5 axis Build
08 Mar 2011 17:20 #7644 by andypugh
Replied by andypugh on topic Re:5 axis Build
My first thought is that you might be loading the wrong kernel. type
uname -r
at the command prompt?
08 Mar 2011 17:36 #7645 by andypugh
You might have some luck asking on the #emc IRC channel, details here:
www.linuxcnc.org/component/option,com_mo...emid,8/lang,english/
You should be able to chat live with devs and users (if anyone is online and listening)
08 Mar 2011 17:47 #7646 by jimmy111
Replied by jimmy111 on topic Re:5 axis Build
Is this what you are asking for??
Linux version 2.6.32-122-rtai (root@moses-6core) (gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) ) #rtai SMP Tue Jul 27 12:44:07 CDT 2010
08 Mar 2011 17:50 #7647 by jimmy111
Im sure it has something to do with this specific computer. I loaded the same disk on 2 other computers and had no problem.
08 Mar 2011 18:13 #7648 by andypugh
There goes that theory.
Can you put the output of dmesg at www.pastebin.com ?
08 Mar 2011 18:23 #7649 by jimmy111
Ok did it. it is:
jimmy111dmsg
08 Mar 2011 18:38 #7651 by jimmy111
Could it be that Im running a 64bit processor (Phenom II 6 core) and Ubunta is setting itself up as 64bit??
08 Mar 2011 18:58 #7652 by andypugh
It looks like the problem at the bottom of this page:
wiki.linuxcnc.org/emcinfo.pl?Ubuntu10.04PackageNotes
(Basically RTAI does not like 6-core machines)
You can either disable some cores, or possibly buy one of the inexpensive Atom boards, which work a treat. D510MO is very popular and about $70.
08 Mar 2011 19:19 #7653 by jimmy111
Ill play with the boot settings and see what happens.
Thanks for the help.
For the record it is a ASUS M4A89GTD PRO mother board and a Phenom II 6 core black processor.
Ubunta seems to work great. Just problems with the CNC program.
08 Mar 2011 19:24 #7655 by andypugh
Yes, the problem is with the RTAI patch, not with the standard Ubuntu kernel.
