mesa card 5i25 kernel error
11 years 2 weeks ago #63842 by bkt
Replied by bkt on topic mesa card 5i25 kernel error
your second time ask regards my linuxcnc version ..
I intrigued me ... so I did the upgrade to 2.7.0, always keeping ubuntu 04.10 .... a mess .... what you see in the pictures is normal or am I missing pieces to be able to use pnconf?
I used the option 5i25 and I did not use the option 5i25 internal ...
for example, you can no longer see the smart series, so they are unable to use all of the I / O card 7i77 ....
I tried configurations 7i77x2 and 7i77x2r ....
11 years 2 weeks ago - 11 years 2 weeks ago #63843 by bkt
sorry ... the image:
You see I have no option for using 7i77 in mode 0 or 1 or 2
Last edit: 11 years 2 weeks ago by bkt.
11 years 2 weeks ago #63844 by PCW
Replied by PCW on topic mesa card 5i25 kernel error
To reduce variables, I would start with
5i25_7i77x2.bit
And use the external 5I25 connector
11 years 2 weeks ago #63847 by bkt
witch is the external connector? ( pheraps I not undersatand the sense of option 5i25 and 5i25-internal .....)
At this point I would start with fresh installation ... with asrock d2550 mini-itx witch is the best choice?
1-lucid
2-precise or
3-wheezy?
Linuxcnc 2.7.0 or 2.6.9?
Tomorrow morning start and if you reply me this evening i can download your suggested release and SO.
Regards
Giorgio
11 years 2 weeks ago #63857 by cncbasher
use the latest iso
linuxcnc.org/docs/2.7/html/getting-start...#_download_the_image
the external db25 connector is placed on the mounting plate , and looks just like a parallel port , this is the default external connector to use ,
the internal is a 26pin header along the top edge of the 5i25 .
11 years 2 weeks ago #63862 by bkt
ok for precision DB25 connector is mesa = 0 and internal (plasic 26 pin connector) is mesa = 1. Is correct?
ok I have a bootable usb pen drive with debia wheezy AND LINUXCNC 2.7
rEGARDS
gIORGIO
Time to create page: 0.197 seconds
