7I97T joint following error
21 Feb 2025 20:26 #322227 by PCW
Replied by PCW on topic 7I97T joint following error
Can you post your hal/ini files?
21 Feb 2025 23:38 #322245 by Tinker
Replied by Tinker on topic 7I97T joint following error
They should be in the initial post, let me know if they are not please.
22 Feb 2025 00:25 #322247 by PCW
Can you run this command (in a terminal) when LinuxCNC is running, has no faults and you
expect some analog output?
halcmd show all > all,txt
And the post all.txt here.
22 Feb 2025 00:45 #322248 by Tinker
30 bit OUT TRUE hm2_7i97.0.gpio.024.in
30 bit OUT FALSE hm2_7i97.0.gpio.024.in_not
30 bit OUT TRUE hm2_7i97.0.gpio.025.in
30 bit OUT FALSE hm2_7i97.0.gpio.025.in_not
30 bit OUT TRUE hm2_7i97.0.gpio.026.in
30 bit OUT FALSE hm2_7i97.0.gpio.026.in_not
30 bit OUT TRUE hm2_7i97.0.gpio.027.in
30 bit OUT FALSE hm2_7i97.0.gpio.027.in_not
30 bit OUT TRUE hm2_7i97.0.gpio.028.in
30 bit OUT FALSE hm2_7i97.0.gpio.028.in_not
30 bit OUT FALSE hm2_7i97.0.gpio.029.in
30 bit OUT TRUE hm2_7i97.0.gpio.029.in_not
30 bit OUT TRUE hm2_7i97.0.gpio.030.in
30 bit OUT FALSE hm2_7i97.0.gpio.030.in_not
30 bit OUT TRUE hm2_7i97.0.gpio.031.in
30 bit OUT FALSE hm2_7i97.0.gpio.031.in_not
30 bit IN FALSE hm2_7i97.0.gpio.031.out
30 bit OUT FALSE hm2_7i97.0.gpio.032.in
30 bit OUT TRUE hm2_7i97.0.gpio.032.in_not
30 bit IN FALSE hm2_7i97.0.gpio.032.out
30 bit OUT TRUE hm2_7i97.0.gpio.033.in
30 bit OUT FALSE hm2_7i97.0.gpio.033.in_not
30 bit IN FALSE hm2_7i97.0.gpio.033.out
30 bit OUT TRUE hm2_7i97.0.gpio.034.in
30 bit OUT FALSE hm2_7i97.0.gpio.034.in_not
30 bit IN FALSE hm2_7i97.0.gpio.034.out
30 bit OUT TRUE hm2_7i97.0.gpio.035.in
30 bit OUT FALSE hm2_7i97.0.gpio.035.in_not
30 bit IN FALSE hm2_7i97.0.gpio.035.out
30 bit OUT TRUE hm2_7i97.0.gpio.036.in
30 bit OUT FALSE hm2_7i97.0.gpio.036.in_not
30 bit IN FALSE hm2_7i97.0.gpio.036.out
30 bit OUT TRUE hm2_7i97.0.gpio.037.in
30 bit OUT FALSE hm2_7i97.0.gpio.037.in_not
30 bit IN FALSE hm2_7i97.0.gpio.037.out
30 bit OUT TRUE hm2_7i97.0.gpio.038.in
30 bit OUT FALSE hm2_7i97.0.gpio.038.in_not
30 bit IN FALSE hm2_7i97.0.gpio.038.out
30 bit OUT TRUE hm2_7i97.0.gpio.039.in
30 bit OUT FALSE hm2_7i97.0.gpio.039.in_not
30 bit IN FALSE hm2_7i97.0.gpio.039.out
30 bit OUT TRUE hm2_7i97.0.gpio.040.in
30 bit OUT FALSE hm2_7i97.0.gpio.040.in_not
30 bit IN FALSE hm2_7i97.0.gpio.040.out
30 bit OUT TRUE hm2_7i97.0.gpio.041.in
30 bit OUT FALSE hm2_7i97.0.gpio.041.in_not
30 bit IN FALSE hm2_7i97.0.gpio.041.out
30 bit OUT TRUE hm2_7i97.0.gpio.042.in
30 bit OUT FALSE hm2_7i97.0.gpio.042.in_not
30 bit IN FALSE hm2_7i97.0.gpio.042.out
30 bit OUT TRUE hm2_7i97.0.gpio.043.in
30 bit OUT FALSE hm2_7i97.0.gpio.043.in_not
30 bit IN FALSE hm2_7i97.0.gpio.043.out
30 bit OUT TRUE hm2_7i97.0.gpio.044.in
30 bit OUT FALSE hm2_7i97.0.gpio.044.in_not
30 bit IN FALSE hm2_7i97.0.gpio.044.out
30 bit OUT TRUE hm2_7i97.0.gpio.045.in
30 bit OUT FALSE hm2_7i97.0.gpio.045.in_not
30 bit IN FALSE hm2_7i97.0.gpio.045.out
30 bit OUT TRUE hm2_7i97.0.gpio.046.in
30 bit OUT FALSE hm2_7i97.0.gpio.046.in_not
30 bit IN FALSE hm2_7i97.0.gpio.046.out
30 bit OUT TRUE hm2_7i97.0.gpio.047.in
30 bit OUT FALSE hm2_7i97.0.gpio.047.in_not
30 bit IN FALSE hm2_7i97.0.gpio.047.out
30 bit OUT TRUE hm2_7i97.0.gpio.048.in
30 bit OUT FALSE hm2_7i97.0.gpio.048.in_not
30 bit IN FALSE hm2_7i97.0.gpio.048.out
30 bit OUT TRUE hm2_7i97.0.gpio.049.in
30 bit OUT FALSE hm2_7i97.0.gpio.049.in_not
30 bit IN FALSE hm2_7i97.0.gpio.049.out
30 bit OUT TRUE hm2_7i97.0.gpio.050.in
30 bit OUT FALSE hm2_7i97.0.gpio.050.in_not
30 bit IN FALSE hm2_7i97.0.gpio.050.out
30 s32 OUT 1 hm2_7i97.0.inmux.00.enc0-count
30 bit IN FALSE hm2_7i97.0.inmux.00.enc0-reset
30 s32 OUT 1 hm2_7i97.0.inmux.00.enc1-count
30 bit IN FALSE hm2_7i97.0.inmux.00.enc1-reset
30 s32 OUT 0 hm2_7i97.0.inmux.00.enc2-count
30 bit IN FALSE hm2_7i97.0.inmux.00.enc2-reset
30 s32 OUT 0 hm2_7i97.0.inmux.00.enc3-count
30 bit IN FALSE hm2_7i97.0.inmux.00.enc3-reset
30 bit OUT TRUE hm2_7i97.0.inmux.00.input-00
30 bit OUT FALSE hm2_7i97.0.inmux.00.input-00-not ==> plus-minus-home-joint-0
30 bit IN FALSE hm2_7i97.0.inmux.00.input-00-slow
30 bit OUT TRUE hm2_7i97.0.inmux.00.input-01
30 bit OUT FALSE hm2_7i97.0.inmux.00.input-01-not ==> minus-home-joint-1
30 bit IN FALSE hm2_7i97.0.inmux.00.input-01-slow
30 bit OUT TRUE hm2_7i97.0.inmux.00.input-02
30 bit OUT FALSE hm2_7i97.0.inmux.00.input-02-not ==> pos-limit-joint-1
30 bit IN FALSE hm2_7i97.0.inmux.00.input-02-slow
30 bit OUT TRUE hm2_7i97.0.inmux.00.input-03
30 bit OUT FALSE hm2_7i97.0.inmux.00.input-03-not ==> plus-home-joint-2
30 bit IN FALSE hm2_7i97.0.inmux.00.input-03-slow
30 bit OUT TRUE hm2_7i97.0.inmux.00.input-04
30 bit OUT FALSE hm2_7i97.0.inmux.00.input-04-not ==> neg-limit-joint-2
30 bit IN FALSE hm2_7i97.0.inmux.00.input-04-slow
30 bit OUT FALSE hm2_7i97.0.inmux.00.input-05
30 bit OUT TRUE hm2_7i97.0.inmux.00.input-05-not
30 bit IN FALSE hm2_7i97.0.inmux.00.input-05-slow
30 bit OUT FALSE hm2_7i97.0.inmux.00.input-06
30 bit OUT TRUE hm2_7i97.0.inmux.00.input-06-not
30 bit IN FALSE hm2_7i97.0.inmux.00.input-06-slow
30 bit OUT FALSE hm2_7i97.0.inmux.00.input-07
30 bit OUT TRUE hm2_7i97.0.inmux.00.input-07-not
30 bit IN FALSE hm2_7i97.0.inmux.00.input-07-slow
30 bit OUT FALSE hm2_7i97.0.inmux.00.input-08
30 bit OUT TRUE hm2_7i97.0.inmux.00.input-08-not
30 bit IN FALSE hm2_7i97.0.inmux.00.input-08-slow
30 bit OUT FALSE hm2_7i97.0.inmux.00.input-09
30 bit OUT TRUE hm2_7i97.0.inmux.00.input-09-not
30 bit IN FALSE hm2_7i97.0.inmux.00.input-09-slow
30 bit OUT FALSE hm2_7i97.0.inmux.00.input-10
30 bit OUT TRUE hm2_7i97.0.inmux.00.input-10-not
30 bit IN FALSE hm2_7i97.0.inmux.00.input-10-slow
30 bit OUT FALSE hm2_7i97.0.inmux.00.input-11
30 bit OUT TRUE hm2_7i97.0.inmux.00.input-11-not
30 bit IN FALSE hm2_7i97.0.inmux.00.input-11-slow
30 bit OUT FALSE hm2_7i97.0.inmux.00.input-12
30 bit OUT TRUE hm2_7i97.0.inmux.00.input-12-not
30 bit IN FALSE hm2_7i97.0.inmux.00.input-12-slow
30 bit OUT FALSE hm2_7i97.0.inmux.00.input-13
30 bit OUT TRUE hm2_7i97.0.inmux.00.input-13-not
30 bit IN FALSE hm2_7i97.0.inmux.00.input-13-slow
30 bit OUT FALSE hm2_7i97.0.inmux.00.input-14
30 bit OUT TRUE hm2_7i97.0.inmux.00.input-14-not
30 bit IN FALSE hm2_7i97.0.inmux.00.input-14-slow
30 bit OUT FALSE hm2_7i97.0.inmux.00.input-15
30 bit OUT TRUE hm2_7i97.0.inmux.00.input-15-not
30 bit IN FALSE hm2_7i97.0.inmux.00.input-15-slow
30 bit OUT TRUE hm2_7i97.0.inmux.00.raw-input-00
30 bit OUT FALSE hm2_7i97.0.inmux.00.raw-input-00-not
30 bit OUT TRUE hm2_7i97.0.inmux.00.raw-input-01
30 bit OUT FALSE hm2_7i97.0.inmux.00.raw-input-01-not
30 bit OUT TRUE hm2_7i97.0.inmux.00.raw-input-02
30 bit OUT FALSE hm2_7i97.0.inmux.00.raw-input-02-not
30 bit OUT TRUE hm2_7i97.0.inmux.00.raw-input-03
30 bit OUT FALSE hm2_7i97.0.inmux.00.raw-input-03-not
30 bit OUT TRUE hm2_7i97.0.inmux.00.raw-input-04
30 bit OUT FALSE hm2_7i97.0.inmux.00.raw-input-04-not
30 bit OUT FALSE hm2_7i97.0.inmux.00.raw-input-05
30 bit OUT TRUE hm2_7i97.0.inmux.00.raw-input-05-not
30 bit OUT FALSE hm2_7i97.0.inmux.00.raw-input-06
30 bit OUT TRUE hm2_7i97.0.inmux.00.raw-input-06-not
30 bit OUT FALSE hm2_7i97.0.inmux.00.raw-input-07
30 bit OUT TRUE hm2_7i97.0.inmux.00.raw-input-07-not
30 bit OUT FALSE hm2_7i97.0.inmux.00.raw-input-08
30 bit OUT TRUE hm2_7i97.0.inmux.00.raw-input-08-not
30 bit OUT FALSE hm2_7i97.0.inmux.00.raw-input-09
30 bit OUT TRUE hm2_7i97.0.inmux.00.raw-input-09-not
30 bit OUT FALSE hm2_7i97.0.inmux.00.raw-input-10
30 bit OUT TRUE hm2_7i97.0.inmux.00.raw-input-10-not
30 bit OUT FALSE hm2_7i97.0.inmux.00.raw-input-11
30 bit OUT TRUE hm2_7i97.0.inmux.00.raw-input-11-not
30 bit OUT FALSE hm2_7i97.0.inmux.00.raw-input-12
30 bit OUT TRUE hm2_7i97.0.inmux.00.raw-input-12-not
30 bit OUT FALSE hm2_7i97.0.inmux.00.raw-input-13
30 bit OUT TRUE hm2_7i97.0.inmux.00.raw-input-13-not
30 bit OUT FALSE hm2_7i97.0.inmux.00.raw-input-14
30 bit OUT TRUE hm2_7i97.0.inmux.00.raw-input-14-not
30 bit OUT FALSE hm2_7i97.0.inmux.00.raw-input-15
30 bit OUT TRUE hm2_7i97.0.inmux.00.raw-input-15-not
30 bit IN FALSE hm2_7i97.0.led.CR01
30 bit IN FALSE hm2_7i97.0.led.CR02
30 bit IN FALSE hm2_7i97.0.led.CR03
30 bit IN FALSE hm2_7i97.0.led.CR04
30 bit OUT FALSE hm2_7i97.0.packet-error
30 bit OUT FALSE hm2_7i97.0.packet-error-exceeded
30 s32 OUT 0 hm2_7i97.0.packet-error-level
30 u32 I/O 0x00000000 hm2_7i97.0.packet-error-total
30 bit IN FALSE hm2_7i97.0.pwmgen.00.enable <== joint-0-enable
30 float IN 0 hm2_7i97.0.pwmgen.00.value <== joint.0.output
30 bit IN FALSE hm2_7i97.0.pwmgen.01.enable <== joint-1-enable
30 float IN 0 hm2_7i97.0.pwmgen.01.value <== joint.1.output
30 bit IN FALSE hm2_7i97.0.pwmgen.02.enable <== joint-2-enable
30 float IN 0 hm2_7i97.0.pwmgen.02.value <== joint.2.output
30 bit IN FALSE hm2_7i97.0.pwmgen.03.enable
30 float IN 0 hm2_7i97.0.pwmgen.03.value
30 bit IN FALSE hm2_7i97.0.pwmgen.04.enable
30 float IN 0 hm2_7i97.0.pwmgen.04.value
30 bit IN FALSE hm2_7i97.0.pwmgen.05.enable
30 float IN 0 hm2_7i97.0.pwmgen.05.value
30 s32 OUT 0 hm2_7i97.0.read-request.time
30 s32 OUT 69157 hm2_7i97.0.read.time
30 bit IN FALSE hm2_7i97.0.ssr.00.invert-00
30 bit IN FALSE hm2_7i97.0.ssr.00.invert-01
30 bit IN FALSE hm2_7i97.0.ssr.00.invert-02
30 bit IN FALSE hm2_7i97.0.ssr.00.invert-03
30 bit IN FALSE hm2_7i97.0.ssr.00.invert-04
30 bit IN FALSE hm2_7i97.0.ssr.00.invert-05
30 bit IN FALSE hm2_7i97.0.ssr.00.out-00
30 bit IN FALSE hm2_7i97.0.ssr.00.out-01
30 bit IN FALSE hm2_7i97.0.ssr.00.out-02
30 bit IN FALSE hm2_7i97.0.ssr.00.out-03
30 bit IN FALSE hm2_7i97.0.ssr.00.out-04
30 bit IN FALSE hm2_7i97.0.ssr.00.out-05
30 u32 IN 0x000F4240 hm2_7i97.0.ssr.00.rate
30 bit I/O FALSE hm2_7i97.0.watchdog.has_bit
30 s32 OUT 5328 hm2_7i97.0.write.time
48 float IN 0 ini.0.backlash
48 float IN 1 ini.0.ferror
48 float IN 0 ini.0.home
48 float IN 0 ini.0.home_offset
48 s32 IN 999 ini.0.home_sequence
48 float IN 200 ini.0.max_acceleration
48 float IN 1 ini.0.max_limit
48 float IN 200 ini.0.max_velocity
48 float IN 0.001 ini.0.min_ferror
48 float IN 0 ini.0.min_limit
48 float IN 0 ini.1.backlash
48 float IN 1 ini.1.ferror
48 float IN 0 ini.1.home
48 float IN 0 ini.1.home_offset
48 s32 IN 999 ini.1.home_sequence
48 float IN 200 ini.1.max_acceleration
48 float IN 1 ini.1.max_limit
48 float IN 200 ini.1.max_velocity
48 float IN 0.001 ini.1.min_ferror
48 float IN 0 ini.1.min_limit
48 float IN 0 ini.2.backlash
48 float IN 1 ini.2.ferror
48 float IN 0 ini.2.home
48 float IN 0 ini.2.home_offset
48 s32 IN 999 ini.2.home_sequence
48 float IN 200 ini.2.max_acceleration
48 float IN 1 ini.2.max_limit
48 float IN 200 ini.2.max_velocity
48 float IN 0.001 ini.2.min_ferror
48 float IN 0 ini.2.min_limit
48 float IN 0 ini.a.max_acceleration
48 float IN 0 ini.a.max_limit
48 float IN 0 ini.a.max_velocity
48 float IN 0 ini.a.min_limit
48 float IN 0 ini.b.max_acceleration
48 float IN 0 ini.b.max_limit
48 float IN 0 ini.b.max_velocity
48 float IN 0 ini.b.min_limit
48 float IN 0 ini.c.max_acceleration
48 float IN 0 ini.c.max_limit
48 float IN 0 ini.c.max_velocity
48 float IN 0 ini.c.min_limit
48 bit IN TRUE ini.traj_arc_blend_enable
48 bit IN FALSE ini.traj_arc_blend_fallback_enable
48 float IN 4 ini.traj_arc_blend_gap_cycles
48 s32 IN 50 ini.traj_arc_blend_optimization_depth
48 float IN 100 ini.traj_arc_blend_ramp_freq
48 float IN 0.1 ini.traj_arc_blend_tangent_kink_ratio
48 float IN 1e+99 ini.traj_default_acceleration
48 float IN 1 ini.traj_default_velocity
48 float IN 1e+99 ini.traj_max_acceleration
48 float IN 5.1 ini.traj_max_velocity
48 float IN 0 ini.u.max_acceleration
48 float IN 0 ini.u.max_limit
48 float IN 0 ini.u.max_velocity
48 float IN 0 ini.u.min_limit
48 float IN 0 ini.v.max_acceleration
48 float IN 0 ini.v.max_limit
48 float IN 0 ini.v.max_velocity
48 float IN 0 ini.v.min_limit
48 float IN 0 ini.w.max_acceleration
48 float IN 0 ini.w.max_limit
48 float IN 0 ini.w.max_velocity
48 float IN 0 ini.w.min_limit
48 float IN 200 ini.x.max_acceleration
48 float IN 1 ini.x.max_limit
48 float IN 200 ini.x.max_velocity
48 float IN 0 ini.x.min_limit
48 float IN 200 ini.y.max_acceleration
48 float IN 1 ini.y.max_limit
48 float IN 200 ini.y.max_velocity
48 float IN 0 ini.y.min_limit
48 float IN 200 ini.z.max_acceleration
48 float IN 1 ini.z.max_limit
48 float IN 200 ini.z.max_velocity
48 float IN 0 ini.z.min_limit
4 bit OUT FALSE iocontrol.0.coolant-flood
4 bit OUT FALSE iocontrol.0.coolant-mist
4 bit OUT TRUE iocontrol.0.emc-abort
4 bit IN FALSE iocontrol.0.emc-abort-ack
4 bit IN TRUE iocontrol.0.emc-enable-in <== estop-loopback
4 s32 OUT 7 iocontrol.0.emc-reason
4 bit OUT TRUE iocontrol.0.lube
4 bit IN FALSE iocontrol.0.lube_level
4 bit OUT FALSE iocontrol.0.start-change
4 bit IN FALSE iocontrol.0.start-change-ack
4 s32 OUT 4 iocontrol.0.state
4 bit OUT FALSE iocontrol.0.tool-change ==> tool-change-loop
4 bit IN FALSE iocontrol.0.tool-changed <== tool-change-loop
4 s32 OUT 0 iocontrol.0.tool-number
4 s32 OUT 0 iocontrol.0.tool-prep-index
4 s32 OUT 0 iocontrol.0.tool-prep-number
4 s32 OUT 0 iocontrol.0.tool-prep-pocket
4 bit OUT FALSE iocontrol.0.tool-prepare ==> tool-prep-loop
4 bit IN FALSE iocontrol.0.tool-prepared <== tool-prep-loop
4 bit IN FALSE iocontrol.0.toolchanger-clear-fault
4 bit IN FALSE iocontrol.0.toolchanger-fault
4 bit OUT FALSE iocontrol.0.toolchanger-fault-ack
4 bit OUT FALSE iocontrol.0.toolchanger-faulted
4 s32 IN 0 iocontrol.0.toolchanger-reason
4 bit OUT TRUE iocontrol.0.user-enable-out ==> estop-loopback
4 bit OUT FALSE iocontrol.0.user-request-enable
23 float OUT 0 joint.0.acc-cmd
23 bit OUT TRUE joint.0.active
23 bit OUT FALSE joint.0.amp-enable-out ==> joint-0-enable
23 bit IN FALSE joint.0.amp-fault-in
23 float OUT 0 joint.0.backlash-corr
23 float OUT 0 joint.0.backlash-filt
23 float OUT 0 joint.0.backlash-vel
23 float OUT 0 joint.0.coarse-pos-cmd
23 bit OUT FALSE joint.0.error
23 float OUT 0 joint.0.f-error
23 float OUT 0.001 joint.0.f-error-lim
23 bit OUT FALSE joint.0.f-errored
23 bit OUT FALSE joint.0.faulted
23 float OUT 0 joint.0.free-pos-cmd
23 bit OUT FALSE joint.0.free-tp-enable
23 float OUT 0 joint.0.free-vel-lim
23 s32 OUT 0 joint.0.home-state
23 bit IN FALSE joint.0.home-sw-in <== plus-minus-home-joint-0
23 bit OUT FALSE joint.0.homed
23 bit OUT FALSE joint.0.homing
23 bit OUT TRUE joint.0.in-position
23 bit I/O FALSE joint.0.index-enable <=> joint-0-index-enable
23 float IN 1 joint.0.jog-accel-fraction
23 s32 IN 0 joint.0.jog-counts
23 bit IN FALSE joint.0.jog-enable
23 float IN 0 joint.0.jog-scale
23 bit IN FALSE joint.0.jog-vel-mode
23 bit OUT FALSE joint.0.kb-jog-active
23 float OUT 0 joint.0.motor-offset
23 float OUT -0.001175 joint.0.motor-pos-cmd ==> joint-0-pos-cmd
23 float IN -0.001175 joint.0.motor-pos-fb <== joint-0-pos-fb
23 bit OUT FALSE joint.0.neg-hard-limit
23 bit IN FALSE joint.0.neg-lim-sw-in <== plus-minus-home-joint-0
23 float OUT -0.001175 joint.0.pos-cmd
23 float OUT -0.001175 joint.0.pos-fb
23 bit OUT FALSE joint.0.pos-hard-limit
23 bit IN FALSE joint.0.pos-lim-sw-in <== plus-minus-home-joint-0
23 float OUT 0 joint.0.vel-cmd
23 bit OUT FALSE joint.0.wheel-jog-active
23 float OUT 0 joint.1.acc-cmd
23 bit OUT TRUE joint.1.active
23 bit OUT FALSE joint.1.amp-enable-out ==> joint-1-enable
23 bit IN FALSE joint.1.amp-fault-in
23 float OUT 0 joint.1.backlash-corr
23 float OUT 0 joint.1.backlash-filt
23 float OUT 0 joint.1.backlash-vel
23 float OUT 0 joint.1.coarse-pos-cmd
23 bit OUT FALSE joint.1.error
23 float OUT 0 joint.1.f-error
23 float OUT 0.001 joint.1.f-error-lim
23 bit OUT FALSE joint.1.f-errored
23 bit OUT FALSE joint.1.faulted
23 float OUT 0 joint.1.free-pos-cmd
23 bit OUT FALSE joint.1.free-tp-enable
23 float OUT 0 joint.1.free-vel-lim
23 s32 OUT 0 joint.1.home-state
23 bit IN FALSE joint.1.home-sw-in <== minus-home-joint-1
23 bit OUT FALSE joint.1.homed
23 bit OUT FALSE joint.1.homing
23 bit OUT TRUE joint.1.in-position
23 bit I/O FALSE joint.1.index-enable <=> joint-1-index-enable
23 float IN 1 joint.1.jog-accel-fraction
23 s32 IN 0 joint.1.jog-counts
23 bit IN FALSE joint.1.jog-enable
23 float IN 0 joint.1.jog-scale
23 bit IN FALSE joint.1.jog-vel-mode
23 bit OUT FALSE joint.1.kb-jog-active
23 float OUT 0 joint.1.motor-offset
23 float OUT 0 joint.1.motor-pos-cmd ==> joint-1-pos-cmd
23 float IN 0 joint.1.motor-pos-fb <== joint-1-pos-fb
23 bit OUT FALSE joint.1.neg-hard-limit
23 bit IN FALSE joint.1.neg-lim-sw-in <== minus-home-joint-1
23 float OUT 0 joint.1.pos-cmd
23 float OUT 0 joint.1.pos-fb
23 bit OUT FALSE joint.1.pos-hard-limit
23 bit IN FALSE joint.1.pos-lim-sw-in <== pos-limit-joint-1
23 float OUT 0 joint.1.vel-cmd
23 bit OUT FALSE joint.1.wheel-jog-active
23 float OUT 0 joint.2.acc-cmd
23 bit OUT TRUE joint.2.active
23 bit OUT FALSE joint.2.amp-enable-out ==> joint-2-enable
23 bit IN FALSE joint.2.amp-fault-in
23 float OUT 0 joint.2.backlash-corr
23 float OUT 0 joint.2.backlash-filt
23 float OUT 0 joint.2.backlash-vel
23 float OUT 0 joint.2.coarse-pos-cmd
23 bit OUT FALSE joint.2.error
23 float OUT 0 joint.2.f-error
23 float OUT 0.001 joint.2.f-error-lim
23 bit OUT FALSE joint.2.f-errored
23 bit OUT FALSE joint.2.faulted
23 float OUT 0 joint.2.free-pos-cmd
23 bit OUT FALSE joint.2.free-tp-enable
23 float OUT 0 joint.2.free-vel-lim
23 s32 OUT 0 joint.2.home-state
23 bit IN FALSE joint.2.home-sw-in <== plus-home-joint-2
23 bit OUT FALSE joint.2.homed
23 bit OUT FALSE joint.2.homing
23 bit OUT TRUE joint.2.in-position
23 bit I/O FALSE joint.2.index-enable <=> joint-2-index-enable
23 float IN 1 joint.2.jog-accel-fraction
23 s32 IN 0 joint.2.jog-counts
23 bit IN FALSE joint.2.jog-enable
23 float IN 0 joint.2.jog-scale
23 bit IN FALSE joint.2.jog-vel-mode
23 bit OUT FALSE joint.2.kb-jog-active
23 float OUT 0 joint.2.motor-offset
23 float OUT 0 joint.2.motor-pos-cmd ==> joint-2-pos-cmd
23 float IN 0 joint.2.motor-pos-fb <== joint-2-pos-fb
23 bit OUT FALSE joint.2.neg-hard-limit
23 bit IN FALSE joint.2.neg-lim-sw-in <== neg-limit-joint-2
23 float OUT 0 joint.2.pos-cmd
23 float OUT 0 joint.2.pos-fb
23 bit OUT FALSE joint.2.pos-hard-limit
23 bit IN FALSE joint.2.pos-lim-sw-in <== plus-home-joint-2
23 float OUT 0 joint.2.vel-cmd
23 bit OUT FALSE joint.2.wheel-jog-active
23 s32 OUT 82 motion-command-handler.time
23 s32 OUT 1598 motion-controller.time
23 float IN 1 motion.adaptive-feed
23 float IN 0 motion.analog-in-00
23 float IN 0 motion.analog-in-01
23 float IN 0 motion.analog-in-02
23 float IN 0 motion.analog-in-03
23 float OUT 0 motion.analog-out-00
23 float OUT 0 motion.analog-out-01
23 float OUT 0 motion.analog-out-02
23 float OUT 0 motion.analog-out-03
23 bit OUT FALSE motion.coord-error
23 bit OUT FALSE motion.coord-mode
23 float OUT 0 motion.current-vel
23 bit IN FALSE motion.digital-in-00
23 bit IN FALSE motion.digital-in-01
23 bit IN FALSE motion.digital-in-02
23 bit IN FALSE motion.digital-in-03
23 bit OUT FALSE motion.digital-out-00
23 bit OUT FALSE motion.digital-out-01
23 bit OUT FALSE motion.digital-out-02
23 bit OUT FALSE motion.digital-out-03
23 float OUT 0 motion.distance-to-go
23 bit IN TRUE motion.enable
23 bit OUT FALSE motion.eoffset-active
23 bit OUT FALSE motion.eoffset-limited
23 bit IN FALSE motion.feed-hold
23 float OUT 0 motion.feed-inches-per-minute
23 float OUT 0 motion.feed-inches-per-second
23 bit IN FALSE motion.feed-inhibit
23 float OUT 0 motion.feed-mm-per-minute
23 float OUT 0 motion.feed-mm-per-second
23 float OUT 0 motion.feed-upm
23 bit IN FALSE motion.homing-inhibit
23 bit OUT TRUE motion.in-position
23 bit OUT FALSE motion.is-all-homed
23 bit IN FALSE motion.jog-inhibit
23 bit OUT FALSE motion.jog-is-active
23 bit IN FALSE motion.jog-stop
23 bit IN FALSE motion.jog-stop-immediate
23 bit OUT FALSE motion.motion-enabled ==> motion-enable
23 s32 OUT 0 motion.motion-type
23 bit OUT FALSE motion.on-soft-limit
23 bit IN FALSE motion.probe-input
23 s32 OUT 0 motion.program-line
23 float OUT 0 motion.requested-vel
23 u32 OUT 0x000C33E2 motion.servo.last-period
23 bit OUT FALSE motion.teleop-mode
23 float OUT 0 motion.tooloffset.a
23 float OUT 0 motion.tooloffset.b
23 float OUT 0 motion.tooloffset.c
23 float OUT 0 motion.tooloffset.u
23 float OUT 0 motion.tooloffset.v
23 float OUT 0 motion.tooloffset.w
23 float OUT 0 motion.tooloffset.x
23 float OUT 0 motion.tooloffset.y
23 float OUT 0 motion.tooloffset.z
23 bit OUT FALSE motion.tp-reverse
33 float IN 0 pid.x.Dgain
33 float IN 0 pid.x.FF0
33 float IN 0 pid.x.FF1
33 float IN 0 pid.x.FF2
33 float IN 0 pid.x.FF3
33 float IN 0 pid.x.Igain
33 float IN 1 pid.x.Pgain
33 float IN 0 pid.x.bias
33 float IN -0.001175 pid.x.command <== joint-0-pos-cmd
33 float IN 0 pid.x.command-deriv
33 float IN 0 pid.x.deadband
33 s32 OUT 93 pid.x.do-pid-calcs.time
33 bit IN FALSE pid.x.enable <== joint-0-enable
33 float OUT 0 pid.x.error
33 bit IN TRUE pid.x.error-previous-target
33 float IN -0.001175 pid.x.feedback <== joint-0-pos-fb
33 float IN 0 pid.x.feedback-deriv
33 bit IN FALSE pid.x.index-enable <== joint-0-index-enable
33 float IN 0 pid.x.maxcmdD
33 float IN 0 pid.x.maxcmdDD
33 float IN 0 pid.x.maxcmdDDD
33 float IN 0 pid.x.maxerror
33 float IN 0 pid.x.maxerrorD
33 float IN 0 pid.x.maxerrorI
33 float IN 10 pid.x.maxoutput
33 float OUT 0 pid.x.output ==> joint.0.output
33 bit OUT FALSE pid.x.saturated
33 s32 OUT 0 pid.x.saturated-count
33 float OUT 0 pid.x.saturated-s
33 u32 I/O 0x00000032 pid.x.tune-cycles
33 float I/O 0.5 pid.x.tune-effort
33 bit IN FALSE pid.x.tune-mode
33 bit I/O FALSE pid.x.tune-start
33 u32 I/O 0x00000000 pid.x.tune-type
33 float IN 0 pid.y.Dgain
33 float IN 0 pid.y.FF0
33 float IN 0 pid.y.FF1
33 float IN 0 pid.y.FF2
33 float IN 0 pid.y.FF3
33 float IN 0 pid.y.Igain
33 float IN 1 pid.y.Pgain
33 float IN 0 pid.y.bias
33 float IN 0 pid.y.command <== joint-1-pos-cmd
33 float IN 0 pid.y.command-deriv
33 float IN 0 pid.y.deadband
33 s32 OUT 23 pid.y.do-pid-calcs.time
33 bit IN FALSE pid.y.enable <== joint-1-enable
33 float OUT 0 pid.y.error
33 bit IN TRUE pid.y.error-previous-target
33 float IN 0 pid.y.feedback <== joint-1-pos-fb
33 float IN 0 pid.y.feedback-deriv
33 bit IN FALSE pid.y.index-enable <== joint-1-index-enable
33 float IN 0 pid.y.maxcmdD
33 float IN 0 pid.y.maxcmdDD
33 float IN 0 pid.y.maxcmdDDD
33 float IN 0 pid.y.maxerror
33 float IN 0 pid.y.maxerrorD
33 float IN 0 pid.y.maxerrorI
33 float IN 10 pid.y.maxoutput
33 float OUT 0 pid.y.output ==> joint.1.output
33 bit OUT FALSE pid.y.saturated
33 s32 OUT 0 pid.y.saturated-count
33 float OUT 0 pid.y.saturated-s
33 u32 I/O 0x00000032 pid.y.tune-cycles
33 float I/O 0.5 pid.y.tune-effort
33 bit IN FALSE pid.y.tune-mode
33 bit I/O FALSE pid.y.tune-start
33 u32 I/O 0x00000000 pid.y.tune-type
33 float IN 0 pid.z.Dgain
33 float IN 0 pid.z.FF0
33 float IN 0 pid.z.FF1
33 float IN 0 pid.z.FF2
33 float IN 0 pid.z.FF3
33 float IN 0 pid.z.Igain
33 float IN 1 pid.z.Pgain
33 float IN 0 pid.z.bias
33 float IN 0 pid.z.command <== joint-2-pos-cmd
33 float IN 0 pid.z.command-deriv
33 float IN 0 pid.z.deadband
33 s32 OUT 35 pid.z.do-pid-calcs.time
33 bit IN FALSE pid.z.enable <== joint-2-enable
33 float OUT 0 pid.z.error
33 bit IN TRUE pid.z.error-previous-target
33 float IN 0 pid.z.feedback <== joint-2-pos-fb
33 float IN 0 pid.z.feedback-deriv
33 bit IN FALSE pid.z.index-enable <== joint-2-index-enable
33 float IN 0 pid.z.maxcmdD
33 float IN 0 pid.z.maxcmdDD
33 float IN 0 pid.z.maxcmdDDD
33 float IN 0 pid.z.maxerror
33 float IN 0 pid.z.maxerrorD
33 float IN 0 pid.z.maxerrorI
33 float IN 10 pid.z.maxoutput
33 float OUT 0 pid.z.output ==> joint.2.output
33 bit OUT FALSE pid.z.saturated
33 s32 OUT 0 pid.z.saturated-count
33 float OUT 0 pid.z.saturated-s
33 u32 I/O 0x00000032 pid.z.tune-cycles
33 float I/O 0.5 pid.z.tune-effort
33 bit IN FALSE pid.z.tune-mode
33 bit I/O FALSE pid.z.tune-start
33 u32 I/O 0x00000000 pid.z.tune-type
24 s32 OUT 69422 servo-thread.time
23 bit IN FALSE spindle.0.amp-fault-in
23 bit IN TRUE spindle.0.at-speed
23 bit OUT TRUE spindle.0.brake
23 bit OUT FALSE spindle.0.forward
23 bit I/O FALSE spindle.0.index-enable
23 bit IN FALSE spindle.0.inhibit
23 bit IN FALSE spindle.0.is-oriented
23 bit OUT FALSE spindle.0.locked
23 bit OUT FALSE spindle.0.on
23 bit OUT FALSE spindle.0.orient
23 float OUT 0 spindle.0.orient-angle
23 s32 IN 0 spindle.0.orient-fault
23 s32 OUT 0 spindle.0.orient-mode
23 bit OUT FALSE spindle.0.reverse
23 float IN 0 spindle.0.revs
23 float OUT 0 spindle.0.speed-cmd-rps
23 float IN 0 spindle.0.speed-in
23 float OUT 0 spindle.0.speed-out
23 float OUT 0 spindle.0.speed-out-abs
23 float OUT 0 spindle.0.speed-out-rps
23 float OUT 0 spindle.0.speed-out-rps-abs
Pin Aliases:
Alias Original Name
Signals:
Type Value Name (linked to)
bit TRUE estop-loopback
==> iocontrol.0.emc-enable-in
<== iocontrol.0.user-enable-out
bit FALSE joint-0-enable
==> hm2_7i97.0.pwmgen.00.enable
<== joint.0.amp-enable-out
==> pid.x.enable
bit FALSE joint-0-index-enable
<=> hm2_7i97.0.encoder.00.index-enable
<=> joint.0.index-enable
==> pid.x.index-enable
float -0.001175 joint-0-pos-cmd
<== joint.0.motor-pos-cmd
==> pid.x.command
float -0.001175 joint-0-pos-fb
<== hm2_7i97.0.encoder.00.position
==> joint.0.motor-pos-fb
==> pid.x.feedback
bit FALSE joint-1-enable
==> hm2_7i97.0.pwmgen.01.enable
<== joint.1.amp-enable-out
==> pid.y.enable
bit FALSE joint-1-index-enable
<=> hm2_7i97.0.encoder.01.index-enable
<=> joint.1.index-enable
==> pid.y.index-enable
float 0 joint-1-pos-cmd
<== joint.1.motor-pos-cmd
==> pid.y.command
float 0 joint-1-pos-fb
<== hm2_7i97.0.encoder.01.position
==> joint.1.motor-pos-fb
==> pid.y.feedback
bit FALSE joint-2-enable
==> hm2_7i97.0.pwmgen.02.enable
<== joint.2.amp-enable-out
==> pid.z.enable
bit FALSE joint-2-index-enable
<=> hm2_7i97.0.encoder.02.index-enable
<=> joint.2.index-enable
==> pid.z.index-enable
float 0 joint-2-pos-cmd
<== joint.2.motor-pos-cmd
==> pid.z.command
float 0 joint-2-pos-fb
<== hm2_7i97.0.encoder.02.position
==> joint.2.motor-pos-fb
==> pid.z.feedback
float 0 joint.0.output
==> hm2_7i97.0.pwmgen.00.value
<== pid.x.output
float 0 joint.1.output
==> hm2_7i97.0.pwmgen.01.value
<== pid.y.output
float 0 joint.2.output
==> hm2_7i97.0.pwmgen.02.value
<== pid.z.output
bit FALSE minus-home-joint-1
<== hm2_7i97.0.inmux.00.input-01-not
==> joint.1.home-sw-in
==> joint.1.neg-lim-sw-in
bit FALSE motion-enable
<== motion.motion-enabled
bit FALSE neg-limit-joint-2
<== hm2_7i97.0.inmux.00.input-04-not
==> joint.2.neg-lim-sw-in
bit FALSE plus-home-joint-2
<== hm2_7i97.0.inmux.00.input-03-not
==> joint.2.home-sw-in
==> joint.2.pos-lim-sw-in
bit FALSE plus-minus-home-joint-0
<== hm2_7i97.0.inmux.00.input-00-not
==> joint.0.home-sw-in
==> joint.0.neg-lim-sw-in
==> joint.0.pos-lim-sw-in
bit FALSE pos-limit-joint-1
<== hm2_7i97.0.inmux.00.input-02-not
==> joint.1.pos-lim-sw-in
bit FALSE tool-change-confirmed
<== hal_manualtoolchange.changed
bit FALSE tool-change-loop
<== iocontrol.0.tool-change
==> iocontrol.0.tool-changed
bit FALSE tool-change-request
==> hal_manualtoolchange.change
s32 0 tool-number
==> hal_manualtoolchange.number
bit FALSE tool-prep-loop
<== iocontrol.0.tool-prepare
==> iocontrol.0.tool-prepared
Parameters:
Owner Type Dir Value Name
30 bit RW FALSE hm2_7i97.0.encoder.00.counter-mode
30 bit RW TRUE hm2_7i97.0.encoder.00.filter
30 bit RW FALSE hm2_7i97.0.encoder.00.index-invert
30 bit RW FALSE hm2_7i97.0.encoder.00.index-mask
30 bit RW FALSE hm2_7i97.0.encoder.00.index-mask-invert
30 float RW 40000 hm2_7i97.0.encoder.00.scale
30 bit RW FALSE hm2_7i97.0.encoder.00.sel0.invert_output
30 bit RW FALSE hm2_7i97.0.encoder.00.sel0.is_opendrain
30 float RW 0.5 hm2_7i97.0.encoder.00.vel-timeout
30 bit RW FALSE hm2_7i97.0.encoder.01.counter-mode
30 bit RW TRUE hm2_7i97.0.encoder.01.filter
30 bit RW FALSE hm2_7i97.0.encoder.01.index-invert
30 bit RW FALSE hm2_7i97.0.encoder.01.index-mask
30 bit RW FALSE hm2_7i97.0.encoder.01.index-mask-invert
30 float RW 40000 hm2_7i97.0.encoder.01.scale
30 float RW 0.5 hm2_7i97.0.encoder.01.vel-timeout
30 bit RW FALSE hm2_7i97.0.encoder.02.counter-mode
30 bit RW TRUE hm2_7i97.0.encoder.02.filter
30 bit RW FALSE hm2_7i97.0.encoder.02.index-invert
30 bit RW FALSE hm2_7i97.0.encoder.02.index-mask
30 bit RW FALSE hm2_7i97.0.encoder.02.index-mask-invert
30 float RW 40000 hm2_7i97.0.encoder.02.scale
30 float RW 0.5 hm2_7i97.0.encoder.02.vel-timeout
30 bit RW FALSE hm2_7i97.0.encoder.03.counter-mode
30 bit RW TRUE hm2_7i97.0.encoder.03.filter
30 bit RW FALSE hm2_7i97.0.encoder.03.index-invert
30 bit RW FALSE hm2_7i97.0.encoder.03.index-mask
30 bit RW FALSE hm2_7i97.0.encoder.03.index-mask-invert
30 float RW 1 hm2_7i97.0.encoder.03.scale
30 float RW 0.5 hm2_7i97.0.encoder.03.vel-timeout
30 bit RW FALSE hm2_7i97.0.encoder.04.counter-mode
30 bit RW TRUE hm2_7i97.0.encoder.04.filter
30 bit RW FALSE hm2_7i97.0.encoder.04.index-invert
30 bit RW FALSE hm2_7i97.0.encoder.04.index-mask
30 bit RW FALSE hm2_7i97.0.encoder.04.index-mask-invert
30 float RW 1 hm2_7i97.0.encoder.04.scale
30 float RW 0.5 hm2_7i97.0.encoder.04.vel-timeout
30 bit RW FALSE hm2_7i97.0.encoder.05.counter-mode
30 bit RW TRUE hm2_7i97.0.encoder.05.filter
30 bit RW FALSE hm2_7i97.0.encoder.05.index-invert
30 bit RW FALSE hm2_7i97.0.encoder.05.index-mask
30 bit RW FALSE hm2_7i97.0.encoder.05.index-mask-invert
30 float RW 1 hm2_7i97.0.encoder.05.scale
30 float RW 0.5 hm2_7i97.0.encoder.05.vel-timeout
30 bit RW FALSE hm2_7i97.0.gpio.019.invert_output
30 bit RW FALSE hm2_7i97.0.gpio.019.is_opendrain
30 bit RW FALSE hm2_7i97.0.gpio.020.invert_output
30 bit RW FALSE hm2_7i97.0.gpio.020.is_opendrain
30 bit RW FALSE hm2_7i97.0.gpio.021.invert_output
30 bit RW FALSE hm2_7i97.0.gpio.021.is_opendrain
30 bit RW FALSE hm2_7i97.0.gpio.022.invert_output
30 bit RW FALSE hm2_7i97.0.gpio.022.is_opendrain
30 bit RW FALSE hm2_7i97.0.gpio.023.invert_output
30 bit RW FALSE hm2_7i97.0.gpio.023.is_opendrain
30 bit RW FALSE hm2_7i97.0.gpio.024.invert_output
30 bit RW FALSE hm2_7i97.0.gpio.024.is_opendrain
30 bit RW FALSE hm2_7i97.0.gpio.025.invert_output
30 bit RW FALSE hm2_7i97.0.gpio.025.is_opendrain
30 bit RW FALSE hm2_7i97.0.gpio.026.invert_output
30 bit RW FALSE hm2_7i97.0.gpio.026.is_opendrain
30 bit RW FALSE hm2_7i97.0.gpio.027.invert_output
30 bit RW FALSE hm2_7i97.0.gpio.027.is_opendrain
30 bit RW FALSE hm2_7i97.0.gpio.028.invert_output
30 bit RW FALSE hm2_7i97.0.gpio.028.is_opendrain
30 bit RW FALSE hm2_7i97.0.gpio.029.invert_output
30 bit RW FALSE hm2_7i97.0.gpio.029.is_opendrain
30 bit RW FALSE hm2_7i97.0.gpio.031.invert_output
30 bit RW FALSE hm2_7i97.0.gpio.031.is_opendrain
30 bit RW FALSE hm2_7i97.0.gpio.031.is_output
30 bit RW FALSE hm2_7i97.0.gpio.032.invert_output
30 bit RW FALSE hm2_7i97.0.gpio.032.is_opendrain
30 bit RW FALSE hm2_7i97.0.gpio.032.is_output
30 bit RW FALSE hm2_7i97.0.gpio.033.invert_output
30 bit RW FALSE hm2_7i97.0.gpio.033.is_opendrain
30 bit RW FALSE hm2_7i97.0.gpio.033.is_output
30 bit RW FALSE hm2_7i97.0.gpio.034.invert_output
30 bit RW FALSE hm2_7i97.0.gpio.034.is_opendrain
30 bit RW FALSE hm2_7i97.0.gpio.034.is_output
30 bit RW FALSE hm2_7i97.0.gpio.035.invert_output
30 bit RW FALSE hm2_7i97.0.gpio.035.is_opendrain
30 bit RW FALSE hm2_7i97.0.gpio.035.is_output
30 bit RW FALSE hm2_7i97.0.gpio.036.invert_output
30 bit RW FALSE hm2_7i97.0.gpio.036.is_opendrain
30 bit RW FALSE hm2_7i97.0.gpio.036.is_output
30 bit RW FALSE hm2_7i97.0.gpio.037.invert_output
30 bit RW FALSE hm2_7i97.0.gpio.037.is_opendrain
30 bit RW FALSE hm2_7i97.0.gpio.037.is_output
30 bit RW FALSE hm2_7i97.0.gpio.038.invert_output
30 bit RW FALSE hm2_7i97.0.gpio.038.is_opendrain
30 bit RW FALSE hm2_7i97.0.gpio.038.is_output
30 bit RW FALSE hm2_7i97.0.gpio.039.invert_output
30 bit RW FALSE hm2_7i97.0.gpio.039.is_opendrain
30 bit RW FALSE hm2_7i97.0.gpio.039.is_output
30 bit RW FALSE hm2_7i97.0.gpio.040.invert_output
30 bit RW FALSE hm2_7i97.0.gpio.040.is_opendrain
30 bit RW FALSE hm2_7i97.0.gpio.040.is_output
30 bit RW FALSE hm2_7i97.0.gpio.041.invert_output
30 bit RW FALSE hm2_7i97.0.gpio.041.is_opendrain
30 bit RW FALSE hm2_7i97.0.gpio.041.is_output
30 bit RW FALSE hm2_7i97.0.gpio.042.invert_output
30 bit RW FALSE hm2_7i97.0.gpio.042.is_opendrain
30 bit RW FALSE hm2_7i97.0.gpio.042.is_output
30 bit RW FALSE hm2_7i97.0.gpio.043.invert_output
30 bit RW FALSE hm2_7i97.0.gpio.043.is_opendrain
30 bit RW FALSE hm2_7i97.0.gpio.043.is_output
30 bit RW FALSE hm2_7i97.0.gpio.044.invert_output
30 bit RW FALSE hm2_7i97.0.gpio.044.is_opendrain
30 bit RW FALSE hm2_7i97.0.gpio.044.is_output
30 bit RW FALSE hm2_7i97.0.gpio.045.invert_output
30 bit RW FALSE hm2_7i97.0.gpio.045.is_opendrain
30 bit RW FALSE hm2_7i97.0.gpio.045.is_output
30 bit RW FALSE hm2_7i97.0.gpio.046.invert_output
30 bit RW FALSE hm2_7i97.0.gpio.046.is_opendrain
30 bit RW FALSE hm2_7i97.0.gpio.046.is_output
30 bit RW FALSE hm2_7i97.0.gpio.047.invert_output
30 bit RW FALSE hm2_7i97.0.gpio.047.is_opendrain
30 bit RW FALSE hm2_7i97.0.gpio.047.is_output
30 bit RW FALSE hm2_7i97.0.gpio.048.invert_output
30 bit RW FALSE hm2_7i97.0.gpio.048.is_opendrain
30 bit RW FALSE hm2_7i97.0.gpio.048.is_output
30 bit RW FALSE hm2_7i97.0.gpio.049.invert_output
30 bit RW FALSE hm2_7i97.0.gpio.049.is_opendrain
30 bit RW FALSE hm2_7i97.0.gpio.049.is_output
30 bit RW FALSE hm2_7i97.0.gpio.050.invert_output
30 bit RW FALSE hm2_7i97.0.gpio.050.is_opendrain
30 bit RW FALSE hm2_7i97.0.gpio.050.is_output
30 bit RW FALSE hm2_7i97.0.inmux.00.enc0_4xmode
30 bit RW FALSE hm2_7i97.0.inmux.00.enc1_4xmode
30 bit RW FALSE hm2_7i97.0.inmux.00.enc2_4xmode
30 bit RW FALSE hm2_7i97.0.inmux.00.enc3_4xmode
30 u32 RW 0x00000005 hm2_7i97.0.inmux.00.fast_scans
30 u32 RW 0x00004E20 hm2_7i97.0.inmux.00.scan_rate
30 u32 RO 0x00000010 hm2_7i97.0.inmux.00.scan_width
30 u32 RW 0x000001F4 hm2_7i97.0.inmux.00.slow_scans
30 bit RW FALSE hm2_7i97.0.io_error
30 s32 RO 1 hm2_7i97.0.packet-error-decrement
30 s32 RW 2 hm2_7i97.0.packet-error-increment
30 s32 RW 10 hm2_7i97.0.packet-error-limit
30 s32 RW 80 hm2_7i97.0.packet-read-timeout
30 bit RW TRUE hm2_7i97.0.pwmgen.00.dither
30 bit RW FALSE hm2_7i97.0.pwmgen.00.enable.invert_output
30 bit RW FALSE hm2_7i97.0.pwmgen.00.enable.is_opendrain
30 bit RW TRUE hm2_7i97.0.pwmgen.00.offset-mode
30 bit RW FALSE hm2_7i97.0.pwmgen.00.out0.invert_output
30 bit RW FALSE hm2_7i97.0.pwmgen.00.out0.is_opendrain
30 s32 RW 1 hm2_7i97.0.pwmgen.00.output-type
30 float RW 40000 hm2_7i97.0.pwmgen.00.scale
30 bit RW TRUE hm2_7i97.0.pwmgen.01.dither
30 bit RW TRUE hm2_7i97.0.pwmgen.01.offset-mode
30 bit RW FALSE hm2_7i97.0.pwmgen.01.out0.invert_output
30 bit RW FALSE hm2_7i97.0.pwmgen.01.out0.is_opendrain
30 s32 RW 1 hm2_7i97.0.pwmgen.01.output-type
30 float RW 40000 hm2_7i97.0.pwmgen.01.scale
30 bit RW TRUE hm2_7i97.0.pwmgen.02.dither
30 bit RW TRUE hm2_7i97.0.pwmgen.02.offset-mode
30 bit RW FALSE hm2_7i97.0.pwmgen.02.out0.invert_output
30 bit RW FALSE hm2_7i97.0.pwmgen.02.out0.is_opendrain
30 s32 RW 1 hm2_7i97.0.pwmgen.02.output-type
30 float RW 40000 hm2_7i97.0.pwmgen.02.scale
30 bit RW FALSE hm2_7i97.0.pwmgen.03.dither
30 bit RW FALSE hm2_7i97.0.pwmgen.03.offset-mode
30 bit RW FALSE hm2_7i97.0.pwmgen.03.out0.invert_output
30 bit RW FALSE hm2_7i97.0.pwmgen.03.out0.is_opendrain
30 s32 RW 1 hm2_7i97.0.pwmgen.03.output-type
30 float RW 1 hm2_7i97.0.pwmgen.03.scale
30 bit RW FALSE hm2_7i97.0.pwmgen.04.dither
30 bit RW FALSE hm2_7i97.0.pwmgen.04.enable.invert_output
30 bit RW FALSE hm2_7i97.0.pwmgen.04.enable.is_opendrain
30 bit RW FALSE hm2_7i97.0.pwmgen.04.offset-mode
30 bit RW FALSE hm2_7i97.0.pwmgen.04.out0.invert_output
30 bit RW FALSE hm2_7i97.0.pwmgen.04.out0.is_opendrain
30 s32 RW 1 hm2_7i97.0.pwmgen.04.output-type
30 float RW 1 hm2_7i97.0.pwmgen.04.scale
30 bit RW FALSE hm2_7i97.0.pwmgen.05.dither
30 bit RW FALSE hm2_7i97.0.pwmgen.05.enable.invert_output
30 bit RW FALSE hm2_7i97.0.pwmgen.05.enable.is_opendrain
30 bit RW FALSE hm2_7i97.0.pwmgen.05.offset-mode
30 bit RW FALSE hm2_7i97.0.pwmgen.05.out0.invert_output
30 bit RW FALSE hm2_7i97.0.pwmgen.05.out0.is_opendrain
30 s32 RW 1 hm2_7i97.0.pwmgen.05.output-type
30 float RW 1 hm2_7i97.0.pwmgen.05.scale
30 u32 RW 0x00004E20 hm2_7i97.0.pwmgen.pdm_frequency
30 u32 RW 0x000124F8 hm2_7i97.0.pwmgen.pwm_frequency
30 s32 RW 0 hm2_7i97.0.read-request.tmax
30 bit RO FALSE hm2_7i97.0.read-request.tmax-increased
30 s32 RW 143945 hm2_7i97.0.read.tmax
30 bit RO FALSE hm2_7i97.0.read.tmax-increased
30 u32 RW 0x004C4B40 hm2_7i97.0.watchdog.timeout_ns
30 s32 RW 24505 hm2_7i97.0.write.tmax
30 bit RO FALSE hm2_7i97.0.write.tmax-increased
23 s32 RW 4011 motion-command-handler.tmax
23 bit RO FALSE motion-command-handler.tmax-increased
23 s32 RW 24322 motion-controller.tmax
23 bit RO FALSE motion-controller.tmax-increased
23 bit RO FALSE motion.debug-bit-0
23 bit RO FALSE motion.debug-bit-1
23 float RO 0 motion.debug-float-0
23 float RO 0 motion.debug-float-1
23 float RO 0 motion.debug-float-2
23 float RO 1 motion.debug-float-3
23 s32 RO 0 motion.debug-s32-0
23 s32 RO 0 motion.debug-s32-1
33 s32 RW 4618 pid.x.do-pid-calcs.tmax
33 bit RO FALSE pid.x.do-pid-calcs.tmax-increased
33 s32 RW 2554 pid.y.do-pid-calcs.tmax
33 bit RO FALSE pid.y.do-pid-calcs.tmax-increased
33 s32 RW 2090 pid.z.do-pid-calcs.tmax
33 bit RO FALSE pid.z.do-pid-calcs.tmax-increased
24 s32 RW 168007 servo-thread.tmax
23 float RO 0 tc.0.acc
23 float RO 0 tc.0.pos
23 float RO 0 tc.0.vel
23 float RO 0 tc.1.acc
23 float RO 0 tc.1.pos
23 float RO 0 tc.1.vel
23 float RO 0 tc.2.acc
23 float RO 0 tc.2.pos
23 float RO 0 tc.2.vel
23 float RO 0 tc.3.acc
23 float RO 0 tc.3.pos
23 float RO 0 tc.3.vel
23 u32 RO 0x00000000 traj.active_tc
23 float RO 0 traj.pos_out
23 float RO 0 traj.vel_out
Parameter Aliases:
Alias Original Name
hm2_7i97.0.encoder.00.sel0.invert_output hm2_7i97.0.gpio.018.invert_output
hm2_7i97.0.encoder.00.sel0.is_opendrain hm2_7i97.0.gpio.018.is_opendrain
hm2_7i97.0.pwmgen.00.enable.invert_output hm2_7i97.0.gpio.008.invert_output
hm2_7i97.0.pwmgen.00.enable.is_opendrain hm2_7i97.0.gpio.008.is_opendrain
hm2_7i97.0.pwmgen.00.out0.invert_output hm2_7i97.0.gpio.000.invert_output
hm2_7i97.0.pwmgen.00.out0.is_opendrain hm2_7i97.0.gpio.000.is_opendrain
hm2_7i97.0.pwmgen.01.out0.invert_output hm2_7i97.0.gpio.001.invert_output
hm2_7i97.0.pwmgen.01.out0.is_opendrain hm2_7i97.0.gpio.001.is_opendrain
hm2_7i97.0.pwmgen.02.out0.invert_output hm2_7i97.0.gpio.002.invert_output
hm2_7i97.0.pwmgen.02.out0.is_opendrain hm2_7i97.0.gpio.002.is_opendrain
hm2_7i97.0.pwmgen.03.out0.invert_output hm2_7i97.0.gpio.003.invert_output
hm2_7i97.0.pwmgen.03.out0.is_opendrain hm2_7i97.0.gpio.003.is_opendrain
hm2_7i97.0.pwmgen.04.enable.invert_output hm2_7i97.0.gpio.005.invert_output
hm2_7i97.0.pwmgen.04.enable.is_opendrain hm2_7i97.0.gpio.005.is_opendrain
hm2_7i97.0.pwmgen.04.out0.invert_output hm2_7i97.0.gpio.004.invert_output
hm2_7i97.0.pwmgen.04.out0.is_opendrain hm2_7i97.0.gpio.004.is_opendrain
hm2_7i97.0.pwmgen.05.enable.invert_output hm2_7i97.0.gpio.007.invert_output
hm2_7i97.0.pwmgen.05.enable.is_opendrain hm2_7i97.0.gpio.007.is_opendrain
hm2_7i97.0.pwmgen.05.out0.invert_output hm2_7i97.0.gpio.006.invert_output
hm2_7i97.0.pwmgen.05.out0.is_opendrain hm2_7i97.0.gpio.006.is_opendrain
Exported Functions:
Owner CodeAddr Arg FP Users Name
00030 7f454f271908 558d598d2b10 YES 1 hm2_7i97.0.read
00030 7f454f271891 558d598d2b10 YES 0 hm2_7i97.0.read-request
00030 7f454f271749 558d598d2b10 YES 1 hm2_7i97.0.write
00023 7f454f3b73ad 00000000 YES 1 motion-command-handler
00023 7f454f3b79a0 00000000 YES 1 motion-controller
00033 7f454f258240 7f454f6633f0 YES 1 pid.x.do-pid-calcs
00033 7f454f258240 7f454f663590 YES 1 pid.y.do-pid-calcs
00033 7f454f258240 7f454f663730 YES 1 pid.z.do-pid-calcs
Realtime Threads:
Period FP Name ( Time, Max-Time )
1000000 YES servo-thread ( 70409, 168007 )
1 hm2_7i97.0.read
3 motion-controller
4 pid.x.do-pid-calcs
5 pid.y.do-pid-calcs
6 pid.z.do-pid-calcs
7 hm2_7i97.0.write
kris@mill:~$ all,txt
bash: all,txt: command not found
kris@mill:~$ > all,txt
kris@mill:~$
22 Feb 2025 03:56 - 22 Feb 2025 04:13 #322250 by PCW
No motion or PWM is possible because LinuxCNC is not in a machine-on state:
Also the ferror limit is still 0.001:
You cannot start tuning without increasing the min-ferror and
ferror limits(for all joints) or you will get an immediate ferror and
not know the cause.
Last edit: 22 Feb 2025 04:13 by PCW.
22 Feb 2025 20:59 #322308 by Tinker
OK, so i fixed the following error thing, how do I fix the PWM problem?
22 Feb 2025 21:51 #322312 by PCW
What PWM problem?
When PWM enable is true, the analog output voltage will match the PWM value number.
_but_ if you get a fault (as it looks like in your first data dump), LinuxCNC will go into the
machine-off state and disable PWM enable so no analog output is possible
Can you re-do the halcmd show all > all.txt with linuxCNC running in the machine on state
(if running axis, this means the power button is depressed = shows shadow border)
23 Feb 2025 19:29 #322390 by Tinker
This is with the machine in the on state. The servos are drifting in the - directoin and do not respond to jog comands.
30 bit OUT FALSE hm2_7i97.0.gpio.022.in_not
30 bit OUT TRUE hm2_7i97.0.gpio.023.in
30 bit OUT FALSE hm2_7i97.0.gpio.023.in_not
30 bit OUT TRUE hm2_7i97.0.gpio.026.in_not
30 bit OUT TRUE hm2_7i97.0.gpio.027.in_not
30 bit OUT FALSE hm2_7i97.0.gpio.029.in_not
30 bit IN TRUE hm2_7i97.0.pwmgen.00.enable <== joint-0-enable
30 bit IN TRUE hm2_7i97.0.pwmgen.01.enable <== joint-1-enable
30 bit IN TRUE hm2_7i97.0.pwmgen.02.enable <== joint-2-enable
30 s32 OUT 67784 hm2_7i97.0.read.time
30 s32 OUT 4757 hm2_7i97.0.write.time
48 float IN 25 ini.0.ferror
48 float IN 1 ini.0.min_ferror
48 float IN 25 ini.1.ferror
48 float IN 1 ini.1.min_ferror
48 float IN 25 ini.2.ferror
48 float IN 1 ini.2.min_ferror
23 bit OUT TRUE joint.0.amp-enable-out ==> joint-0-enable
23 float OUT -0.0911 joint.0.coarse-pos-cmd
23 float OUT 0.5281 joint.0.f-error
23 float OUT 1 joint.0.f-error-lim
23 float OUT -0.0911 joint.0.free-pos-cmd
23 float OUT 3.4 joint.0.free-vel-lim
23 float OUT -0.0911 joint.0.motor-pos-cmd ==> joint-0-pos-cmd
23 float IN -0.6192 joint.0.motor-pos-fb <== joint-0-pos-fb
23 float OUT -0.0911 joint.0.pos-cmd
23 float OUT -0.6192 joint.0.pos-fb
23 bit OUT TRUE joint.1.amp-enable-out ==> joint-1-enable
23 float OUT 0.006225 joint.1.coarse-pos-cmd
23 float OUT 0.002075 joint.1.f-error
23 float OUT 1 joint.1.f-error-lim
23 float OUT 0.006225 joint.1.free-pos-cmd
23 float OUT 0.006225 joint.1.motor-pos-cmd ==> joint-1-pos-cmd
23 float IN 0.00415 joint.1.motor-pos-fb <== joint-1-pos-fb
23 float OUT 0.006225 joint.1.pos-cmd
23 float OUT 0.00415 joint.1.pos-fb
23 bit OUT TRUE joint.2.amp-enable-out ==> joint-2-enable
23 float OUT -0.012925 joint.2.coarse-pos-cmd
23 float OUT 0.03755 joint.2.f-error
23 float OUT 1 joint.2.f-error-lim
23 float OUT -0.012925 joint.2.free-pos-cmd
23 float OUT -0.012925 joint.2.motor-pos-cmd ==> joint-2-pos-cmd
23 float IN -0.050475 joint.2.motor-pos-fb <== joint-2-pos-fb
23 float OUT -0.012925 joint.2.pos-cmd
23 float OUT -0.050475 joint.2.pos-fb
23 s32 OUT 130 motion-command-handler.time
23 s32 OUT 2590 motion-controller.time
23 bit OUT TRUE motion.motion-enabled ==> motion-enable
23 u32 OUT 0x000632DC motion.servo.last-period
33 float IN -0.0911 pid.x.command <== joint-0-pos-cmd
33 float IN 1 pid.x.deadband
33 s32 OUT 142 pid.x.do-pid-calcs.time
33 bit IN TRUE pid.x.enable <== joint-0-enable
33 float OUT 0.528125 pid.x.error
33 float IN -0.619225 pid.x.feedback <== joint-0-pos-fb
33 float IN 0.006225 pid.y.command <== joint-1-pos-cmd
33 float IN 1 pid.y.deadband
33 s32 OUT 35 pid.y.do-pid-calcs.time
33 bit IN TRUE pid.y.enable <== joint-1-enable
33 float OUT 0.002075 pid.y.error
33 float IN 0.00415 pid.y.feedback <== joint-1-pos-fb
33 float IN -0.012925 pid.z.command <== joint-2-pos-cmd
33 float IN 1 pid.z.deadband
33 s32 OUT 63 pid.z.do-pid-calcs.time
33 bit IN TRUE pid.z.enable <== joint-2-enable
33 float OUT 0.03755 pid.z.error
33 float IN -0.050475 pid.z.feedback <== joint-2-pos-fb
24 s32 OUT 79374 servo-thread.time
Pin Aliases:
Alias Original Name
Signals:
bit TRUE joint-0-enable
==> pid.x.enable
float -0.0911 joint-0-pos-cmd
==> pid.x.command
float -0.619225 joint-0-pos-fb
==> pid.x.feedback
bit TRUE joint-1-enable
==> pid.y.enable
float 0.006225 joint-1-pos-cmd
==> pid.y.command
float 0.00415 joint-1-pos-fb
==> pid.y.feedback
bit TRUE joint-2-enable
==> pid.z.enable
float -0.012925 joint-2-pos-cmd
==> pid.z.command
float -0.050475 joint-2-pos-fb
==> pid.z.feedback
<== pid.x.output
<== pid.y.output
<== pid.z.output
bit TRUE motion-enable
s32 0 tool-number
Parameters:
30 s32 RW 115492 hm2_7i97.0.read.tmax
30 u32 RW 0x002625A0 hm2_7i97.0.watchdog.timeout_ns
30 s32 RW 17642 hm2_7i97.0.write.tmax
23 s32 RW 2198 motion-command-handler.tmax
23 s32 RW 21328 motion-controller.tmax
33 s32 RW 2480 pid.x.do-pid-calcs.tmax
33 s32 RW 1760 pid.y.do-pid-calcs.tmax
33 s32 RW 1673 pid.z.do-pid-calcs.tmax
24 s32 RW 145962 servo-thread.tmax
Parameter Aliases:
Alias Original Name
Exported Functions:
00030 7f8d53a76908 559ef76c6b10 YES 1 hm2_7i97.0.read
00030 7f8d53a76891 559ef76c6b10 YES 0 hm2_7i97.0.read-request
00030 7f8d53a76749 559ef76c6b10 YES 1 hm2_7i97.0.write
00023 7f8d53bbc3ad 00000000 YES 1 motion-command-handler
00023 7f8d53bbc9a0 00000000 YES 1 motion-controller
00033 7f8d53a5d240 7f8d53e683f0 YES 1 pid.x.do-pid-calcs
00033 7f8d53a5d240 7f8d53e68590 YES 1 pid.y.do-pid-calcs
00033 7f8d53a5d240 7f8d53e68730 YES 1 pid.z.do-pid-calcs
Realtime Threads:
500000 YES servo-thread ( 80041, 145962 )
1 hm2_7i97.0.read
3 motion-controller
7 hm2_7i97.0.write
kris@mill:~$
23 Feb 2025 19:51 #322391 by PCW
There's a +.5281 difference in joint 0 position and feedback
This should result in a 0.5281 PID output (when P=1) which is connected
to the PWM value, but in fact, the PWM value is zero:
Did you set all deadzones to zero?
23 Feb 2025 20:04 #322393 by Tinker
I set all dead bands to 1. When I try to jog the machine the joint pos cmd moves in halshow but the joint pos fb does not.. Its like the card is not talking to my drives
Time to create page: 0.548 seconds
