Original Gmoccopy setting all gone
1 year 11 months ago #315543 by raychar
Replied by raychar on topic Original Gmoccopy setting all gone
Re: Latency issues with new os:
forum.linuxcnc.org/ethercat/54144-perfor...-9-3-bookworm#312257
Re: glade
It's a program to build glade user interfaces. If you don't want to install it just post the file here and I'll try to update it for you.
Attached the ui file, please help to update. Also, after running linuxcnc -l in terminal, the error message is as in attachment
1 year 11 months ago #315544 by raychar
Missed in last message, the gvcp-panel.ui here
1 year 11 months ago - 1 year 11 months ago #315546 by raychar
Does the 7i76E have field power ?
There is field power. Single power supply for it and VIN, of 12V. Everythng performed well before new debian version use .
Last edit: 1 year 11 months ago by raychar.
1 year 11 months ago #315547 by Aciera
Replied by Aciera on topic Original Gmoccopy setting all gone
Here is the updated 'gvcp-panel.ui':
File Name: gvcp-panel.ui
File Size:5 KB
1 year 11 months ago #315559 by raychar
Thanks for the new ui file, after replacing with it and opening again, still doesn't work, please see the first attachment, the right hand side is 3.4.8 new version, the axis can't move (left side 3.0.91 is old version for comparison). Still many other problems.., furthermore, for latency problem, I hesitiate to update network card driver as my sources.list contents are a liitle bit different from what the links' information mentioned
1 year 11 months ago - 1 year 11 months ago #315563 by Aciera
Looks like your config is looking for a directory that is no longer there:
emc/task/emctask.cc 68: interp_error: Unable to open file </home/raychar/linuxcnc/nc_files/null.ngc> Unable to open file </home/raychar/linuxcnc/nc_files/null.ngc> can't open /home/raychar/linuxcnc/nc_files/null.ngc
[edit]
I'm not aware of a file 'null.ngc' in a regular installation so maybe that is something you have customized in the previous version.
Last edit: 1 year 11 months ago by Aciera.
Time to create page: 0.974 seconds
