build/motion
Otherwise you can try:
1. remove the CMakeLists.txt.user configuration file you see in the ~/linuxcnc_trajectory_planner/cmake dir.
2. Try it again, create a new build dir in the ~/linuxcnc_trajectory_planner/cmake do the cmake .. & make -j4 && make install.
Ok good luck.
Last edit: 20 Oct 2024 09:17 by Grotius.
Time to create page: 0.236 seconds
