- Thank you received: 905
I was under the impression that LCNC already disables feed-hold in the background during tapping or other spindle-synchronized movements. I think activating feed-hold has no effect until the tool is back at the retract plane. Which is why I didn't think adding feed-hold disable feature to the s-curve Tp was necessary.Adaptive feed and feed hold are core to how plasmac for plasma machines operates. However it does not use the gcode on/off capabilities that I have seen.
feed-hold issued during a tapping cycle could be catastrophic as it just stops xyz motion and does nothing to spindle. Feed-inhibit would be appropriate then as it alllows synch motion as used in tapping to complete.
Adaptive feed along with external offsets allows for some cool cut recovery operations on a plasma or probably any jet cutting machine (e.g. Laser or water jet)
Thank you for your answer.
I now understand every parameter and tested a little.
One thing I don't like. A given gcode with G64 P0.1 (mm) with an 90 degree edge. The small line upwards is 0.1 mm right of the edge. Your scurve tp sets a radius of 0.1 mm and the default tp sets a radius so that the distance between the blended path and the original path is not greater then 0.1 mm. I always set with a P value the maximum allowed deviation of a given path. So now I am not really sure. Can I just calculate something?
