Ver 10 NEW install
2 months 3 weeks ago #348494 by 5280
Replied by 5280 on topic Ver 10 NEW install
Thank you for the reply (link to the Debian 13 install link after building a USB boot install flash drive and doing the install on the (older Dell laptop 8 gig memory)thee install goes fine till the password section which i have tried any number of password from 4 letters to 20 letters / numbers .? nothing get me past the enter login on the reboot . Every thing looks fine on the setup "but" ? I guess I am not to have this I have never understand why since I am the only person "WHY " I need a password" and the only person who will use this people have gotten crazy with the requiring passwords
Thanks for the help
2 months 3 weeks ago #348495 by 5280
Sorry about Pxxx/Moning about passwords I am leaving M.S. because of how they handle the passwords. I have been building boxes since Aug of 1977 (Almost 50 years) and over 100 boxes's
why cant they just have a check box do you need a password yes / no and leave it at that
1 frustrated old man
Ken (5280)
2 months 3 weeks ago #348497 by Todd Zuercher
Replied by Todd Zuercher on topic Ver 10 NEW install
It is possible to set up a linux system with no passwords, but it isn't completely simple or recommended (especially on systems with any internet exposure.)
First you can do away with a root password, by leaving that blank when installing. The user password is required while installing, but you can configure Linux to boot directly to the user interface by enabling automatic login, and the system will start without needing to input a password.
If you configured the system without a root password, the installer will have given sudo privileges to the user, and will promp for a password when a sudo command is input at the terminal.
With automatic login and sudo privileges for the user, you would only need to enter your password to perform administrative tasks that probably should be password protected. Otherwise you shouldn't normally need to user your password.
There are ways to even remove the requirement for a password for sudo tasks, but I've never tried and would have to google instructions how to do it. (not to mention that it's generally probably not a good idea.)
2 months 3 weeks ago #348498 by 5280
Tks for the info But I stick to GIVE THE USER THE CHOICE right off the bat....! an force me to "DIG" for that info to have to disable. at a later date
I under stand with the internet the way it is.? "BUT" give me the "choice"
I understand this will never HAPPEN but had to get my 2 cents worth in.!
the old timer
2 months 3 weeks ago #348508 by 5280
Ok I reinstall the debian system iso file and it still will not let me past the login screen I tried the blank password name and password but still it will not let me past the login screen with or with out the login.
now at a stand still.?
Ken
2 months 3 weeks ago #348515 by tommylight
Replied by tommylight on topic Ver 10 NEW install
Just re-read this topic ... twice, i am confused on many levels...
If you want just to test use the live version, do not install it.
And that never asks you for a "password" ... that is a thing since the inception of personal computers.
Time to create page: 0.162 seconds
