7i77 testers wanted
01 May 2012 02:34 #19688 by cmorley
Replied by cmorley on topic Re:7i77 testers wanted
PNCconf includes an option to add a gladvcp or pyvcp spindle speed indicator.
It can be displayed inside AXIS on the right side.
Did you do an open loop test with the A axis ?
01 May 2012 03:06 - 01 May 2012 03:09 #19689 by maxvdh
Replied by maxvdh on topic Re:7i77 testers wanted
OK I'll look into the indicator.
The A axis is the axis I had been doing the open loop testing with up to now and it seems to work fine open loop in pncconf. I'm not quite sure where to begin the diagnosis with AXIS. It's actually a C axis (I just set it up as A since that was easy with PNCConf) so soon I'll have to figure out how to configure linuxCNC for a C axis.
Last edit: 01 May 2012 03:09 by maxvdh.
01 May 2012 03:32 #19690 by cmorley
does the count direction and analog output agree?
You may already know - but that is what the openloop test is for.
positive jog should produce positive encoder count and move the motor in the right direction.
I have not got a lot of feedback on servo A axis - most are steppers.
01 May 2012 03:52 #19692 by maxvdh
It appears to go in the correct direction and indicate the correct encoder count when I use the open loop test. But as far as I can tell in AXIS there's no attempt at motion before it throws a joint 3 following error message.
Do you know anything about configuring it as a C axis rather than A? Thanks
01 May 2012 04:05 - 01 May 2012 04:09 #19693 by cmorley
Well i haven't done that - I should add it to PNCconf it comes up from time to time...
in the INI file:
under [TRAJ] heading
change axes = 4 to axes = 6
change COORDINATES = X Y Z A to COORDINATES = X Y Z C
change the [AXES_3] heading to [AXES_5]
In the main HAL file:
change all the [AXES_3] to [AXES_5]
now if you are using AXIS the display will probably be wrong.
in the INI file under the [DISPLAY] heading
look for GEOMETRY= XYZA
This changes the way gcode is displayed.
try XYZC - but I'm not sure of this...
Last edit: 01 May 2012 04:09 by cmorley.
01 May 2012 05:22 #19694 by cmorley
Question for Peter:
Is there any other difference for AOUT5 besides it's separate enable pin?
Pncconf at the moment allows one to have the spindle controlled by any AOUT
so I must fix the enable problem but I want to know if the spindle MUST be AOUT5
01 May 2012 05:23 #19695 by maxvdh
Thanks, that seems to work. Is there no need to change all the pid.a.Pgain etc values to pid.c.Pgain?
I'll continue trying to figure out the follow error issue tomorrow. I must have set the deadband too small or something. I'm not sure what the feedforward gains should be either.
01 May 2012 05:27 #19696 by cmorley
well it would make more sense but doesn't matter but....
I forgot about changing axis.3 to axis.5
for example axis.5.motor-pos-cmd
You will find them in the HAL file
01 May 2012 05:30 #19697 by cmorley
yes following error seems too small:
0.0005 of a degree
01 May 2012 13:26 #19707 by PCW
Replied by PCW on topic Re:7i77 testers wanted
The only difference with analog channel 5 is that its enable is separate
(making the enable useful for a spindle)
