mesa card 5i25 kernel error
11 years 1 week ago #63950 by PCW
Replied by PCW on topic mesa card 5i25 kernel error
5i25-internal means use internal 5i25/daughtercard XML info not external file
it has nothing to do with connectors
11 years 1 week ago - 11 years 1 week ago #63951 by bkt
Replied by bkt on topic mesa card 5i25 kernel error
@PCW ok thanks .... if I write with mesaflash 5i25_7i77x2.bit file I change .xml file too?
and you can suggest the right combination of choice? 1-2-3-4 ?
Last edit: 11 years 1 week ago by bkt.
11 years 1 week ago - 11 years 1 week ago #63952 by bkt
Ok I try to cancel 5i25 folder .... load 5i25_7i77x2.bit on 5i25 flash with mesaflash ... re-start the pc ... use every type of combination of choice (1-2-3-4 in my image) .... use 5i25 internal data and 7i77x2 .... the same not at all TB5 configurator :evil: :evil: :evil: :evil:
At these point I think the flash is out .... I have 2 5i25 cards installed (on different machine) .... same problem ..... :evil: :evil: :evil: :evil: :evil:
11 years 1 week ago - 11 years 1 week ago #63955 by PCW
Once you have written the firmware with mesaflash you should never need the bitfiles anymore
(doesnt matter what version of mesaflash, they all do the same thing as regards writting firmware)
If you use pncconfs internal settings (which means dont use external XML file)
You dont need the xml files at all since they are not used so it doesn't
matter where you put them or even if you delete them all
I just verified that pncconf from 2.7 works ok with internal 5i25/7I77 data
Last edit: 11 years 1 week ago by PCW.
The following user(s) said Thank You: bkt
11 years 1 week ago - 11 years 1 week ago #63958 by bkt
ok But I use ubuntu 10.04 .... see my image ...NO TB5 CONFIGURATOR.
see cncbasher on wheezy ..... it see TB7 TB8 TB5 configurator. .......
It is only a pncconf problem on ubuntu 10.04? ok please send me a 4axis (ecoder and analogue) + 16 in out configuration makine for axis gui ... I try it and if it works i make my configuration by hand.
11 years 1 week ago #63960 by cncbasher
pncconf needs the 7i77x2.xml file to be in /lib/firmware/hm2/5125 , and with root permissions
u must use sudo to copy these to the folder , without them pncconf cannot work
sudo cp *.xml /lib/firmware/hm2/5i25
Time to create page: 0.222 seconds
