Regarding the firmware for the pendant, I thought about trying to read it out with glitching or some other technique. But I have not seen the need for it so far. I did read out the firmware from the dongle, but also that was quite much work for what in theory should be simple:
github.com/finngineering/ch55x_firmware_extractor
The reverse engineering I have done for that is with Ghidra. But the dongle is based on the CH554 microprocessor, which is a "8051" type. And the support for that processor is not the best in Ghidra.
I'm not sure what differences you are asking about for the usbhid-dump Hakan. I haven't really checked the source, but I guess it's just polling the interrupt endpoint more or less the same as my test program and the xhc-whb04b-6 component. What would be interesting to know is if there are disconnects with all these program if left running long enough. Say, 1 day or so. Or if that happens only with the xhc-whb04b-6 component (and maybe only while LinuxCNC is running)... I could maybe leave it running overnight myself to check.
