XHC WHB04B development?
- Finngineering
- Thank you received: 49
07 Feb 2026 08:53 #342590
by Finngineering
Replied by Finngineering on topic XHC WHB04B development?
Okay, thank you for the feedback. I realize now I wasn't clear in my last request, but I meant jogging with the pendant while a program is running. But you did that as well.
This setupAsyncTransfer() assertion failed is also what I had before changing the loops. That error occurs when the USB dongle has already reset, most likely because it saw no activity from the computer side.
I mentioned that after some time, the pendant still stops working for me. But I don't recall right now if I have even checked if I get the same setupAsyncTransfer failed at that time. I should check...
If you continue using this modified version, let us know if it looks to have cured the other issue you had as well.
I just started on writing a new firmware for the dongle. But I'm not sure where that will lead, if anywhere.
- Hakan
- Thank you received: 454
07 Feb 2026 09:19 #342592
by Hakan
Replied by Hakan on topic XHC WHB04B development?
What number do you use for loops? Is any number "best"?
- Finngineering
07 Feb 2026 12:01 #342597
by Finngineering
I believe I have 10, but can't verify until tomorrow or Monday. I have only tried the one value, which was an educated guess and seemed to work.
The total delay can be loops * timeout, i.e. 60 * 5 ms = 300 ms with the default values. In practice it can become longer because of how the delay is made and how the kernel schedules the task. I would imagine that as long as the delay is more than a few servo cycles, it should work. So probably it would work even with loops set to 1. But I have not tested. Nor do I think it would solve all issues that I experience.
- Hakan
07 Feb 2026 13:52 #342600
by Hakan
Ok, I continue with the 10 I have guessed and set.
Seeing that you understand pretty well what is going on, what will you do different with a new driver?
- Finngineering
07 Feb 2026 18:03 #342614
by Finngineering
Hopefully have a completely stable firmware and some type of watchdog to keep track of the communication. By the way, with firmware I speak about the USB dongle and with driver I mean the computer/LinuxCNC component.
I'm not completely happy with how the LinuxCNC xhc-whb04b-6 component works either. And at least for me, the amount of abstraction layers in that code makes it difficult to understand/change.
- Finngineering
08 Feb 2026 19:59 #342670
by Finngineering
I have loops set to 10 and timeout to 3.
- Hakan
09 Feb 2026 07:44 #342699
by Hakan
Is it realistic to write a new firmware for the dongle? Is it to improve on the reset?
Sounds like you identified blocking wait states as at least one big part of the problem.
Realistic to rewrite those sections in the component?
fyi, I have the radio version, works well for me needs.
- Finngineering
10 Feb 2026 14:42 #342772
by Finngineering
Yes, I think its realistic to write a new firmware. The goal would be to have the pendant fully reliable and also proper detection if the RF link fails, possibly some other improvements as well.
It doesn't have to be an either/or solution. With the new firmware, I would probably strive to maintain "protocol compatibility", so the same xhc-whb04b-6 component could still be used.
Improving the xhc-whb04b-6 component is certainly possible, and hopefully that could be done as well. For this blocking wait state, I don't really see a clean/simple fix, other than reducing the max blocking time like we have done. And to be honest, the amount of abstractions used in the code makes it difficult to follow for myself.
But this is also one reason why I made this post. To see if others have similar issues (and now you have confirmed that its not only me). Maybe there is somebody else that wouldn't mind updating the xhc-whb04b-6 code, but would need inputs on what to change.
The following user(s) said Thank You: NWE
- Hakan
11 Feb 2026 19:16 - 11 Feb 2026 19:19 #342812
by Hakan
Used the mpg today, sadly it crashed again. Loops = 10.
I actually opened an issue on github now over two years ago github.com/LinuxCNC/linuxcnc/issues/2237
No resolution. I never made a serious attempt to understand the code structure of the component.
Just looked at what was going on around the triggered assert() and made some more or less random changes.
Where is the blocking call? I'll see if I can do some ... tests.
Last edit: 11 Feb 2026 19:19 by Hakan.
- Finngineering
12 Feb 2026 15:28 #342847
by Finngineering
Yeah, at least for me the loops = 10 was not the solution to everything, so not surprised the situation is the same for you. As far as I have seen, this loops = 10 would only help during a LinuxCNC mode change (auto/manual/mdi/teleop/joint).
I was not aware of that issue, so that you for bringing that up. I will write a comment there (if I can), because I think what we have discussed here is a partial solution.
I would be interesting in knowing the error message (if any) when it fails, i.e. console ouput. This I can also "generate" myself, but right now I'm not using the machine.
Time to create page: 0.518 seconds
