- Thank you received: 286
I've never used a feed-hold disable function; I suspect it's a legacy feature intended for machines run by operators who are not 'allowed' to really manipulate the controls. Or the programmer sees a feature to be cut where feed-hold would lead to issues (drill/tool rubbing and work-hardening the part) and turns off feed hold for that program segment.For awareness:
The scurve planner has some behaviour changes around:
motion.feed-hold
motion.adaptove-feed
Under the standard planner per documentation the effects of these pins can be enable or disabled through the use of M53 and M52 respectively. These M codes are not supported under scurve. The effects of these pins are always active.
If this departure from current behaviour is material and of concern then we would be interested to understand what the "real world" down sides are to this implementation.
Thanks - James.
At the risk of repeating myself:
Grotius is like a heat seeking missile, he locks on to something and does not stop!
Thank you Grotius.
In this case, the missile orbited earth at least 15 times and probably once around Mars before hitting the Scurve target!
I am in awe with Grotius's tenacity over many years on this!
