Welcome Hannes and thank you from my side for your contributions. I am fairly new here myself, and have made no "real" contributions to LinuxCNC so far.
If you read through this thread, you saw we discussed a "loops" variable. The changes you made to hal.cc should be another way of fixing that specific issue. As for the other changes, I haven't really used any of those features. And to be honest, I'm a bit confused about the modes (auto, MDI, manual, teleop, joint).
In other news, I have been slowly chipping away at making a new firmware for the dongle. As of right now, I have something that is mostly working. I will release the source code once I have it in a little bit better shape. But I don't think it will be of use to most people, as flashing a new firmware is likely a one way street, and may make the pendant unusable.
If you or somebody else wants to update the xhc-whb04b-6 component (more), there is some low hanging fruit:
The libusb_fill_bulk_transfer in:
github.com/LinuxCNC/linuxcnc/blob/master...whb04b-6/usb.cc#L457
should really be a libusb_fill_interrupt_transfer. Endpoint 1 is an interrupt endpoint after all. The dongle/pendant doesn't know the difference between bulk and interrupt, but for scheduling of traffic on the USB bus, there are some differences. It's not inconceivable that some of the disconnects could be from USB congestion and wrong transfer type, but I do think it's unlikely.
Another thing is the checksum calculation. The full formula is:
checksum = (~random + button1)^(~random | seed)
In the XHC implementation, the seed is the day of month [1...31] and "random" is from a timer in the microcontroller.
