XHC WHB04B development?
8 months 6 days ago - 8 months 6 days ago #343571 by Hannes
Replied by Hannes on topic XHC WHB04B development?
I just had an idea: I don't need A/B/C, so I wired the feeds to these channels. It works way better anyway and I can use the jog wheel.
You can not use this in MDI mode due to when jogging, the WHB automatically changes to manual mode.
In auto mode with linuxcnc 2.9.8 without my patch, you probably will get a lot of error messages due to the whb wants to change from auto to manual. But this is gone with this fix:
github.com/LinuxCNC/linuxcnc/pull/3810/c...f939ee3cfb99275R1344
See
File Name: xhc_whb04b_6.hal
File Size:14.66 KB
after:
#Rewire feeds to A/B/C
Last edit: 8 months 6 days ago by Hannes.
The following user(s) said Thank You: NWE
8 months 5 days ago #343582 by Finngineering
I think the data looks okay for you Hannes, and it seems likely that the firmware on your pendant doesn't support the F/S indications. I am not setup to build linuxcnc on this machine right now, but here is a screenshot from Wireshark showing the same type of data as your terminal output:
The highlighted line is the last part of the report, where the feed and spindle overrides are given. For me, both were at 100% = hex 0x64. My pendant also shows the F/S values in auto mode when a program is running. Many different firmware variants, I suppose...
I've had LinuxCNC simulation running a long G-code program a couple of nights to see if I can find some issues with my dongle firmware. So far, no disconnects nor any other meaningful issues. Sometimes (around 0.0035% of the time) it send a zero-length package, which is not correct, but neither is it harmful. I will try to look over the USB handling to see if I can get rid of that one.
8 months 4 days ago #343634 by Finngineering
I'm fairly sure I fixed the 0.0035% bug I mentioned in the last post. Swapping two lines in the code should have been enough. Right now, I'm not aware of any real bugs in my firmware. I will continue using it with the dongle/pendant on the mill. But unless something comes up, I consider it good enough.
Unfortunately, I was mistaken about the bootloader version where the dongle firmware can more easily be read out. It is possible for versions before 2.40, but not with version 2.40 or 2.50. So right now there is no easy way to read out the whole firmware from the dongles.
8 months 4 days ago #343644 by Hakan
Replied by Hakan on topic XHC WHB04B development?
One more update on display in Auto mode. NOW it does show F: and S:
and also coordinate updates.
After x minutes is seems to enter some sleep mode and stops updating the
display altogether. Buttons still work though.
I think I wrote that the component is prepared for reconnecting. No, it isn't.
If the setupAsyncTransfer() fails, the component exits.
I am testing to see if the usb part can be restarted.
8 months 4 days ago #343646 by Hannes
Thanks! I just modified quickly linuxcnc to send exactly your data. But no F/S. So I think just a buggy firmware.
8 months 4 days ago #343650 by Finngineering
Hakan, as far as I can tell, the component should try to reconnect after a failed asyncSetupTransfer in case you comment out the assert call. It should then after a short while fail on libusb_control_transfer, which then calls setDoReconnect(true), which in turn should cause a restart of the USB stack.
If you run the component with the -a flag, the console output when it fails would be interesting to see.
Time to create page: 0.070 seconds
