- Thank you received: 2349
Don’t make that assumption re feedhold. And tapping. The planner is taking things direct from the Hal pin. Not from the lcnc motmod module.
it needs to be explicitly tested. Unless someone has done so already and can confirm what the behaviour is.
And that behaviour continues under scurve planner? That was what I was referring to. Not what standard planner does.
I can confirm that LCNC 2.10 disables feed-hold while synchronized motion is in progress. FH has no effect during a G33 or G33.1 command until after the synch move is complete.
