Mesa 5i25+7i77 plug-n-go configuration
10 May 2012 14:26 #19974 by PCW
Thanks for help PCW ! But I have checked in both computer and there is no hm2-servo directory in ~/linuxcnc/configs/ . I think I am missing any step.
It may be that you need to install the hm2 firmware package to get the hm2 configuration directories
(I dont have a running liveCD version so Im not sure when that gets installed)
In any case you can make your own directory in ~/linuxcnc/configs and put the 5i25-7i77.ini and hm2-servo7i77.hal there
10 May 2012 14:33 - 10 May 2012 14:34 #19975 by ishman
Replied by ishman on topic Re:Mesa 5i25+7i77 plug-n-go configuration
I am trying to search hostmot2 firmware for 5i25 but there is no firmware for 5i25. When I try "sudo apt-get install hostmot2-firmware (and press tab)" then it shows the following options.
hostmot2-firmware
hostmot2-firmware-5i22-1.5
hostmot2-firmware-3x20-1
hostmot2-firmware-5i23
hostmot2-firmware-4i65
hostmot2-firmware-7i43-2
hostmot2-firmware-4i68
hostmot2-firmware-7i43-4
hostmot2-firmware-5i20
hostmot2-firmware-all
Last edit: 10 May 2012 14:34 by ishman.
10 May 2012 15:04 - 10 May 2012 15:07 #19976 by PCW
Thats correct, there is no firmware directory for the 5I25
(the 5I25 stores its firmware on the card)
I was just thinking that perhaps the hostmot2-firmware package installs the hostmot2 configs but
the configs are in the normal 2.5 release tree so I dont know why you dont have them by default
what directories do you have in ~/linuxcnc/configs/ ?
Last edit: 10 May 2012 15:07 by PCW. Reason: aspergers
10 May 2012 15:11 #19977 by ishman
I have the following directories in ~/linuxcnc/configs/
5axis
my_LinuxCNC_machine
my-mill
sim
two of them started with my are created by me. One with stepconf and one with pncconf. Both have their xml files as well in the same directory.
10 May 2012 15:27 #19978 by PCW
OK you would probably have to start Linuxcnc and select an existing hm2-servo config
(doesnt matter which one) to create the directory
10 May 2012 15:35 #19979 by ishman
Thanks for your effort ! but I am unable to figure out where to get existing hm2-servo config ? Do you mean my own created one ?
I have created "my_LinuxCNC_machine" with pncconf and it configures both 5i25 and 7i77. atleast not giving any error till loading the linuxcnc. I will try to hook this configuration with my machine on Saturday.
10 May 2012 15:56 #19980 by PCW
No, start linuxcnc and select a hm2-servo config from the sample configs.
10 May 2012 16:05 - 10 May 2012 16:06 #19981 by ishman
I got it ! It created a directory hm2-servo. There is some <board>.ini files with hm2-servo.hal and readme.txt and tool.tbl.
Last edit: 10 May 2012 16:06 by ishman.
10 May 2012 16:13 #19982 by PCW
Good, so now if you want to try manual HAL file editing you can copy the 5i25-7i77.ini and hm2servo7i77.hal file to that directory and give it a try
10 May 2012 16:23 #19983 by ishman
Yes ! I want to try manual editing as well. But I can't find the 5i25-7i77.ini and hm2servo7i77.hal in downloaded drivers from mesanet. there is only .bit files or .pin files. Is there any other link to download ?
