Ver 10 NEW install
2 months 3 weeks ago #348560 by 5280
Replied by 5280 on topic Ver 10 NEW install
thanks for the effort.. I think it is called a locked loop I have seen this also.
I have found that if i do a
ctrl + alt + F3
it takes me to the terminal login screen at which point I am able to log in with user name and password that was setup during setup and then do things in terminal mode. terminal mode seems to be working just fine. I have done the updates and the upgrade. per info on terminal screens but nothing past that at this point.
AI says there is fix for this locked loop thing but I have not done it yet. will do it later on.. now i have to learn all the command line stuff if i live that long .?
Thanks again for the help.
Ken
2 months 3 weeks ago - 2 months 3 weeks ago #348563 by tommylight
Replied by tommylight on topic Ver 10 NEW install
hmmm that might also be a hardware issue, usually dry capacitors or memory problems, although memory problems will show up during boot in most cases.
You might want to try Linux Mint Debian Edition, after install and reboot:
sudo apt update
sudo apt install linuxcnc-uspace
But this will be an older version of 2.9, not the master version or 2.10
Edit:
if you want to continue with ctrl+alt+F3 , type startx and check what errors it shows up.
Last edit: 2 months 3 weeks ago by tommylight.
2 months 3 weeks ago #348574 by 5280
good afternoon Sir
the startx command takes me into the debain program no errors.
windows 10 ran just fine. BUT it was Microsoft windows 10 (UGH)
what a back door just to run the debian OS
but it seems to work
is this something that might need to be looked at by the powers that be.? as a possible fix.
2 months 3 weeks ago - 2 months 3 weeks ago #348577 by NWE
Replied by NWE on topic Ver 10 NEW install
run the following cammand at the terminal:
systemctl get-default
if it replies with
multi-user.target
then that is what is wrong. Run
sudo systemctl set-default graphical.target
or if it replied with
graphical.target
then this is not the problem, it takes more diagnostics.
Last edit: 2 months 3 weeks ago by NWE.
2 months 3 weeks ago #348580 by 5280
When should i run the systemctl get-default
before startx
or
after from with in the OS terminal after everything is running
2 months 3 weeks ago #348581 by NWE
It doesn't matter. If you have it running now, just open a terminal window and run the command. Or doing it before startx should work the same.
Time to create page: 0.076 seconds
