Original Gmoccopy setting all gone
1 year 10 months ago #315907 by raychar
Replied by raychar on topic Original Gmoccopy setting all gone
> With added null.ngc files and nc_files path, the said error removed
> however, the axix cannot be run still persists, as showed in first attachemts,  "joint 1 following error" appears whenever axis button is clicked. How can i resolve it?
> This time, i installed the r8168 driver for the Realtek network card as per the forum information
> The latency test and latency-histogram results are shown in second and third attachments, the latter one seems have no improvement?
  • Moderator
  • Moderator
1 year 10 months ago #315919 by tommylight
Replied by tommylight on topic Original Gmoccopy setting all gone
Use
latency-histogram --nobase --sbinsize 1000 --show
There are a lot of excursions out of the visible area.
1 year 10 months ago #315940 by rodw
Replied by rodw on topic Original Gmoccopy setting all gone
Try setting isolcpus=1
I use grub-customizer to do this. It is installed on the linuxcnc ISO's
1 year 10 months ago #315959 by raychar
Use
first captured picture show immediate after running, the next one is after waiting for 1~2 minutes
  • Moderator
  • Moderator
1 year 10 months ago #315961 by tommylight
Those are terribly horrible results ! :)
Was latency better before installing the DKMS drivers? Why and by who were you told to install DKMS?
If i recall correctly you had dropped link to Mesa board, but they were not from network issues, they were from huge latency issues, is this that topic?
Did you disable stuff in BIOS?
How much memory does the PC have?
1 year 10 months ago #316023 by raychar
>Not quite understanding your meanings. The PC is of 2Gb memory.
>Now I replace the computer with the old hard drive which stored old version Linuxcnc 2.8.4, for perserving purpose, no Linux undates/upgrades and network drive update on it. The latency test runs, attached are two pictures and the last picture shows  screen that the axis run without much problems
Time to create page: 1.211 seconds
