- Thank you received: 2177
Original Gmoccopy setting all gone
1 year 11 months ago #315460
Replied by Aciera on topic Original Gmoccopy setting all gone
Run from terminal again and post the output as there are likely other python2/gtk2 issues..
- raychar
1 year 11 months ago #315468
by raychar
Replied by raychar on topic Original Gmoccopy setting all gone
Also, by running linuxcnc -l in terminal, the message found as listed in attachment. However, if I replace the old mSATA drive which has with old version Linuxcnc on this same computer, everything works fine. Don't know why everything goes wrong now including the latency test
1 year 11 months ago #315470
New operating system and new Linuxcnc version are expected to give you different behavior.
As for the config not starting, uncomment these lines in your ini and try again:
You will likely need to update 'gvcp-panel.ui', opening the file in glade and saving again might already do the trick.
EMBED_TAB_NAME = Center_panel
EMBED_TAB_COMMAND = gladevcp -c gladevcp -H gvcp_call_list.hal -x {XID} gvcp-panel.ui
- raychar
1 year 11 months ago #315477
by raychar
After doing the lines' uncommenting, still not work, as shown in attached error message. Furthermore, i don't know how to opening the file in glade to do upgrading the 'gvcp-panel.ui' file? where is glade ? Also, i don't know why my hardware now runs with the latency problem, this showed in error message and also when I run latency test, previously this did'nt happen.
(my mini computer is of :
Intel Celeron(R) CPU J1800 @ 2.41Ghz
RAM: 2G, Storage: 512 mSATA drive)
1 year 11 months ago #315478
Re: Latency issues with new os:
forum.linuxcnc.org/ethercat/54144-perfor...-9-3-bookworm#312257
Re: glade
It's a program to build glade user interfaces. If you don't want to install it just post the file here and I'll try to update it for you.
Re: glade
- Thank you received: 7491
1 year 11 months ago #315482
Replied by tommylight on topic Original Gmoccopy setting all gone
Does the 7i76E have field power ?
Time to create page: 1.215 seconds
