XHC WHB04B development?
8 months 2 weeks ago #342881 by Hakan
Replied by Hakan on topic XHC WHB04B development?
What did you find as being the problem? You probably already wrote it, can you do it again?
What is the way to fix?
8 months 2 weeks ago #342883 by Finngineering
The problem is that the dongle resets itself. Basically the same as pulling it out of the USB port and reinserting it.
In the situation where you try to jog with the pendant while running a program, this is caused by a too long time during which the xhc-whb04b-6 component does not poll the dongle. This we "fixed" with the loops=10.
In the other situations that happens "randomly" after some time, I do not know what the reason is.
The following user(s) said Thank You: NWE
8 months 2 weeks ago - 8 months 2 weeks ago #342994 by Hakan
Had event logging on today. It failed again (loop =10).
libusb_submit_transfer failed with LIBUSB_ERROR_NO_ DEVICE (-4)
github.com/tenderlove/libusb/blob/763471...libusb/libusb.h#L750
github.com/tenderlove/libusb/blob/763471...13/libusb/io.c#L1288
Syslog is absolutely full of usb disconnects of the xhc device. Every 16-17 second the device disconnects and reconnects.
Must be the xhc component that does this? It only happens when linuxcnc is running.
If I look in github.com/tenderlove/libusb/blob/master...usb/os/linux_usbfs.c and search for LIBUSB_ERROR_NO_DEVICE,
they are there.
Why are all the disconnects/reconnects there? Wouldn't surprise me if that can cause something.
Last edit: 8 months 2 weeks ago by Hakan.
8 months 2 weeks ago #343002 by MRx
Replied by MRx on topic XHC WHB04B development?
Disconnects might be caused by multiple reasons.
a) poor xhci support for that system - try to connect the pendant to a USB 2.0 port
b) check if USB autosuspend is disabled (as root)
cat >/sys/module/usbcore/parameters/autosuspend
echo -1 >/sys/module/usbcore/parameters/autosuspend
c) if connected to a USB hub - don't do that, connect it directly
d) EMI issues, check if there's a pattern that can trigger this, check if a relay is able to disconnect it somehow; I had HDMI displays resetting due to issues with relays a decade ago (eg. missing flyback diodes)
I worked on the XHC pendant some years ago to fix some issues, I never had disconnect issues with it.
The following user(s) said Thank You: tommylight, Hakan, andrax
8 months 2 weeks ago - 8 months 2 weeks ago #343009 by Hakan
Had a session with a lot of mode shifts, auto programs, manual and mdi and not being careful when mode shifting.
Worked great, it felt like there was no problem with the xhc.
I had checked autosuspend which was set to 2. Set it to -1 and the disconnect/connects in syslog stopped.
Finished after a few hours. Checked syslog and now the xhc is just laying there doing nothing on the milling machine.
The faint light is on, that's all. And the syslog fills with new disconnect/connects. Every 10-20 seconds it happens.
autosuspend was already set to -1.
Went to the milling machine and turned off the pendant. New disconnects/connects stopped coming in syslog.
Didn't touch the usb dongle during the whole day. The pendant causes the disconnects? When idle?
8 months 2 weeks ago #343011 by MRx
Under normal operation there's no disconnect of the XHC pendant. It's solid. If you power it off it will disconnect.
I heard from others that they had EMI problems with USB and the XHC pendant in the past, I'm going to operate it with a large CNC in the near future so I will see if it will hit me too.
I think you have to fix a problem on the USB layer, maybe use another system which has a native USB 2.0/ehci port. The XHCI USB ports can cause issues depending on the hardware.
By the way you can easily convert an WHB04B to 6 axis by removing a stopper with a knife which is inside the rotary switch. 6 axis are wired up even on the 4 axis versions.
Time to create page: 0.214 seconds
